  1. Oct 21, 2019 at 3:54 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Yeah you should probably work on them aero dynamics
    Running Board Man likes this.
  2. Oct 21, 2019 at 3:55 PM
    eon_blue
    Azusa, CA
    whatchu talking about, I'm 5'11 175lbs
    Lean and mean baby :wink:
    The beer will probably catch up to me soon
  3. Oct 21, 2019 at 3:55 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Pffft I'm pretty much there too sans skids, roof rack with LED lights, and 1" smaller E rated tires.
    Gimme your supercharger; will save you gas money in the long run o_O
    I didn't know Ryan sent you nudes back
  4. Oct 21, 2019 at 3:56 PM
    eon_blue
    Azusa, CA
    Heavy 33s really kills it the most I think, weight right at the wheels has a big effect on mpgs and performance
  5. Oct 21, 2019 at 3:56 PM
    ToyotaDriver
    ToyotaDriver Well-Known Member
    Idaho
    ‘04 V6 5 Speed SR5 TRD downward spiraling project, ‘15 V6 6speed TRD daily
    The 1st Gen: All pro 3” lift (650 lbs coils, expedition rears with bilstiens),Timbren rear bumpstops, ubolt flip, diff drop, carrier bearing drop, 33’s on beadlocks ,ARB Bumper, winch, hand throttle, ARE canopy, roof bars, poly bushings all around minus the body mounts. The 2nd Gen: Leveling kit, roll up tonneau cover. 265/75/16’s
    Anyone ever tried to recreate interior panels with fiberglass? I am in the parts gathering phase of a dual battery/accessory wiring project. I’ve decided to use rocker switches from otrattw331B2353-77EE-4778-9786-353F2B813841.jpg
    I want to mount them in the lower dash below the ash tray in my ‘04. I’ve decided that I’m going to use 8 receptacles which will be just about as wide as the factory panel as pictured. The setup show has 6, I plan to add two more. There are a few reasons I want to recreate this piece! First, they’re expensive if you f*** it up, second, the rocker switch panel won’t fit flush on this piece and I want to make it look as clean and factory as possible. Any suggestions?
  6. Oct 21, 2019 at 3:56 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I run my E tires at 40psi
  7. Oct 21, 2019 at 3:56 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Im the same as you. But i look bigger
  8. Oct 21, 2019 at 3:57 PM
    eon_blue
    Azusa, CA
    #fatter
    Kwikvette likes this.
  9. Oct 21, 2019 at 3:58 PM
    eon_blue
    Azusa, CA
    ooof I couldn't do that, they ride rough enough as it is lol. I'll run them at 35psi at the most...usually 32
  10. Oct 21, 2019 at 3:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Shots fired
    Weird, plenty soft riding for me
  11. Oct 21, 2019 at 3:59 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    If you can wait i might have another one of those panels u can cut up
    ToyotaDriver[QUOTED] likes this.
  12. Oct 21, 2019 at 4:00 PM
    ToyotaDriver
    Idaho
    I have nothing but time!
  13. Oct 21, 2019 at 4:00 PM
    eon_blue
    Azusa, CA
    What spring rating do you have up front? My 600# ones probably don't help without a front bumper
  14. Oct 21, 2019 at 4:00 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I like to call it the perfect dad bod
  15. Oct 21, 2019 at 4:01 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I think mine are 600?
    Whatever Fox 2.5's come with from the factory, with preload to get me to 2" of height.
  16. Oct 21, 2019 at 4:02 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Not everyone can be a fiery latino :wink:
    Sperrunner[QUOTED] likes this.
  17. Oct 21, 2019 at 4:03 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    You need a National Luna Dual Battery kit?
  18. Oct 21, 2019 at 4:04 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I got 2 boxs on interior trim. Idk what i have
  19. Oct 21, 2019 at 4:05 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Wasnt I suppose to see if i had a part for someone in here.
  20. Oct 21, 2019 at 4:06 PM
    eon_blue
    Azusa, CA
    hmm maybe, I'm not sure what those come with
