  1. Dec 14, 2019 at 2:35 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    CS_AR likes this.
  2. Dec 14, 2019 at 2:38 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    what are these for?
  3. Dec 14, 2019 at 2:38 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    If I understand your scanner readings, the ECU is reducing the fuel to air ratio by 7%?
    CS_AR[QUOTED] likes this.
  4. Dec 14, 2019 at 2:38 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oof, that hurt.
    Area51Runner[QUOTED] likes this.
  5. Dec 14, 2019 at 2:40 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    The Taco and the Merc ran fine. Checkmate.
    Kwikvette likes this.
  6. Dec 14, 2019 at 2:40 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Queer
    what road and Kwikvette like this.
  7. Dec 14, 2019 at 2:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'd say that's 2-1; Tyler's winning
  8. Dec 14, 2019 at 2:43 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    What about his civic
    Area51Runner and cruiserguy like this.
  9. Dec 14, 2019 at 2:44 PM
    cruiserguy
    Elijah
    SEKS
    Jumped in with perfect timing, just like a true friend :rofl::D
    Area51Runner likes this.
  10. Dec 14, 2019 at 2:44 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Based on this explanation, it looks like I'm ok. I may need to check the readings after a good drive.
    STFT (short term fuel trim) is the instantaneous response of the ECU to reduce or add fuel to maintain an ideal combustion mixture. It depends on the response of the O2 sensor. If the O2 sensor says the exhaust is too rich (too much fuel) the ECU will reduce pulse width of injectors to subtract fuel. Thus STFT will read negative. If exhaust is lean (too much oxygen), it will add fuel and STFT will become positive. Ideally STFT should be close to 0. But it fluctuates as you drive the car.
    LTFT (long term fuel trim) should not change instantly, it is a learned response that happens over time. If the STFT stays consistently negative or positive for a long period of time. That will show up in the LTFT.
    If the LTFT is negative, it means the ECU has been reducing fuel to maintain an ideal fuel mix. Which basically means the car is running rich. If LTFT is positive, it means the ECU is adding fuel which is an indication that the car is running lean. Normally LTFT should be between -10 to +10 percent. But the closer it is to zero, the more ideal the combustion mixture.
  11. Dec 14, 2019 at 2:45 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yeah. I now own a 1986 Nissan 300zx Z31. Zane is a very very bad influence.
    cruiserguy and CS_AR[QUOTED] like this.
  12. Dec 14, 2019 at 2:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  13. Dec 14, 2019 at 2:47 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Also ran fine. Sold it at a profit. I’ve sold all my vehicles at a profit. I haven’t lost money on a single one.
  14. Dec 14, 2019 at 2:47 PM
    CS_AR
    Nissan help make you mentally strong. :transformer:
  15. Dec 14, 2019 at 2:48 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    (cause Tyler clearly won)
  16. Dec 14, 2019 at 2:49 PM
    cruiserguy
    Elijah
    SEKS
    That made more sense than a lot of the shite I've read from 'experts'
  17. Dec 14, 2019 at 3:00 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Yet :boink:
  18. Dec 14, 2019 at 3:08 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    $500 was a steal on that Z31. The next cheapest one on CL is a few grand.
  19. Dec 14, 2019 at 3:08 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    100xNylon Fender Wheel Flare Moulding Clips For Toyota 90904-67036
    is this by chance by blue92 thought i was trying to remove when he recommended that pry tool :notsure:
  20. Dec 14, 2019 at 3:08 PM
    Area51Runner
    Could've been worse...
