  1. Oct 7, 2019 at 11:43 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    hey what would elocker thirds without the actuators in need of a rebuild be worth to yall?
    think i can get 150 each?
  2. Oct 8, 2019 at 2:50 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
  3. Oct 8, 2019 at 5:28 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    that movie was trippy!
  4. Oct 8, 2019 at 5:43 AM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
  5. Oct 8, 2019 at 5:46 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  6. Oct 8, 2019 at 5:48 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Sperrunner[QUOTED] likes this.
  7. Oct 8, 2019 at 6:03 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    @Speedytech7 how bad is a clutch job on the 3RZ? Not that mine needs it, but with the rear main seal and the tranny/t case input/output seals leaking its gonna need done at some point in the near future.
  8. Oct 8, 2019 at 6:54 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Doing the clutch is simple. It's getting access to it that is a pain. Depending on how much lift you have you could drop the trans and change it with out needing ramps/jacks other than a trans jack. I've always done a clutch with the engine out so I've lucked out in that regard and don't have much knowledge in dropping the trans for a clutch job.
  9. Oct 8, 2019 at 7:04 AM
    Hooks98tacoma
    Hooks98tacoma Well-Known Member
    Georgia
    98 Tacoma 2.4
    This will be me in a couple hours
    GQ7227 likes this.
  10. Oct 8, 2019 at 7:05 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    what kind of face when parts go missing?
  11. Oct 8, 2019 at 7:08 AM
    Hooks98tacoma
    Georgia
    98 Tacoma 2.4
    CD280B56-2CD0-434F-A314-BE76FD8C4F77.jpg 03C7A8DC-B2B0-430F-87ED-257155E5CC0D.jpg
    cruiserguy and GQ7227[QUOTED] like this.
  12. Oct 8, 2019 at 7:11 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I have 2" of lift so I think I could slide it out with no issues, but I have ramps available if need be. Gotta do some research and get a part/tool price list made up and see of its gonna be worth it to do myself.
  13. Oct 8, 2019 at 7:17 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    The hardest part is getting to the top bolt of the trans/engine, need a few long extensions and a weeble wobble to get to it if you don't have a body lift.
    cruiserguy likes this.
  14. Oct 8, 2019 at 7:19 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Cant get a long wrench down from behind the valve cover? Ive got some XL ratcheting wrenches, and there is a little bit of space between the engine and firewall.
  15. Oct 8, 2019 at 7:22 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    You can it's just a lot of short moves compared to full turns with the extensions and impact drill.
    cruiserguy, FLBAdrian and Blue92 like this.
  16. Oct 8, 2019 at 7:37 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I used a 10’ socket extension after I unbolted the transmission bracket and let it lean down towards the back. I hit the top bellhousing bolt from in front of the rear axle.
    cruiserguy and se7enine[QUOTED] like this.
  17. Oct 8, 2019 at 7:41 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Seems a bit excessive considering the trans+t case is only 4ish feet long
  18. Oct 8, 2019 at 7:46 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Only if the last person to change it put the bolt back
    se7enine[QUOTED], JKO1998 and Blue92 like this.
  19. Oct 8, 2019 at 7:55 AM
    hotboatrod
    hotboatrod Well-Known Member
    Rod
    El Cajon
    1996 Tacoma 4X4 V6 auto
    2 1/2" front lift and bigger tires and wheels
    I have a ton of welding experience with a 110 mig. I've used many different brands and models. I have never used a 110 machine that had gas hooked up to it that worked in a good enough manner for me to be happy with how it worked. I'm not suggesting it's not possible though. The 110 migs need a solid good supply of up to 15 amps otherwise the machine won't work as good as it could. Other than the 20+ year old Craftsman 110 mig I gave away about 3 months ago the only machine I would consider buying is a 110V Lincoln. I have never used a 110 Miller, I don't even know if they make them.
    I've built complete car frames, boat trailers, utility trailers, heavy car frame mods, partial body panel replacement/sheet metal, exhaust, etc etc etc all with that 110 Craftsman. To my knowledge no weld I've done has ever broken or cracked.
    If you're looking for perfect looking and beautiful welds out of a 110 mig then you have a disappointing future ahead of you. If you want to build a air or water storage tank with a 110 mig then you have a big challenge ahead of you but it can be done.
    Lots of welders say flux core is trash but there are lots of idiots in the world. Studies have shown that flux core welds can be stronger than their gas weld comparisons. Skyscrapers are welded with flux core machines (strong weld and aren't affected as much by windy conditions while welding).
    110 migs set up with flux core wire are the shiznit!
  20. Oct 8, 2019 at 7:58 AM
    hotboatrod
    Rod
    El Cajon
