  1. Jul 20, 2019 at 9:09 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Nice did you already adjust the timing to back in spec? Make any difference in how it ran?
  2. Jul 20, 2019 at 9:13 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Idle is lower.
    There is no timing mark which means i gotta go through finding top dead center and everything. Which im to lazy. I adjusted it to the idle is sounding right and no more sputtering from the exhaust
  3. Jul 20, 2019 at 9:14 AM
    cruiserguy
    Elijah
    SEKS
    Yeah I guess that's what I meant, old school with distributor for adjusting so it's nice and easy to adjust and get close. Smell like it's running better for the emission test?
  4. Jul 20, 2019 at 9:16 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Got my hands on a Rav4 Airbag for my IS300 wheel. Gonna drop it off at a shoe repair shop to see if they can repair the cracked leather. Sounded like they could when I talked to them over the phone. IMG_20190720_112018183.jpg
    Dang meant to post this in the other thread lol.
    01x4 likes this.
  5. Jul 20, 2019 at 9:17 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Smells better. Actually just found the timing mark. Its cast into the black and was coverd in gunk. Now to find the mark on the crank pully
    cruiserguy[QUOTED] likes this.
  6. Jul 20, 2019 at 9:22 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    What condition are the cats in?
    cruiserguy likes this.
  7. Jul 20, 2019 at 9:24 AM
    cruiserguy
    Elijah
    SEKS
    Sweet. I'll bet it's in time now but it'll be good to verify to know for sure. How many degrees advanced is the stock timing? Toyota is usually very reserved on their timing from factory and can usually be advanced a couple degrees with no issues at all. This could give just a tad bit more pep in certain rpm range
  8. Jul 20, 2019 at 9:25 AM
    cruiserguy
    Elijah
    SEKS
    Hopefully not fouled out, that's right his Nox or whatever it's called was really really high huh? Could be the timing and plugs too
  9. Jul 20, 2019 at 9:28 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    So I changed my oil yesterday. My oil smelt burnt and Not even 4 quarts drained out. I change my oil every 3k miles or every 6 months. Always use Mobil 1 and Toyota Filter. Could my piston rings be going out? My tuck is at 197k.
  10. Jul 20, 2019 at 9:33 AM
    cruiserguy
    Elijah
    SEKS
    Do you remember how much you put in to start with?
  11. Jul 20, 2019 at 9:34 AM
    cruiserguy
    Elijah
    SEKS
    Also what grade or rating on the Mobil 1? 5w-30?
  12. Jul 20, 2019 at 9:48 AM
    Fatal_Paradox
    Bardstown, KY
    yeah 5w 30 and each time I fill up I do about 5.5 quarts or until my dipstick reading is in the middle
  13. Jul 20, 2019 at 10:02 AM
    eon_blue
    Azusa, CA
    First time haha
    Using smaw
  14. Jul 20, 2019 at 10:22 AM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    So I have a bad injector any one ever order from motor west performance? 2F2EB44A-D5DF-45B0-9130-FEF7F4BF47D6.jpg
  15. Jul 20, 2019 at 10:32 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I hope you have a certain someone on ignore while your taking this class. Ignore all internet "advice" and listen to your instructor and you'll get the hang of it in no time.
    eon_blue[QUOTED] likes this.
  16. Jul 20, 2019 at 10:38 AM
    cruiserguy
    Elijah
    SEKS
    Toyota does consider 'normal' oil consumption to be up to 1 qt per 1000 miles, just FYI. Not that I'd be content with that consumption, but just as an FYI.
    Mobil 1 runs on the thinner end of spectrum of the weight ratings. Try running 10w-30..... but that only thickens the viscosity at ambient temp not running temp. Me personally I run Mobil 1 0w-40 and have in all of my vehicles for last few years. That would give a little bit more viscosity at running temp, so when you're cruising along at 2500 rpm theoretically you'd have less consumption. Might be worth trying for ya. And don't fret the 0w-40 rating. This is what Porsche runs in their stuff from the factory. And I've analyzed many of my oil samples and the results have all been very good.
    Fatal_Paradox[QUOTED] likes this.
  17. Jul 20, 2019 at 10:46 AM
    eon_blue
    Azusa, CA
    Oh I just let that roll off me lol this is my first time so I expect it to suck. It is fun though, wish I had started a long time ago
    Need to get better about my speed...didn't help that I skipped breakfast this AM so I'm a little shaky
  18. Jul 20, 2019 at 10:50 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  19. Jul 20, 2019 at 11:04 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    vacuum leak or misfire
    Sperrunner likes this.
  20. Jul 20, 2019 at 11:07 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    If it's the van it probably needs a full tune up anyway, timing adjustment, plugs, wires, dizzy, valve lash adjustment, needs a long ass drive where you work it hard to bring that old cat up to temp and probably should get a new cat too
    Sperrunner and Area51Runner like this.
