  1. Oct 26, 2019 at 9:13 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    This cat looks like it doesn't have time for your crap hahahha:rofl::rofl::cool:
    Running Board Man likes this.
  2. Oct 26, 2019 at 9:16 AM
    cruiserguy
    Elijah
    SEKS
    Yeah that force always pushing against the pinion bearing of the diff and output bearing of the t-case. Granted if runnerman grease was squeezing out of the splines than the pressure wasn't staying trapped in the grease cavity of the shaft. So he got lucky there. But yes you can cause those bearings to fail prematurely.
    But you can always just take a little 6mm socket and remove the zerk and drive over a curb to push that excess pressure out if it's a concern and you want to be safe
  3. Oct 26, 2019 at 9:19 AM
    cruiserguy
    Elijah
    SEKS
    Greasing the zerks on the driveshaft is part of proper driveshaft maintenance
    JKO1998 and Running Board Man like this.
  4. Oct 26, 2019 at 9:29 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Dude, PG&E just stated they will be shutting off power where I'm at as well as south of me.
    Scheduled to go off at 10pm and could last up until Monday.
    Running Board Man and cruiserguy like this.
  5. Oct 26, 2019 at 9:30 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    No working for you
  6. Oct 26, 2019 at 9:31 AM
    eon_blue
    Azusa, CA
    I got a few of those blankets to do exactly that with (work on my truck) but after a few uses they start shedding like crazy...I ended up looking like I was growing patches of dark black hair all over me after I use them lol. It's not so bad if you flip them over though.
    Lately we've had so many cardboard boxes in the house from baby stuff that I've started cutting up those to use... works pretty good though not as soft as a blanket.
    cruiserguy likes this.
  7. Oct 26, 2019 at 9:32 AM
    eon_blue
    Azusa, CA
    Damn that sucks...I'll have to check with my mom in Marina and see if she's affected
  8. Oct 26, 2019 at 9:36 AM
    JKO1998
    Utah
    Has anyone here ever used the playing cards to protect tires from getting paint on them? How’d it go?
  9. Oct 26, 2019 at 9:37 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    This is the tricky part that you can't skip that really makes it all work. You don't want pressure to build up in the cylinder to put unnatural stress on the joints. I like the mini guns because I get a better feel for when they start to get resistance from back pressure. That some of the guesswork out of knowing when you are about to cross the threshold for injecting too much grease.
    cruiserguy[QUOTED] likes this.
  10. Oct 26, 2019 at 9:38 AM
    eon_blue
    Azusa, CA
    I didn't do that, but rather than waste a deck of playing cards I cut some paper bags up into squares and used those. Worked well
  11. Oct 26, 2019 at 9:39 AM
    JKO1998
    Utah
    Hmmm alright
  12. Oct 26, 2019 at 9:39 AM
    eon_blue
    Azusa, CA
    If it's windy outside you'll get very frustrated lol.
  13. Oct 26, 2019 at 9:39 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Come hang here lol
  14. Oct 26, 2019 at 9:40 AM
    JKO1998
    Utah
    Laughs in cracked garage*
  15. Oct 26, 2019 at 9:46 AM
    CS_AR
    I've used index cards with a slight trim to match the wheel diameter. Once you make a pattern card with the right curve, then cut the others to match and tape them all together in a circle around the wheel.
    If you really want to make sure that no over spray gets on any part of the tire, there is some kitchen drawer liner paper that you can get at Walmart with a mild adhesive backing. It sticks to the surface and won't move while you are painting. It works way better than using paper and tape to wrap something before painting.
  16. Oct 26, 2019 at 9:57 AM
    cruiserguy
    Elijah
    SEKS
    I'm seeing in the news the wildfires are getting REAL bad. Sucks bad for you guys man
    How does shutting the power off help with getting the fires contained and eliminated? Anyone know? I'm sure someone has heard or knows
  17. Oct 26, 2019 at 9:58 AM
    cruiserguy
    Elijah
    SEKS
    I prefer the nice big cardboard boxes as well. Makes it a lot easier for the sliding under :D
    eon_blue[QUOTED] likes this.
  18. Oct 26, 2019 at 9:58 AM
    eon_blue
    Azusa, CA
    From what I've heard on the radio they can't prove that the shut offs have prevented any fires so they can't say for sure (can't prove something that never happened). But they expect the shutoffs to continue every fire season for at least the next decade until the power lines and equipment are all upgraded
  19. Oct 26, 2019 at 10:00 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Naw, she's in the other direction.
    South would be Chualar, Soledad, etc.
    Dude, I get out at 8..9...10? It'll be midnight if I get to your place, and I got work tomorrow again :rofl:
    Unless I could get those Limited Seats, @Empty_Lord has a bounty on them o_O
  20. Oct 26, 2019 at 10:02 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Going to the junkyard, going to snag me a Grand Vitara alternator
