  1. Jun 21, 2019 at 5:03 PM
    stinger86
    stinger86 Well-Known Member
    San Diego, CA
    2016 Double Cab Limited
  2. Jun 21, 2019 at 5:03 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
  3. Jun 21, 2019 at 5:08 PM
    stinger86
    San Diego, CA
    [​IMG] That is the only real noticeable damage. Some crack in the rhino lining of the plastic bumper don't really give a shit about that. It's really not that bad, but still don't back into people's shit.
  4. Jun 21, 2019 at 5:10 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Hard to tell with the bumper on. I would remove it and check it well.
  5. Jun 21, 2019 at 5:10 PM
    stinger86
    San Diego, CA
    As to the how, it was a steep street so you any time you weren't holding the brake you'd roll backwards. Anyways dude was trying to parallel in the spot in front of the truck. Didn't make the cut correctly so was moving to reposition and apparently didn't go out of reverse and applied the throttle. You'd think the display showing the backup camera would be a clue....
  6. Jun 21, 2019 at 5:12 PM
    stinger86
    San Diego, CA
    Just looking for other shit bent/not in the correct location? I guess I know what I'm doing on Sunday, or I guess wouldn't the body shop look at that when I get the estimate?
  7. Jun 21, 2019 at 5:12 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yeah the body shop would look at it. But if you wanted to see for yourself I would remove the bumper cover.
  8. Jun 21, 2019 at 5:13 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Not only does it have a big ass backup camera display, the car has sonar and will beep at you. If you get too close to an obstacle it will say “STOP!” with a loud chime. It even tells you the distance between an obstacle in feet and inches.
    Running Board Man likes this.
  9. Jun 21, 2019 at 5:13 PM
    stinger86
    San Diego, CA
    Yeah guess I'll take a look on Sunday before going to a body shop.
  10. Jun 21, 2019 at 5:15 PM
    stinger86
    San Diego, CA
    So when you touch something does it just play a really loud sighing sound, really? Really you hit something? After all i fucking did?
    Running Board Man and cruiserguy like this.
  11. Jun 21, 2019 at 5:18 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You have to be a special kind of stupid to hit something in a Tesla backing up. There’s so many warning implements.
    Really hard to hit something, as you can see.
  12. Jun 21, 2019 at 5:20 PM
    Daddo
    Daddo Well-Known Member
    Paul
    2004 Doublecab Tacoma 4wd
    Full Total Chaos Long Travel
    My son did a similar thing adding rear discs to his 2001 tacoma and had to grind the rotors down for some reason. ( There was grinding shit everywhere ) Was always a problem because the calipers were fixed not floating . When you drive it with multiple turns the flex of the rotors push the calipers open. Need to brake and the pedal goes to the floor for the first pump, Kinda Scary until you are used to it.
  13. Jun 21, 2019 at 5:26 PM
    stinger86
    San Diego, CA
  14. Jun 21, 2019 at 5:36 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  15. Jun 21, 2019 at 5:38 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I only stalled once pulling it into the garage.
    Running Board Man and Sperrunner like this.
  16. Jun 21, 2019 at 5:54 PM
    eon_blue
    Azusa, CA
    But how much of the clutch did you burn off?
    When I was getting my stmaxx tires installed, the kid that pulled my truck into the bay didn't know stick very well and didn't stall, but roasted the shit out of my clutch
  17. Jun 21, 2019 at 5:56 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I drove it around the block, but only in 1st. I tried to put it into 2nd but it would shutter back and forth till I put it back into 1st.
  18. Jun 21, 2019 at 5:58 PM
    eon_blue
    Azusa, CA
    Means you weren't going fast enough to be in 2nd gear, if the RPMs were too low then it was chugging it sounds like.
    Burning the clutch happens when you give it too much gas while still having your foot on the clutch, common when reversing and not having a good feel for the clutch
    You'll know pretty quick when that awful burnt paper clutch smell permeates the air, or in Miguel's case...smoke fills the air
  19. Jun 21, 2019 at 6:04 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Dont worry, my clutch is still fine. So im sure yours is good
  20. Jun 21, 2019 at 6:04 PM
    eon_blue
    Azusa, CA
    Yeah its fine until one day you need a new one when it should've lasted another 50k+ miles lol
