  1. Oct 8, 2019 at 6:16 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
  2. Oct 8, 2019 at 6:18 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I have 4 that’ll be up sometime soonish
  3. Oct 8, 2019 at 6:18 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    GQ7227 likes this.
  4. Oct 8, 2019 at 6:19 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    What
    GQ7227 likes this.
  5. Oct 8, 2019 at 6:24 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    1. That is not Aluminum Oxide. That is Sodium Bicarbobate, or Baking Soda. This is a very fine grit one time use media that is inappropriate for your purpose.
    2. Blast Tanks require a really powerful compressor. I have a 60 Gal 11 CFM unit @ 90 PSI and it only works for a few seconds.
    3. The most abrasive media you can buy is something called Steel Shot. It’s basically crushed up ball bearings. This is completely excessive for your purpose.
    4. Go buy a bag of Harbor Freight Aluminum Oxide or a Garnet media. This is what I use for Rusty cast iron and corroded steel.
    GQ7227[QUOTED] likes this.
  6. Oct 8, 2019 at 6:24 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    @Kwikvette, you are into the lifting of trucks?
    how can i get mine up another foot, maybe 2', so that i can safely work on it
    i currently have the front up on ramps and the floor jack under the passenger rear axle up maybe half a foot with the driver rear on the ground
    i need much more space for safety to work on my knees and i don't have a clue what to do :notsure:
    Kwikvette likes this.
  7. Oct 8, 2019 at 6:25 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    this is the picture google image gave to me :notsure:
    here
    the guy at harbor freight said the soda should work ok? ... the glass bead media worked much better in August but was a mess!
    i got the biggest compressor i could get that was less than $500 with 200psi
  8. Oct 8, 2019 at 6:26 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You should not be sandblasting your entire frame. Only sandblast the rusty inaccessible parts like the inside of the frame. The rest of it use a DA sander with 36 Grit. Sandblasting is very inefficient when it comes to large objects.
  9. Oct 8, 2019 at 6:27 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Huh??
  10. Oct 8, 2019 at 6:30 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Soda media is completely inappropriate for what you’re doing. Soda is for delicate jobs. While it will work Aluminum Oxide is more appropriate and reusable.
    Sperrunner likes this.
  11. Oct 8, 2019 at 6:30 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Huh?!?!?!
  12. Oct 8, 2019 at 6:31 PM
    Empty_Lord
    Dan
    Hi
  13. Oct 8, 2019 at 6:34 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Hows the tundra coming
  14. Oct 8, 2019 at 6:36 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    When it comes to air compressors, PSI is irrelevant when rating efficiency. 200 PSI means nothing. A little 5 gallon pancake compressor can hold up to 200 PSI.
    CFM is what you should be concerned about. A 11 CFM 60 Gal unit will operate the blast tank very inefficiently. People who do commercial sandblasting use construction air compressors, which do 185 CFM+. I rented one to power my blast cabinet during my horn blasting sessions.
    Kwikvette and GQ7227[QUOTED] like this.
  15. Oct 8, 2019 at 6:39 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    the entire front part does not seem to really need it, (i have a pic to post) just under the bottom edges that the dealer undercoating and most of the inaccessible rear section
    but i have to get rid of that nasty Toyota paint that is pure garbage and will not protect anything from road chemicals from what i have been learning
    and I have not figured out how to sandblast inside frame on the bottom?
    will the DA sander with 36 grit get it all down to naked steel to use the afterblast zinc phosphoric wash before the primer?
  16. Oct 8, 2019 at 6:41 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    the higher CFM they (harbor freights) had was $200 more, a wheelbarrow one and heavy as heck! like 300lbs i think
    and required gas and oil
    i am in too far over my head with all this :(
    ... had enough trouble trying to figure out how to properly attach the air hoses, had to make 2 trips back to the store that is a bit over 5 miles away
  17. Oct 8, 2019 at 6:44 PM
    Empty_Lord
    Dan
    rear window is in, bedliner is done. i should be able to pick it up friday. he just has to paint the new grill
    i didnt get to make it this morning so i didnt get to see it. damn
    Sperrunner[QUOTED] likes this.
  18. Oct 8, 2019 at 6:49 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
  19. Oct 8, 2019 at 6:54 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
  20. Oct 8, 2019 at 6:55 PM
    eon_blue
    Azusa, CA
    So much for seeing Joker tonight, got stuck at work for an extra 2 hours
    had tickets for 6pm but just clocked out
    Kwikvette and Sperrunner like this.
