  1. Sep 19, 2019 at 11:02 AM
    eon_blue
    Azusa, CA
    Finally ordered some 3˚ axle shims....hopefully helps with driveline vibes and makes my leaky pinion seal happy
    Running Board Man likes this.
  2. Sep 19, 2019 at 11:04 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Never
  3. Sep 19, 2019 at 11:05 AM
    eon_blue
    Azusa, CA
    never say never
    But really though why are we saying never
    I took the carrier bearing drop spacers out awhile ago as I think it was just making things worse...should have done shims from the start.
  4. Sep 19, 2019 at 11:10 AM
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    Spacers on the center bearing cause of lift?
  5. Sep 19, 2019 at 11:13 AM
    eon_blue
    Azusa, CA
    Yeah, the rear lift throws off the geometry of the driveline and as a result over the last few years my pinion seal has developed a slow leak. I tried carrier bearing spacers first cause they're easy to slap on, but I don't think they helped at all and in fact might've made it worse. Shims slide under the leaf packs/above the axle and angle the driveline back into it's stock geometry, or close to it.
    I'll probably still need to address the pinion seal leak but it's not terrible yet
  6. Sep 19, 2019 at 11:15 AM
    jgill21
    Jake
    Nashville
    Ah ok, never would've thought of trying to keep it all straight when I lift it. But If you tried it and it didn't work, is there any way to fix it?
  7. Sep 19, 2019 at 11:20 AM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    I have some vibes around 60mph and I plan on getting 2.5 or 3 degree shims. Sucks that ARB was only willing to give me a spacer to fix my dakar lean and the shims will be taking priority over a spacer.
  8. Sep 19, 2019 at 11:21 AM
    Empty_Lord
    Dan
    I’m
    Just being a smart ass. Shims usually help a lot
    eon_blue[QUOTED] likes this.
  9. Sep 19, 2019 at 11:21 AM
    eon_blue
    Azusa, CA
    yeah the shims are basically a spacer anyway, just an angled one. I picked up the 3˚ ones just because it seems those are the most commonly used for ~2.5 - 3" lift.
    I haven't tried the shims yet but they should do the trick. The carrier bearing spacers were the thing I tried before that didn't help
  10. Sep 19, 2019 at 11:38 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    This is da police
    Whoop whoop
    04Pre_Runner likes this.
  11. Sep 19, 2019 at 11:38 AM
    04Pre_Runner
    Andrew
    I have two trim packers up front to offset my front lean. The problem here is my Dakar rear leaf springs have completely failed after 10,000 miles and began heavy leaning to the driver side even with no gas in the tank. I also had a major sag as they no longer provide much lift.
    After calling them up they just gave me the run around for months, until their final offer was a leaf spring spacer block to fix the lean to the driver side in the rear.
  12. Sep 19, 2019 at 11:40 AM
    eon_blue
    Azusa, CA
    If you carry weight in the back then Dakars aren't any good, in my experience. Even with an AAL they sagged badly with a bed rack and tent + couple hundred pounds of gear.
  13. Sep 19, 2019 at 11:43 AM
    04Pre_Runner
    Andrew
    The sag began with literally nothing in the rear of the truck. I had taken the truck in a few camping trips, moved some furniture and firewood, and done other "truck things" but up until my camper shell in July I had never permanently had weight in the bed. So they literally failed under the weight of a stock empty truck.
  14. Sep 19, 2019 at 11:44 AM
    04Pre_Runner
    Andrew
    I'm going Deaver or Alcans next. And putting these Dakars on my project truck.
    Silver02Taco likes this.
  15. Sep 19, 2019 at 11:45 AM
    eon_blue
    Azusa, CA
    Hmm yeah that's not good. I mean they are naturally pretty flat springs but they should still be providing lift esp with no weight back there.
    I haven't had great luck with my Expos either, if I were to do it again knowing what I know now, I'd have gone with Alcan springs from the get go
    04Pre_Runner[QUOTED] likes this.
  16. Sep 19, 2019 at 11:46 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Start my own COPS spinoff.
    Silver02Taco and 04Pre_Runner like this.
  17. Sep 19, 2019 at 11:47 AM
    eon_blue
    Azusa, CA
    gonna laugh when you get featured on a real episode of COPS getting arrested for impersonating one lol
    Actually I don't even know if that show is still on
  18. Sep 19, 2019 at 11:59 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    don't think its still on either (except re-runs of course) but they definitely still arrest for impersonating... :ballchain:
  19. Sep 19, 2019 at 12:10 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Unless you've got a bumper/swingout tire carrier, the tailgate is forever replaced by my tiregate.
    @JKO1998 your ditch lights removed.
    Also went to Sears to redeem some $25 worth of expiring points; these magnetic LED flashlights were only $3/ea for the blue/green and $5 for the red.
    JKO1998 likes this.
  20. Sep 19, 2019 at 12:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    FML forgot he's on probation from LT :rofl:
