  1. Oct 15, 2019 at 7:53 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    That could be possible. Not sure I'll be ready to do that til post Thanksgiving
  2. Oct 15, 2019 at 7:53 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I have 3 8.4” axles and a 7.5”
  3. Oct 15, 2019 at 7:56 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    his truck is a elocker.
    no rush. his has time. the things just rotting bad. im just curious because my spare housing is just as rusty as his.
    are you going to be using the axles too?
  4. Oct 15, 2019 at 7:57 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Just modify the 8.4” lol
  5. Oct 15, 2019 at 8:00 PM
    Empty_Lord
    Dan
    that involves welding. and i'd rather just be simple swap housing out and roll with it.
    i might take you up on one later though when the time comes for me to make the other frame "driveable"
  6. Oct 15, 2019 at 8:02 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I have 1 complete 8” and one bare housing. Also like 6 spare 8.4” axle shafts
  7. Oct 15, 2019 at 8:04 PM
    Empty_Lord
    Dan
    i have 2 8.4" diffs.. one with LSD.
    3 Elocker Diffs
    1 elocker housing with a 4.10 ratio gear thats in good shape.
    3 front diffs all 4.10 gears..
    housings are what i lack. but i need to offload these diffs. theyre all worn out. i just want to keep one of each
  8. Oct 15, 2019 at 8:06 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I need a manual hub front diff.
  9. Oct 15, 2019 at 8:06 PM
    Empty_Lord
    Dan
    that i do not have sadly.
    Sperrunner[QUOTED] likes this.
  10. Oct 15, 2019 at 8:09 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Damn
  11. Oct 15, 2019 at 8:10 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I was gunna trade you a axle
  12. Oct 15, 2019 at 8:12 PM
    Empty_Lord
    Dan
    lol. all mine are ADD tubed.
  13. Oct 15, 2019 at 8:13 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Ill just buy @Tour991 manual stuff
    Tour991 likes this.
  14. Oct 15, 2019 at 8:21 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Don't buy Toyota stuff, otherwise you'll be that guy that said he was going to buy a ram coal roller and it never happening ..cause your monies went to yota parts.
    Running Board Man likes this.
  15. Oct 15, 2019 at 8:22 PM
    Wulf
    rock raisin
    No sir, the diamond housing is setup to use Dana 44 front spindles/brakes/hubs and has FF stub shafts between the diff and the hubs
  16. Oct 15, 2019 at 8:23 PM
    Empty_Lord
    Dan
    i may need to jump on the shafts too then. lol i have a bad issue of hoarding... just PM me whenever your done with what you need.
    Wulf[QUOTED] likes this.
  17. Oct 15, 2019 at 8:24 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Actually be that guy that didn't get the roll coaller.....:D
  18. Oct 15, 2019 at 8:26 PM
    Wulf
    rock raisin
    It's a 2000 housing with ABS. Was told it had 100k mi with 50k on the fluid and it came out still greenish so if believe it
  19. Oct 15, 2019 at 8:26 PM
    Wulf
    rock raisin
    Or you can be me, spend money on both, and have none left over :homer:
    Kwikvette[QUOTED] likes this.
  20. Oct 15, 2019 at 8:27 PM
    Wulf
    rock raisin
    Third is the same, you need the manual axle tube
