  1. Aug 5, 2019 at 7:03 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Nominal use for 1/2 inch conduit is a single strand of Romex, two is pushing it, and three is nearly too much.
    Running Board Man likes this.
  2. Aug 5, 2019 at 7:07 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Eh, with runs like that you couldve easily bought some 1" to replace it with.
    Also, forgive my ignorance of residential codes, but if its going through conduit, does it need to be sheathed romex? Couldve pulled a bunch of 12 ga wire by itself much easier.
  3. Aug 5, 2019 at 7:11 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Right after I posted the pics I noticed the reflection in that second one, and I was like I'll edit it and delete it or crop whatever, than thought nah, those tards won't notice it. Didn't take fukin sperruner but 10 minutes to blast it.
  4. Aug 5, 2019 at 7:14 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Huh. I always thought of you as our resident old fart. Guess that pic disproves my theory.
  5. Aug 5, 2019 at 7:15 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    at least you only have a 20 cent spread on those
    its like 50 cent spread here from 87 to 91, it makes me mad my truck likes the good stuff!
    my truck did not know what it was getting in Milwaukee
    found a BP that had 93 octane so i juiced the betch up :)
  6. Aug 5, 2019 at 7:15 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It’s a bit of a gray area, I would’ve much preferred THHN machine wire and some say it’s okay, some say it’s not. It’s even a gray area if you can remove the outer sheathing from Romex and used only the inner wires through conduit.
    I really hate solid core wire, it’s a real bitch to work with.
    I originally wanted to run 3/4 conduit, but all our fixtures used 1/2 NPT bungs and it was simpler to just use 1/2 conduit for the whole system. That run of conduit is the only place I have more than 1 wire running through it.
  7. Aug 5, 2019 at 7:17 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Are you putting 91 in your truck that only needs 87?
    GQ7227[QUOTED] likes this.
  8. Aug 5, 2019 at 7:18 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    its a placebo, it likes the 91 better for some reason it seems to drag on 87 sometimes
    i like it peppy :)
  9. Aug 5, 2019 at 7:20 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    it will probably but it probably will not like it, the bitch has an attitude of sorts
  10. Aug 5, 2019 at 7:20 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Free>Cheapest shit at the pump> anything else
  11. Aug 5, 2019 at 7:22 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Yeah Im glad I dont have to deal with solid core wire in the industrial field. Ive seen rubber sheathed aluminum wire wrapped in cloth though at some super old facilities. That was, um, interesting to work with.
    Im gonna have to dig deeper into this code stuff regarding emt in the home. Ive got some shop lights running off extension cords secured to the ceiling in the garage. Id like to bend up some emt and pull 14 ga wire someday.
  12. Aug 5, 2019 at 7:24 PM
    JKO1998
    Utah
    I’d take it
  13. Aug 5, 2019 at 7:26 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Some older vehicles seem to run better with higher octane. The 92 suffers from pinging due to premature fuel detonation and the high octane gas makes the issue much more tolerable.
  14. Aug 5, 2019 at 7:29 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    That’s... that’s not how it works.
  15. Aug 5, 2019 at 7:31 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Generally don’t need to run conduit unless it’s outdoors or it’s not running through the studs in a new construction building. I just stapled my shop lights to the ceiling and am t-ing it off the existing bulb fixture in the center. I want to run conduit for it one day.
    I’ve seen people run conduit and run it through the studs which is completely unnecessary. That’s like wearing two condoms.
  16. Aug 5, 2019 at 7:33 PM
    eon_blue
    Azusa, CA
    If that's true then you might need to do a tune up or something, should run just fine on 87 but if you're getting some knocking on regular it's something to be looked into.
    Only time these trucks should need 91 is if you're supercharged/turbo'ed
  17. Aug 5, 2019 at 7:38 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Yeah I know what I have is totally safe. But it looks ghetto. If I owned the house, it would be rigid emt from day 1. Not the flexy stuff, as that also looks trashy. Like whoever did it was too scared to try a few bends on the rigid stuff. And all it would be is a few 90 degree bends and an offset going into the switch box. Easy to do.
  18. Aug 5, 2019 at 7:40 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    it has always seemed to knock 'occasionally' since i got it on less than 91, or its all in my head which is probably true
    i just don't care for ethanol is most likely why and the 91 has no ethanol here
  19. Aug 5, 2019 at 7:41 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    corn is for FOOD not fuel
  20. Aug 5, 2019 at 7:44 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    but then it might be my driving habits and not taking it past 3k rpm unless in 5th gear :notsure:
