  1. Dec 26, 2019 at 7:13 PM
    eon_blue
    Azusa, CA
    Why do you use an impact for a tire rotation...have fun replacing studs
  2. Dec 26, 2019 at 7:13 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Only to remove thE nuts
  3. Dec 26, 2019 at 7:14 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I prefer it
    01x4[QUOTED] likes this.
  4. Dec 26, 2019 at 7:14 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Tyler uses it to put on tires
  5. Dec 26, 2019 at 7:15 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Thats actually a job I am always more than willing to pay someone else to do. Mainly cause I only have 2 jackstands that I trust haha. Other 2 are the elcheapos from the autozone store brand. Super tiny and I need an entire tree stump to put them on so they can reach my frame haha.
    Area51Runner and Sperrunner like this.
  6. Dec 26, 2019 at 7:17 PM
    Daddo
    Daddo Well-Known Member
    Paul
    2004 Doublecab Tacoma 4wd
    Full Total Chaos Long Travel
    and your definition of sophisticated is?
  7. Dec 26, 2019 at 7:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    What auto?
    The truck you don't drive or the van that doesn't run? :boink:
  8. Dec 26, 2019 at 7:18 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    RC car
    Area51Runner likes this.
  9. Dec 26, 2019 at 7:19 PM
    eon_blue
    Azusa, CA
    I do mine usually even though I get free ones from Americas Tire for buying my tires there...they're just always packed and a rotation usually involves waiting half the day.
    I just put one front corner on jack stands, remove that tire and lift the rear diff and remove the opposite corner tire...swap then repeat for the next two.
    Wish my spare had a matching wheel so I could do a 5 tire rotation though
  10. Dec 26, 2019 at 7:20 PM
    eon_blue
    Azusa, CA
  11. Dec 26, 2019 at 7:21 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    So you swap sides the tires are on? I was always taught to keep them on the same side and just swap front to rear. :notsure:
    Kwikvette likes this.
  12. Dec 26, 2019 at 7:22 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Seadoos*
    eon_blue[QUOTED] likes this.
  13. Dec 26, 2019 at 7:22 PM
    eon_blue
    Azusa, CA
    I always do an X rotation but some people do it your way too, IDK I've never had any issues with it.
    Blue92[QUOTED] likes this.
  14. Dec 26, 2019 at 7:23 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I dunno.
    I was just using a big word to make me sound smarter than I actually am :homer:
  15. Dec 26, 2019 at 7:25 PM
    eon_blue
    Azusa, CA
    I just looked it up and it says on Google for 'non directional' tires to use the cross X method, if they're directional its better to keep them on the same side.
  16. Dec 26, 2019 at 7:26 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I thought it had something to do with radial vs bias ply tires. Radial= rotate like an X, Bias = keep same side. Again, probably doesnt matter though. Especially in your case since 35000 miles on your tires is about all you'll see Id assume.
  17. Dec 26, 2019 at 7:28 PM
    eon_blue
    Azusa, CA
    Ha yeah if I'm lucky. They usually get replaced due to chunking before tread wear. At least with my past KO2s.
  18. Dec 26, 2019 at 7:30 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    WHAT’RE YOU DOING STEP-BRO?
  19. Dec 26, 2019 at 7:40 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    No reason not to invest in a good set (4 or more) if you're going to be doing any kind of DIY work. Especially if it's lifted. I ended up ordering a couple of sets of these prior to the OME kit.
    Will be honest though, considering a couple of these HF jackstands for the height factor (up to 30"). Those torin 6 ton stands still work but they are damn near on the max setting (up to 23")
    01x4 and Sperrunner like this.
  20. Dec 26, 2019 at 7:42 PM
    eon_blue
    Azusa, CA
    I like the HF 6 ton stands, I have two that I use most of the time. I have a few Craftsman 3 ton stands as well that work well for the rear axle but not tall enough to use up front.
    Area51Runner[QUOTED] likes this.
