  1. Jul 22, 2019 at 9:34 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    I was thinking of pressing the OE Rubber bushing in... PITA maybe because of that metal sleeve. :notsure:
    cruiserguy likes this.
  2. Jul 22, 2019 at 9:34 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Oh yeah to get poly out do that. Im talking to press in new oem ot push out old oem
  3. Jul 22, 2019 at 9:34 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Just come over to the shop and use the press
  4. Jul 22, 2019 at 9:35 AM
    eon_blue
    Azusa, CA
    I was just gonna try that ball joint pressing tool you mentioned earlier. Or smack a 35mm axle nut socket on the back of it with a sledge hammer until it goes in lol. Or gets destroyed
    Area51Runner likes this.
  5. Jul 22, 2019 at 9:36 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    ball joint press probably be a better deal. Or go over till @zero4 im sure he has a shop press lol
    eon_blue[QUOTED] likes this.
  6. Jul 22, 2019 at 9:48 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I don't have a hydraulic press press, only an arbor press. My lil brother has one though. What are you guys talking about, leaf spring bushings? I've never had to press out stock ones before. I have Deavers that use poly bushings. Being well over 10 yrs old they we shot (loose as hell). I replaced them last year, put on greasable shackles & main eye bolts too. I've never had any clunking though.
    Speaking of clucking, my truck started clunking in the front anytime it rained. Now it clunks when it's dry. Replaced my LBJs last week thinking it was them since they'e got well over 100K on them. Wasn't the problem, they were still good, no play at all & they were Moogs. I put new Moogs back on. Yeah, yeah, yeah, OEM blah blah blah. :luvya:
    It's my outer tie rod ends & maybe inners too cause the're pretty loose also. I regreased them when I replaced the LBJs, most of the clunking went away. Replacing both inner & outer tie rods today after work.
    Replacing all this crap with a bad back sucks!
    cruiserguy and Area51Runner like this.
  7. Jul 22, 2019 at 9:49 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    right for the thumb
    Sperrunner likes this.
  8. Jul 22, 2019 at 9:50 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    You sure its not the lca bushings
    Wulf likes this.
  9. Jul 22, 2019 at 9:50 AM
    eon_blue
    Azusa, CA
    Id be impressed if anyone could properly swing a big 8lb sledge hammer with one hand while holding the object with the other lol
  10. Jul 22, 2019 at 9:51 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I did while the leafs were sitting in my lap because it was the best way to hold it stead
  11. Jul 22, 2019 at 9:51 AM
    Wulf
    rock raisin
    Fwiw I was told my leaves are alcans and they've not sagged in the 7 years of wheeling and hauling I've done in the Tacoma
  12. Jul 22, 2019 at 9:52 AM
    eon_blue
    Azusa, CA
    No doubt they're worth every penny...but thems a lot of pennies
  13. Jul 22, 2019 at 9:52 AM
    Wulf
    rock raisin
    I bet James will just to prove is wrong. Hopefully he video tapes it
  14. Jul 22, 2019 at 9:53 AM
    eon_blue
    Azusa, CA
    But you used a ball joint press
  15. Jul 22, 2019 at 9:54 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Not 100% sure, that's what I thought it was last year when it started happening. Would only clunk going over speed bumps with the wheels turned when wet. I think I said that here a while back cause I know my bushings are torn.
    We'll see today after I replace all the tie rods, they're loose as hell. If it is the LCA bushings, then I don't care, I'll wait till my buddy's garage is finished being built.
  16. Jul 22, 2019 at 9:55 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Yeah but the socket got stuck in the leaf after pushing the bushing out because it was fge same diameter as the bushing
  17. Jul 22, 2019 at 9:58 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Had some poly bushings damn near drive me crazy with a creaking noise. Had to buy a chassis ear to pinpoint the noise. I only use poly on end links now.
    Area51Runner[QUOTED] likes this.
  18. Jul 22, 2019 at 10:02 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Hammers are Thumb Detectors. Crescent/adjustable wrenches are Nut Rounders. I have a genuine Thumb Detecting Nut Fucker just like AvE.
    cruiserguy and Hooks98tacoma like this.
  19. Jul 22, 2019 at 10:06 AM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Don't put Autozone LCAs on your truck. The bushings fail in 10,000 miles lol.
    zero4 likes this.
  20. Jul 22, 2019 at 10:07 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Ive been known to use that as a hammer
    zero4[QUOTED] likes this.
