  1. Aug 30, 2019 at 8:28 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i wonder what the crow would do to fight back on a 2nd gen hater
    got some snarky reply back today from one of them in jersey
    Running Board Man likes this.
  2. Aug 30, 2019 at 8:35 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Autozone hoses in the 92, no problems from the hose for going on 4 years.
    Id bet that oem hose is a gates or some other US manufacturer.
  3. Aug 30, 2019 at 8:41 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Mitsuboshi and Yokohama, and some other one. Mostly Japanese but an American replacement is no worry
  4. Aug 30, 2019 at 8:45 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Yeah pretty hard to mess up a hose. Id go Napa hose if I had to replace mine, only cause I like their rewards system over the others.
  5. Aug 30, 2019 at 8:46 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i should shop Napa instead of OReilly
  6. Aug 30, 2019 at 8:48 PM
    Speedytech7
    Orielly and Napa both carry gates and Bando
  7. Aug 30, 2019 at 8:55 PM
    Speedytech7
    Just know who usually makes what, I look up companies that OEMs out source to so I can get parts from their third party names. That's how I find quality parts for cheapo prices when I work on things. Easier to buy as wholesale or a third party rebox than from the OE vendor. Get OEM parts for AutoZone and Oreilly house brand prices often enough. I work on a lot of Japanese crap and take note of it as I replace or repair which helps as well. Here's a name I bet you haven't heard but they make tons of belts, Unitta.
  8. Aug 30, 2019 at 8:55 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Both have basically the same rewards system too. Get $5 off every $100 spent. I only pick Napa over Oreily cause of my poor experiences with the oreily managers in town. Strung me along for 4 job interviews, eventually told me they wanted a full timer for a part time ad. :rolleyes:
  9. Aug 30, 2019 at 9:10 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Those are probably the 12A ones. The 6A & 9A ones were crazy expensive too when they first came out. I don't own any 12A ones. I do have one 9A but I waited till the price finally came down. If/when the 12A ones get cheaper I might get one but I don't really need 12A. I'd use it for my blower, that's what I'm using the 9A on now. All my other M18 batts are 5A. They last a long time for me.
    I'm waiting for the M12 3A compact ones to come down in price. The 2A ones don’t last very long in the M12 ratchet.
  10. Aug 30, 2019 at 9:15 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I just Picked up a bunch of stuff today and i think it came with the 2A. Last fine in the impact but over heats fast in a grinder. I might have to buy a 12A to use just for the grinder.
    I wonder how long the 6A will last in my fan. And it what you mean with the 2A m12, they suck, i go through them way to fast and i have 4
  11. Aug 30, 2019 at 9:45 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    The grinders need at least the 5A battery to be useable, I think that's what the kits come with it. The blower don't last that long with the 5A & is why I got the 9A. Problem with the 12A is they're stupid expensive still, that and they're pretty bulky & heavy to use in a hand held tool. The 9A is pretty big for a batt already. They take a while to charge too unless you use the fast charger. I won't be getting the fast charger though. 12A would be good for the grinder if you need to do a lot of grinding but the weight will make the tool off balance. I'd just use a corded grinder if I had to do a lot of grinding.
    I only own one 2A M18. I only use it in the flashlight though because of it's compact size. Was a waste of a 5A battery using in the flashlight. I think they make 3A CP now for M18 but whatever I don't need one. I just want the M12 3A CPs and I'll be good.
  12. Aug 30, 2019 at 9:58 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I’m tying on go more cordless because its not always easy to have power access out in the field. Though i did go with a corded rotary hammer drill because when i read the box for the M18 it said like 20 min run time
  13. Aug 30, 2019 at 10:18 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Oh yeah, definitely go cordless for field work if/when possible. So much easier & convenient than having to lug around & use extension cords! Heck, I rarely even use my air tools at home now, I use cordless most of the time.
    You do that much grinding for your work? And a rotary hammer drill? Did you change jobs?
    Ah, just do like this! ;)
  14. Aug 30, 2019 at 10:23 PM
    Speedytech7
  15. Aug 30, 2019 at 10:27 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I do commercial hvacr now. Today I had to install new door guides for a walk in case, which meant I had to cut the old bolts out and drill new holes into the concrete to install new mount bolts. So I needed some fancy tools lol
  16. Aug 30, 2019 at 10:29 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    With just one twist of the boost gauge you can whip have the engine from existence
  17. Aug 30, 2019 at 10:31 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    @zero4
    You should see my Milwaukee shelf in my truck lol
  18. Aug 31, 2019 at 6:31 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
  19. Aug 31, 2019 at 7:00 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    They open today?
  20. Aug 31, 2019 at 7:02 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
