  1. Dec 2, 2019 at 1:58 PM
    eon_blue
    Azusa, CA
    Since you have a manual trans you don't have a trans temp reading anyway, only the autos have that feature. We don't need one anyhow since manuals don't tend to overheat like autos easily can.
    I use a $20 OBDII dongle and the Torque app as well, works great. Can drain your phone battery pretty quick if it's older though, just keep it plugged in.
    I use mine to monitor fuel trims, coolant temp, intake temp, battery voltage, ignition timing and scan for codes all on one screen.
    Das it mang[QUOTED] likes this.
  2. Dec 2, 2019 at 1:59 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    yep, ended up going with (I had room on my panel for two separate solutions) -
    https://smile.amazon.com/gp/product/B07QZZP2PT
    and this -
    https://smile.amazon.com/gp/product/B01CZ2ZXKM/
    (the readout is really nice on this - none of that cheap super bright eye blinding LED crap)
    EDIT: Speaking of OTRATTW, they have it much cheaper -
    https://www.otrattw.net/Blue-Sea-Mini-OLED-DC-Voltmeter-1733.html
    For a switch mount, they have (without the voltmeter):
    https://www.otrattw.net/Blue-Sea-Fast-Charge-Dual-USB-Charger-Switch-Mount-1039b.html
  3. Dec 2, 2019 at 2:03 PM
    eon_blue
    Azusa, CA
    Are you able to use the Torque app to monitor oil pressure on your Taco? That's one reading it seems I can't get on mine, figured it just wasn't available on our trucks.
  4. Dec 2, 2019 at 2:03 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Got confirmation my wheels are on the way as is my new seat for the Taco.
  5. Dec 2, 2019 at 2:04 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    It is not available on our trucks. The "sender" for the dash light is just a on/off switch that triggers when the pressure is too low
  6. Dec 2, 2019 at 2:04 PM
    Wulf
    rock raisin
    what seat did you go with?
  7. Dec 2, 2019 at 2:04 PM
    Area51Runner
    too low = NON EXISTENT
    :rofl:
  8. Dec 2, 2019 at 2:05 PM
    Speedytech7
    10 psi. So if the light is on you in big trouble haha
    Running Board Man and eon_blue like this.
  9. Dec 2, 2019 at 2:05 PM
    eon_blue
    Azusa, CA
    yeah the red oil lantern of death, I wish I could monitor it without relying on seeing a dash light that pretty much means 'you're fucked' lol.
  10. Dec 2, 2019 at 2:06 PM
    Speedytech7
    MasterCraft Rubicon with lumbar and heater
  11. Dec 2, 2019 at 2:06 PM
    Wulf
    rock raisin
    You can add in a tee where the factory one is and add a sending unit for your own standalone gauge
  12. Dec 2, 2019 at 2:07 PM
    eon_blue
    Azusa, CA
    Might do that one of these days, with the boost and AFR gauge though I don't really want yet another gauge on my dash lol. Would probably put it above the steering wheel or something.
  13. Dec 2, 2019 at 2:07 PM
    Speedytech7
    Crown Vic police interceptor center console. I'm gonna have gauges out the ass
  14. Dec 2, 2019 at 2:09 PM
    eon_blue
    Azusa, CA
    I'll probably get a combo boost/afr gauge one of these days to consolidate those 2, the old TRD boost one periodically goes on the fritz...think the stepper motor in it is going out.
  15. Dec 2, 2019 at 2:10 PM
    Area51Runner
    i thought you mounted those two on the a pillar
  16. Dec 2, 2019 at 2:11 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    as u can tell this is my first manual, pardon the ignorance haha. So in reality, I may be skeptical running the 5 lug in 3rd because I'm at nearly 4k rpms when in a climb; but that's just my auto transmission mentality? obv I dump a gear after the climb, but ya. And okay looks like you guys just directed me the right direction! thank you so much! saved me half the cost I appreciated it!
    eon_blue[QUOTED] likes this.
  17. Dec 2, 2019 at 2:12 PM
    eon_blue
    Azusa, CA
    Boost is on the A pillar, AFR is right next to it on the dash. But the A pillar one sticks out and covers the corner of the dash anyhow
    They do make an A pillar gauge pod that will hold 2 gauges, but you have to remove your grab handle to put it on. I can't live without the grab handle, I use that way too much when wheeling. I would probably reach for the gauge pods and rip them off by accident
  18. Dec 2, 2019 at 2:12 PM
    Das it mang
    Az
    1996 T100 SR5 MT
  19. Dec 2, 2019 at 2:13 PM
    Area51Runner
    ouch! Yeah that would be bad.
  20. Dec 2, 2019 at 2:13 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Will be going this route then, thank you!
