  1. Jul 30, 2019 at 8:55 PM
    Wulf
    rock raisin
    Motor is too hot to touch too now BTW.
    cruiserguy likes this.
  2. Jul 30, 2019 at 8:55 PM
    Wulf
    rock raisin
    As far as I can tell it was installed before 2007 and was last serviced in 2008 before I started messing with it.
  3. Jul 30, 2019 at 8:56 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    And the back window in the bed
  4. Jul 30, 2019 at 8:56 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Wait so it runs and its common - say speed 1 and its 120v then it stops running and it goes to common - speed 1 24v
  5. Jul 30, 2019 at 8:57 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The shocks were up there as a contingency plan for something else, but the window did fall when the cab roof hit the ground and landed unharmed haha. I still have it actually
  6. Jul 30, 2019 at 8:58 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    If this the case see if the signal wire at the board or what ever controls power to the fan is still 24volts or if it drops
  7. Jul 30, 2019 at 8:58 PM
    Wulf
    rock raisin
    Yeah, something like that. I would see 110+ on speed 1 and 400mv or so on the others
  8. Jul 30, 2019 at 8:58 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Bad motor wulf
  9. Jul 30, 2019 at 8:59 PM
    Speedytech7
    I'll go with the first, the latter sounds too old world spiritual. At a certain point you realize you're going over and just sorta work with that.
    cruiserguy[QUOTED] likes this.
  10. Jul 30, 2019 at 9:00 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    blow seals out. kill the trans eventually.
  11. Jul 30, 2019 at 9:01 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    It will only run 1 speed and changed if needed. But if its dropped from 120 to 24 yoi have a power supply issue. Either the signal wire telling the board or contactor to close to opening or its not having power sent to it by the board
  12. Jul 30, 2019 at 9:02 PM
    Speedytech7
    Full line pressure isn't even achieved under full throttle, but moderate increase should be fine. I just wouldn't yank it all the way out.
    Running Board Man likes this.
  13. Jul 30, 2019 at 9:02 PM
    JKO1998
    Utah
    That wrecks the real reason you hate the KOs huh
  14. Jul 30, 2019 at 9:02 PM
    cruiserguy
    Elijah
    SEKS
    H
    Did you catch where Wulf said the motor was too hot to touch?
  15. Jul 30, 2019 at 9:03 PM
    Empty_Lord
    Dan
    if youve got the cable tight enough like he supposedly had it'll do damage. i run mine a little tight. but nothing ridiculous.
  16. Jul 30, 2019 at 9:03 PM
    Speedytech7
    Nah, they were already disliked well before that. I started really disliking them about a year after I got them.
  17. Jul 30, 2019 at 9:04 PM
    Speedytech7
    Agreed
  18. Jul 30, 2019 at 9:04 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    That might be from it trying to start over and over again
  19. Jul 30, 2019 at 9:06 PM
    Empty_Lord
    Dan
    speaking on transmissions. do i just pull the tundras and have it rebuilt or do i try a shift kit first to fix the 4th to 5th flare when cold..
  20. Jul 30, 2019 at 9:06 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Shift kit
