  1. Oct 26, 2019 at 10:06 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Towed the 6.0l up the street to the shop. The new truck didn't seem to notice it back there
  2. Oct 26, 2019 at 10:12 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    What will that work in?
    Running Board Man likes this.
  3. Oct 26, 2019 at 10:13 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I’ll probably just end painting them before mounting
    CS_AR[QUOTED] likes this.
  4. Oct 26, 2019 at 10:14 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    What are you using for paint?
  5. Oct 26, 2019 at 10:16 AM
    JKO1998
    Utah
    No idea yet
  6. Oct 26, 2019 at 10:27 AM
    cruiserguy
    Elijah
    SEKS
    So I just looked into this a little. That's crazy man and I'd be livid just like the residents there. These fires are starting from power lines that are breaking??? Wtf is this 1970s power line technology?
    I truly didn't know that wind/breeze snapped power lines is what was causing these fires. Why is it happening there and not other states that have more wind gusts? Are the power lines really that poor of shape/quality?
  7. Oct 26, 2019 at 10:35 AM
    eon_blue
    Azusa, CA
    Yup it's a shitshow really...the power equipment has been outdated and in many cases in disrepair for a long time and the power company (PG&E in Northern CA) hasn't done anything about it. Well, until after the huge fires last year that killed a lot of people. Now their solution is to shut off the power during risky weather and spend the next decade rebuilding/upgrading their equipment.
    Edison is the power company in SoCal and while we have had some big fires of our own, I don't think many have been attributed to faulty power equipment. Usually its some arsonist freak or dumbass tossing a lit cigarette. But Edison is worried now too now that PG&E has taken so much heat up north, and they are shutting off power down here too in order to prevent fires. Not in same magnitude that it's happening up north though.
    Just a good observation of corporate greed and valuing money over common sense and safety. These companies have gotten so big that they can't fail and they know we can't go without them.
  8. Oct 26, 2019 at 10:39 AM
    CS_AR
    We had decent luck using the Duplicolor system. The trick to having the finish harden like a powder coat job is to heat the wheel after painting it completely cures before mounting a tire or driving on a road where you can pick up gravel chips. We learned this by noticing the front wheels were chip resistant on a gravel road but not the rear. The heat from the front disc brakes allowed the front wheels to cure and harden better than the rear. The rear eventually cured but not after some chips.
    Then we painted another set of wheels with the same paint and baked each wheel in the oven to cure. Those wheels turned out to be the best of all. Here's an article about baking wheels to speed the curing process.
    https://forums.nasioc.com/forums/showthread.php?t=1475706
    cruiserguy likes this.
  9. Oct 26, 2019 at 10:41 AM
    JKO1998
    Utah
    these are just going on the 99, doesn’t need any fancy process or paint
  10. Oct 26, 2019 at 10:59 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
  11. Oct 26, 2019 at 11:05 AM
    CS_AR
    @cruiserguy
    Here's one of those suspension "black art" tricks that I learned from guys who are into autox and need their suspensions to be tight and completely predictable after a refresh.
    Pick out a grease that you like that is compatible with other greases, then inject it inside the boot from the top using a grease needle. You don't want to damage the boot or compromise the seal by changing and adding more grease to a joint. Then once you start getting the new grease inside the boot, start working in the new grease around the ball and socket until it rotates and moves around until it feels smooth like butter. You can feel the amount grease is in the boot for when it is compressed after installation to avoid having to much. Its a new joint with no wear on the ball or socket. This just helps make sure grease is evenly applied and the suspension ball joints move with the least amount of resistance. After I started doing this, new suspensions feel quick and responsive immediately after installation while having a new and tight ball and socket. I think this helps ball joints last since it provides more protection than just installing the replacement joint without any conditioning.
  12. Oct 26, 2019 at 11:29 AM
    cruiserguy
    Elijah
    SEKS
    I have read or heard, no actual experience, that the issue with that greasing method is that the new grease can't get to where it is functional and helping lubricate where needed. This prolly depends on the component and setup/design as well. I've heard that this is why Toyota did not use greasable ball joints on these Tacomas. But it's just hearsay, somewhat logical hearsay but I really don't know. I would imagine on TREs that that method should absolutely work as it's not a load bearing joint.
  13. Oct 26, 2019 at 11:34 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Wolf piss will keep coons away.
  14. Oct 26, 2019 at 12:05 PM
    JKO1998
    Utah
  15. Oct 26, 2019 at 12:13 PM
    JKO1998
    Utah
    When someone asks why there’s scratches on the top
    Sperrunner, cruiserguy and CS_AR like this.
  16. Oct 26, 2019 at 12:20 PM
    eon_blue
    Azusa, CA
    At the smog shop... wish me luck
  17. Oct 26, 2019 at 12:41 PM
    eon_blue
    Azusa, CA
    Boom..in and out in 10 minutes, passed with flying colors. 2 more worry free years lol
  18. Oct 26, 2019 at 12:41 PM
    cruiserguy
    Elijah
    SEKS
    Was this the star one?
    eon_blue[QUOTED] likes this.
  19. Oct 26, 2019 at 12:42 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Buy a tesla. No smog
  20. Oct 26, 2019 at 12:44 PM
    eon_blue
    Azusa, CA
    I guess so...was a star rated facility and they told me they sent the into off to the DMV. Better have been lol. I was due for the star test this year.
    I could pay off smog testers with cash for the rest of my life if I needed to for 1/4 what a Tesla would cost me
    cruiserguy[QUOTED] likes this.
