  1. Dec 10, 2019 at 12:15 PM
    Wulf
    rock raisin
    with 5.29s the truck feels like it has some power again
    Das it mang likes this.
  2. Dec 10, 2019 at 12:16 PM
    Wulf
    rock raisin
    I need a head unit that has bluetooth audio and hands free calling for the Taco and the Lexus. Debating about just going with a cheap traditional din or spending more for a touchscreen headunit... thinking about going cheap since I don't really need fancy features in either
  3. Dec 10, 2019 at 12:17 PM
    Wulf
    rock raisin
    the lexus currently has the factory HU with a 3.5mm cord soldered to the L/R traces on its board. that works but is inconvenient
  4. Dec 10, 2019 at 12:32 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    that actually doesn't sounds too bad on paper, but never seen u drive it so I can't say. Glad to hear u got ur gears done, what was the main difference with upgraded gears? cycle through gears faster (like they run thru their rpms in each gear faster), and more pep at RPM's from prior? Never re-geared so this will be my first with the taco
  5. Dec 10, 2019 at 12:34 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    TBH I cant even see shit on my headunit and i'm happy I went with a burner pioneer single din bc I did consider a fancy one. I would go with a single din, but its up to u. I always refer to my phone mounted to my windshield for everything. The clock on the taco is blocked by my steering wheel, and can only read the headunit if I stare for a min, or it's nighttime; even with the colors of the unit set to a bright white
  6. Dec 10, 2019 at 12:58 PM
    Wulf
    rock raisin
    Thinking about picking up this one for the Lexus and possibly the Tacoma if I like it
    $80 for the HU plus install kits seems solid
    https://www.crutchfield.com/p_130MS322BT/Pioneer-MVH-S322BT.html
    Das it mang[QUOTED] likes this.
  7. Dec 10, 2019 at 1:08 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Solid scoop right there. super easy to install, just make sure u crimp everything up nicely. I hated going back to fix mine; I tried to install during the Az summer at 110 degrees and got too hot and electric taped the connections together at first from frustration :rofl::rofl: But, the pioneer units have served me well. Was able to set up the crossover nicely with the stock speakers and tbh it sounds better than the infinity speakers that came stock in my old ram prior
    Wulf[QUOTED] likes this.
  8. Dec 10, 2019 at 1:10 PM
    Wulf
    rock raisin
    Big difference on the trail, for sure.
    On the street just imagine only having your current 2,3, and 4th to use.
    With the bigger tires 5th was pretty much unusable and starting in 1st required a abuse of the clutch
  9. Dec 10, 2019 at 1:17 PM
    Wulf
    rock raisin
    Going back to fix anything is annoying!
  10. Dec 10, 2019 at 1:32 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    what even happens in a situation like that? legally/ insurance shit wise lol. That sucks tho man, just remember everything happens for a reason
    01x4[QUOTED] likes this.
  11. Dec 10, 2019 at 1:33 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    That makes sense, do mph shift points change with a regear? If the regear is accurate enough you can still do 80 85 on the highways right?
  12. Dec 10, 2019 at 1:37 PM
    Wulf
    rock raisin
    uhhh I haven't thought about it enough to be able to tell you... with 5.29s the shift points are a little more aggressive than I'm used to because of how deep the gears are in comparison
    But yes, I should be able to do 80 albeit at 3500~ RPM or so. I haven't taken the truck past 65. I need a better wheel and tire setup to be comfortable with that
  13. Dec 10, 2019 at 2:20 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Hmm sweet that isn't too high of RPM's in hindsight of how high the gearing is. I just have the I10/i17 here in az which the speed limit is 75 so everyone goes 85, and don't wanna lose that ability with a regear. Thanks for the info, sorry to pick your brain lol
  14. Dec 10, 2019 at 2:28 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Damn that's crazy, glad to hear he's okay. that would be a great junkyard find then for parts since it was about to be sold and was in good condition likely
  15. Dec 10, 2019 at 2:36 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    6 k overall??? gawdamn that's horrible to lose a taco so young if true. Keep up tho, another will pop up
  16. Dec 10, 2019 at 2:47 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Guess it was a sign to not leave the 01 yet haha
  17. Dec 10, 2019 at 3:19 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Shit, I passed OChem
  18. Dec 10, 2019 at 3:20 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Smart bastard
  19. Dec 10, 2019 at 3:21 PM
    eon_blue
    Azusa, CA
    cruiserguy likes this.
  20. Dec 10, 2019 at 3:22 PM
    JKO1998
    Utah
    To be fair, I basically memorized the last 3 finals, I didn’t actually learn anything
