  1. Aug 8, 2018 at 1:02 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I work for a large chemical company that recently merged with another large chemical company.
    Title includes: Maintenance of air compressors, cooling towers, cooling water fan arrays, boiler operation and maintenance.
    I have 10 cooling towers, 13 boilers and 8 250 HP, 1000 cfm air compressors that need constant monitoring or service.
    I have no parabolic cooling towers (think nuke plants)
  2. Aug 8, 2018 at 1:03 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    A Hand Throttle?
  3. Aug 8, 2018 at 1:03 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    large A/C units, plastic blow molders to name a couple
    Speedytech7[OP] likes this.
  4. Aug 8, 2018 at 1:05 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
  5. Aug 8, 2018 at 1:08 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Toyota must really like that ignition cylinder. That’s looks exactly like the one on our trucks.
    When would you use something like that?
  6. Aug 8, 2018 at 1:09 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    cold starts, gas pedal link break
  7. Aug 8, 2018 at 1:10 AM
    Speedytech7
    I have a self made one in the truck for keeping the amperage output on the alt up for winching that way I can focus on the winching rather than if my battery is going to die despite the truck still being running which can happen. You could use it to limp if your cable broke I guess too.
  8. Aug 8, 2018 at 1:10 AM
    koditten
    Kirk
    Central Michigan
    How much does the voltage really fluctuate? We all know how inaccurate the factory gauges are. Has anyone hooked up a scan tool to see real numbers?
  9. Aug 8, 2018 at 1:11 AM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    Hand throttles used to be a big thing on farm trucks, super handy. Also a lot of times offroad with a manual that a hand throttle would be nice
  10. Aug 8, 2018 at 1:13 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    wwot page 800
  11. Aug 8, 2018 at 1:13 AM
    Speedytech7
    The cruiser being a fancy weirdo has multiple alt output/demand modes. At idle it doesn't supply a whole bunch so the idle feels smoother. I idle around 13.4-13.8 and above 900rpm it seems to peak around 14.5-14.8. But again a load is really the worry factor, since all alternators supply less amperage at idle than say 1500rpm. I'll use it in the cruiser to keep the AC performance up in traffic, and on the taco I use it to keep the winch from draining the battery then taking out the alt in the process.
    koditten[QUOTED] likes this.
  12. Aug 8, 2018 at 1:13 AM
    E30325
    Nick
    That's a hell of an offer, sounds great. If you guys end up doing that if you don't mind you should hit me up
  13. Aug 8, 2018 at 1:15 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    yea, same here :)
    E30325[QUOTED] likes this.
  14. Aug 8, 2018 at 1:16 AM
    E30325
    Nick
    I'm in Oregon too so that isn't even far for me haha, I'm sure I've been some of the places he's talking about. The Gifford Pinchot national Forrest is absolutely amazing
  15. Aug 8, 2018 at 1:16 AM
    Speedytech7
    @BartMaster1234 and @koditten, if you have a manual trans it can be nice too so if you're in the rocks or on a super steep hill your starts can be easier and you can use the brake and clutch simultaneously. I haven't need that yet but who knows maybe I'll park myself precariously one time or accidentally stall on a ledge or something.
    BartMaster1234, E30325 and what road like this.
  16. Aug 8, 2018 at 1:17 AM
    Speedytech7
    So is the Wallowa Whitman national forest. I rolled my last truck in Oregon haha
  17. Aug 8, 2018 at 1:18 AM
    E30325
    Nick
    Never been there, sounds great though
  18. Aug 8, 2018 at 1:19 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I never understood why you had to swap things in your trucks. What was wrong with the donor truck you use the body for?
    E30325 likes this.
  19. Aug 8, 2018 at 1:25 AM
    Speedytech7
    This was one of our campsites...
    [​IMG]IMG_5314 by Ben, on Flickr
    [​IMG]IMG_5316 by Ben, on Flickr
    Here's where some dipshit flipped his truck...
    [​IMG]IMG_5345 by Ben, on Flickr
    Said dipshit stayed for the rest of the three day trip anyway...
    [​IMG]IMG_5371 by Ben, on Flickr
    Monte helping me through a notch in the beautiful WW National Forest
    [​IMG]IMG_5412 by Ben, on Flickr
    Breath taking views...
    [​IMG]IMG_5431 by Ben, on Flickr
    The sheer magnitude of it all...
    [​IMG]IMG_5475 by Ben, on Flickr
    We even had riverside camping...
    [​IMG]IMG_5525 by Ben, on Flickr
    Totally worth going back to Eastern Oregon...
    [​IMG]IMG_5528 by Ben, on Flickr
    Prayn4surf and E30325[QUOTED] like this.
  20. Aug 8, 2018 at 1:32 AM
    Speedytech7
    It was pretty tired as most neglected Toyotas can be. It had a higher mileage 3RZ that had its engine light on for lots of things (seemed to run okay though), was a fucking automatic (dangerously slow), was on some clapped out suspension, and was nasty inside. But it had nicer axle gears than my other one did, it had a perfect frame, body didn't leak, everything worked, and the bed interior was flawless. I wanted my manual trans and recently rebuilt engine so I swapped it all, and if you swap the trans you swap the ECU and associated wiring. Doing the wiring, well might as well put my nicer HVAC crap from the other truck in too. I swapped every electrical harness, all HVAC, all clutch related components, welded new x-members in, swapped steering rack, spindles, years worth of mods on the other truck done in days... not to mention suspension and welding sliders back on... thanks again @drr you saved my bacon! All because I wanted my reliable Toyota pickup back again, I knew all my parts were good, it was just a matter of installing them.
    drr likes this.
