  1. Jun 7, 2018 at 1:54 PM
    #1441
    eon_blue
    Azusa, CA
    My brakes are making a terrible rubbing sound lately ever since I had that issue where the caliper bolt was loose and leaking...don't really know what's going on (they feel/brake just fine but make that terrible sound especially when cold). I just replaced the rotors and pads a couple months ago.
    Thinking I should just replace the front and rear lines and bleed the system and see where that leaves me. Got my steel front lines coming in next week.
  2. Jun 7, 2018 at 1:54 PM
    #1442
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Remember 1 2 3 hold open valve then close, repeat till you dont see anymore air. Or atleast thays how i do it. Also make sure you dont drain the master cylinder while doing that lol
    eon_blue[QUOTED] likes this.
  3. Jun 7, 2018 at 1:56 PM
    #1443
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I dont think steel lines are effective if you only replace say the rear i think you have to replace all the lines for it to really work
  4. Jun 7, 2018 at 1:57 PM
    #1444
    eon_blue
    Azusa, CA
    They will all be steel eventually, I ordered the front ones yesterday but won't be here till next week.
  5. Jun 7, 2018 at 1:58 PM
    #1445
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I would wait to do it all at the same time. Bleeding breaks is kinda a pita so if you can only do it once i would do that
  6. Jun 7, 2018 at 2:06 PM
    #1446
    eon_blue
    Azusa, CA
    hmm good point.
    (when it rains it pours) I still have the clunking coming from the rear springs despite repeatedly checking the torque on every bolt I worked on since installing the AALs. Only thing I can think of is that maybe I didn't get the front leaf spring hangar bolts pushed all the way through when I torqued them down. Gonna loosen both tonight and try to push/screw the bolts through further and see if that solves it; I know from past experience that if there's any play in the front hangars then the leaf packs 'pop' like crazy. If not, then it's gotta be something with the packs themselves. I know the center bolts are tight so I'll be at a loss if tonight's attempt doesn't remedy it.
    Between that and brakes, my truck sounds like a bucket of hard objects rattling around whenever I hit a bump in the road or take a turn at speed.
  7. Jun 7, 2018 at 2:15 PM
    #1447
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Do your Icons have spherical bearings or rubber bushings. When spherical bearings go out they sound like marbles in a blender haha
  8. Jun 7, 2018 at 2:16 PM
    #1448
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I wonder i its your shocks? But yeah go check every bolt and make sure nothing is lose.
    And i feel you my truck makes alot of sounds too Most of my noise ik is just inter trim making noise but i get this weird clunk up in the RF and its random and everything I tried doing hasnt sloved it yet. Started happening after i put my new front bumper on
  9. Jun 7, 2018 at 2:20 PM
    #1449
    eon_blue
    Azusa, CA
    not sure I'll have to check, they're still relatively new (~15k miles on them) so I'd be a bit surprised, but I've heard worse from other people with Icons lol.
    yeah to some extent I just live with some of the noises I hear, I get that it comes with the territory when you're changing everything from stock and beating up on your truck nearly every weekend. But these noises coincide directly with the recent work I did, which is what has me worried. I guess if I go through everything and can't find anything wrong, I'll feel better about living with it. I've had noises come and go that seemed to basically remedy themselves in the past but I don't want to rely on that without first going through everything lol.
  10. Jun 7, 2018 at 2:23 PM
    #1450
    eon_blue
    Azusa, CA
    When I had my leafs a part I sprayed them down with a healthy amount of grease-free, dirt-repellant lubricant to prevent the squeaking from coming back that I had before...wonder if maybe all that lube between them is making them prone to slipping a bit...enough to make some noise. Guess it's one possibility if I can't find anything wrong.
  11. Jun 7, 2018 at 2:24 PM
    #1451
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Yeah im the say way, one i put my front bumper one i got a weird noise almost like something wrong with my suspension but after i went through all of it and seeing everything is good I just learned to deal with it.
  12. Jun 7, 2018 at 2:32 PM
    #1452
    eon_blue
    Azusa, CA
    alright, just ordered the Trail Gear BPV relocation kit...since the rear is sitting even higher now I should probably factor that into my brake issue possibilities, at the very least it'll help with my braking. Will put that on with the brake lines hopefully next weekend.
    Sperrunner likes this.
  13. Jun 7, 2018 at 2:37 PM
    #1453
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Just found out i need new ball joints... funnnnn
    david9kelsey likes this.
  14. Jun 7, 2018 at 2:39 PM
    #1454
    Speedytech7
    At least it's like two bolts and a tiny stud on 5 lugs.
  15. Jun 7, 2018 at 2:43 PM
    #1455
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Yeah it’s a little harder with the fabtech spindles because i have to pull the whole spindle off.
  16. Jun 7, 2018 at 3:02 PM
    #1456
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Hmm so it looks like i need to call camel back, the left ball joing is 55$ while the right is 75... but its the same exact part
  17. Jun 7, 2018 at 3:11 PM
    #1457
    Speedytech7
    Call Rich or Gary at Camelback
  18. Jun 7, 2018 at 3:13 PM
    #1458
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I will once i get some free time. I dont think they are bad because i have no symptoms of bad ball joint but the boots are torn so they are leaking grease
  19. Jun 7, 2018 at 3:29 PM
    #1459
    Speedytech7
    mechanicjon likes this.
  20. Jun 7, 2018 at 3:47 PM
    #1460
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
