  1. Oct 6, 2019 at 2:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm thinking the most difficult thing to remove would be the ADD piece/tube from a front diff if I can't find a front diff that used manual hubs.
  2. Oct 6, 2019 at 2:51 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    ideally you want both. the 3/8 is more useable for everything but wont do the big shit like the 1/2
    Kwikvette[QUOTED] likes this.
  3. Oct 6, 2019 at 2:51 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I got to use my co2 that day (it was just last week) and the guy's mind was blown :rofl:
  4. Oct 6, 2019 at 2:52 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    The only time I don’t use my 1/2 pneumatic gun is when I’m doing small fasteners, like M6 and below. A majority of what I do (e.g. removing horns from old GM sedans) only requires low power attacks. I don’t need a huge 1/2 to remove an M6 or M5 bolt or nut.
  5. Oct 6, 2019 at 2:52 PM
    eon_blue
    Azusa, CA
    Ever since I left my rear diff drain plug finger tight a couple years ago I always do a mental check list of torqued bolts when I get into my truck after working on it. I got lucky that time that I caught the leak from it the next day...even luckier it didn't come off completely while driving
    cruiserguy[QUOTED] and Kwikvette like this.
  6. Oct 6, 2019 at 2:52 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    IR 1" impact for the win. For when you have to break the lugs loose on your Mack Dump Truck.
  7. Oct 6, 2019 at 2:52 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Even my 1/4" drive Makita can pop crank pulley bolts loose. Honestly nowadays unless you're in the rust belt I think most of the electric ones are good choices. Maybe get something you have batteries for already, that's the expensive part.
  8. Oct 6, 2019 at 2:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Batteries I have are for the lower powered Craftsman tools so I'll be starting new all over again.
  9. Oct 6, 2019 at 2:53 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Do yourself a favor and replace the e-torx fasteners that attach the tube to the clamshell with hex bolts. The e-torx strip really easily. I had to weld a wrench to my old diff to get a stripped one off.
  10. Oct 6, 2019 at 2:54 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    While you're at it, look at the tools that share the batteries with the tool you want, and possibly those that your friends have. Buying a battery powered tool tends to get you into an ecosystem from that manufacturer, and if you can share batteries with friends, it's that much easier.
  11. Oct 6, 2019 at 2:54 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh I was definitely planning on it; I saw @Uphillshunter replace his when he did his big swap.
  12. Oct 6, 2019 at 2:56 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Ohhhhh yeeeaaaaahhhh
  13. Oct 6, 2019 at 2:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Btw, @BartMaster1234 you know it's pretty much your fault that I got a prerunner and decided to do a 4x4 swap right?
    I had gotten rid of my 2007 Nissan Frontier only because I like the way the Tacoma drove/felt vs the Frontier I owned.
    BartMaster1234 likes this.
  14. Oct 6, 2019 at 2:58 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Or for 5-ton owners...even if it's an imaginary 5-ton :stirthepot:
  15. Oct 6, 2019 at 2:58 PM
    Empty_Lord
    Dan
    I have a 1” at work.
    For Honda crank bolts
    cruiserguy and Blue92[QUOTED] like this.
  16. Oct 6, 2019 at 2:59 PM
    eon_blue
    Azusa, CA
    On the plus side...imaginary tools for an imaginary vehicle are cheap
    Empty_Lord and Kwikvette[QUOTED] like this.
  17. Oct 6, 2019 at 2:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    "MAINTENANCE IS ALMOST NON-EXISTENT!"
    :rofl::rofl::rofl:
    eon_blue[QUOTED] likes this.
  18. Oct 6, 2019 at 2:59 PM
    cruiserguy
    Elijah
    SEKS
    Huh??? What kinda Makita 1/4 impact can get a crank bolt??? Oh maybe brand new car with no loc tite. Doubt it'd work on any of the crank bolts I've removed for timing belts
  19. Oct 6, 2019 at 3:00 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Stripped fasteners suck. I don’t know why Toyota used E-Torx.
  20. Oct 6, 2019 at 3:00 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I saw the south main auto guy on youtube do a timing kit on a pilot. He used a really thick walled impact socket and buzzed it off with a smaller gun. Used a normal socket for demonstration and it wouldnt budge.
