  1. Jul 26, 2019 at 4:58 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Non-reverseble ratcheting wrenches can go back to the pits of hell from which they came.
    I only have one set like that, and its the GW XL Metric set. Only gets used rarely, cause its not every day that I need a 12" long 14mm lol. Only got them after doing my carrier bearing, long wrenches wouldve helped a ton on those driveshaft bolts.
    Sperrunner[QUOTED] likes this.
  2. Jul 26, 2019 at 4:59 PM
    eon_blue
    Azusa, CA
    there's the 3 ton normal, 3 ton low profile, and 3 ton extended reach and then the aluminum ones right?
    I should've gotten the extended reach tbh, back when I bought it though I was still on 32s and 5100s so it was more than enough at the time. Still works it's just nearly maxed out when I do use it
  3. Jul 26, 2019 at 5:01 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    My HF 8" drill press is a pos. Chuck wobble is very noticeable. After I got that, I steer clear of HF power tools.
    Also, I was amazed at how powerful my M12 Impact driver is. Beats the dewalt 12volt stuff we have at work by a long shot.
  4. Jul 26, 2019 at 5:01 PM
    eon_blue
    Azusa, CA
    yeah the Chicago Electric dremel I bought is a POS haha.
  5. Jul 26, 2019 at 5:05 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    If you get the 16s you don't have to waste that valuable tire rubber by moving your nice 16 tires over to new temp wheel
    01x4[QUOTED] and Sperrunner like this.
  6. Jul 26, 2019 at 5:05 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    My actual dremel is starting to die, ever since I did artistic pumpkin carving with it lol. I think Ill get the M12 cordless version to replace it someday.
    eon_blue[QUOTED] likes this.
  7. Jul 26, 2019 at 5:12 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  8. Jul 26, 2019 at 5:16 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    My Chicago electric angel grinder is great. Also
    FLBAdrian likes this.
  9. Jul 26, 2019 at 5:21 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Craftsman Dutch Colonial?
  10. Jul 26, 2019 at 5:25 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Those are nice. But I really need to talk my boss into cordless grinders.
  11. Jul 26, 2019 at 5:31 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    The m18 ones
  12. Jul 26, 2019 at 5:31 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    They are the best ones
  13. Jul 26, 2019 at 5:31 PM
    cruiserguy
    Elijah
    SEKS
    Helluva deal. But they are missing the flex-head which I've found invaluable.
  14. Jul 26, 2019 at 5:32 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Yes. Dewalt corded tools are good, their battery stuff is just meh for the industrial environment.
  15. Jul 26, 2019 at 5:33 PM
    cruiserguy
    Elijah
    SEKS
    I have lots of M18 and M12 tools and the M18 Fuel line of tools beats all of my plug in or pneumatic powered tools
  16. Jul 26, 2019 at 5:41 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    You mean strippers? If you’re lucky there’s no strings attached
  17. Jul 26, 2019 at 5:45 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Arent those illegal in Utah?
  18. Jul 26, 2019 at 5:52 PM
    eon_blue
    Azusa, CA
    All I know is that it's a true craftsman (not sure on the Dutch Colonial part) and it was built in 1926
    CS_AR[QUOTED] likes this.
  19. Jul 26, 2019 at 5:56 PM
    JKO1998
    Utah
    Pasty’s
  20. Jul 26, 2019 at 5:57 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    ok guys. brainstorm with me.. my driver side door on the tundra wont open from the inside or outside. ive got most of the door panel off and see the linkages are all attached, pretty sure the latch has failed in the locked position... kinda out of ideas at this point
    Running Board Man likes this.
