  1. Dec 30, 2019 at 9:47 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    cruiserguy[QUOTED] likes this.
  2. Dec 30, 2019 at 9:47 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Because every manual Nissan RWD car came with a CD009 since like 2003 they're super easy to come by and swap kits are on the rise for most any platform that makes power. I've even seen them for LS instead of the shitty shifting Tremec T5 and T56. I've got two from wrecks that a friend pulled for me and him to put in our Z's. But I don't really plan to make more than 450-500hp so I dunno if I'll bother just for the extra gear.
    Running Board Man likes this.
  3. Dec 30, 2019 at 9:48 PM
    Empty_Lord
    Dan
    lotus has been using the 2gr for a while now and with a blower and different cams theyre making over 400hp reliably. even with the dinky stock rods
  4. Dec 30, 2019 at 9:49 PM
    Empty_Lord
    Dan
    that extra gear can really make it more enjoyable to drive on long distance trips if its geared like id think a 6 speed would be
  5. Dec 30, 2019 at 9:50 PM
    Empty_Lord
    Dan
    the fe is the one in the lotus. the FKS is whats in the new tacoma and all the new toyotas as of the last few years
  6. Dec 30, 2019 at 9:50 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Sure sounded like a long ass power band there but I don't know that stuff like you guys do. I know I love the sound though and just how precision and perfect and true stuff has to be to be able to run at those types of rpm omg:drool:
  7. Dec 30, 2019 at 9:50 PM
    Speedytech7
    Yeah, you can make them work like a clutchless. The sequential kits face the gear set for shifting strength, but it helps if you use a strain gauge on the shift handle to let the ECU pull timing and ease the shift, makes it smoother under super high horsepower shifts.
  8. Dec 30, 2019 at 9:52 PM
    Speedytech7
    2GR-FE vs 2GR-FKS boi
  9. Dec 30, 2019 at 9:52 PM
    Empty_Lord
    Dan
    stock cams and springs 7400 rpm will make power and seems safe. (ive been running a 7300 rpm redline on my avalon for over a year now). with valve springs and cams 8k is easy to achieve with a stock bottom end. The VVTI makes the power band very broad which is beautiful for drive ability. being able to phase the cams allows the peak power band to move with engine load/demand..
  10. Dec 30, 2019 at 9:52 PM
    Empty_Lord
    Dan
    someone gets it.
  11. Dec 30, 2019 at 9:54 PM
    Empty_Lord
    Dan
    i dont like the new camrys 4 cylinder engine name...
    A25A-FKS
  12. Dec 30, 2019 at 9:54 PM
    cruiserguy
    Elijah
    SEKS
    8k rpm in a V6 and in a 'grandpa' car.... Perfect sleeper. I'll have one some day
  13. Dec 30, 2019 at 9:54 PM
    Wulf
    rock raisin
    Aska fucks
    Empty_Lord[QUOTED] likes this.
  14. Dec 30, 2019 at 9:55 PM
    Empty_Lord
    Dan
    then theres the twin turbo 3.5.. totally different block and everything the v35a.. 416 hp 440 ft lbs bb! tundras next gen power plant too by the sounds of it
  15. Dec 30, 2019 at 9:57 PM
    Wulf
    rock raisin
  16. Dec 30, 2019 at 9:58 PM
    Empty_Lord
    Dan
    its a good engine. toyota and nissan are the 2 best v6s you can get. that i stand by. fucking ecoboost shitbox engine pissed me off with the water pumps... and the internals are almost a copy of the 1gr in the 2nd gen tacos.. i mean seriously, look!
    ford
    Toyota 4.0
  17. Dec 30, 2019 at 9:59 PM
    Empty_Lord
    Dan
    oh and the v35a achieves 41% combustion efficiency, tis amazing
    cruiserguy and Running Board Man like this.
  18. Dec 30, 2019 at 10:01 PM
    Speedytech7
    The Jerico boxes are the old fashioned way of doing a clutchless setup and are probably fine to about 350-400hp, but they're designed for light circuit racing typically. They're not for high powered applications under full stress like drag racing. Nowadays we use hardened gearsets and use faceplated gear synchros still but in the pull handle for the shifter there is a strain gauge, as soon as you put the pulling or pushing stress on the handle for a shift it tells the ECU in a split second "hey this asshole is gonna shift" that way you dont have to mash the clutch or let up on the gas still and the ECU will either pull timing to ease the stress momentarily (you wouldnt feel it and you wouldn't lose your boost) or it will ignition cut and antilag will kick in to keep the turbo spooled (again wouldn't lose the spool and won't feel it). But it helps you shift faster and with all your power in the game but without jarring and wearing the everliving shit out of the sequential trans. All depends what you choose to do for your specific setup, but the basis is you put force on that shifter and the ECU changes a variable to make it easier to shift in a split second and when the strain gauge on the handle reads you aren't pulling or pushing anymore it determines shifting is done and goes full tilt again all so fast you wouldn't notice.
  19. Dec 30, 2019 at 10:02 PM
    Empty_Lord
    Dan
    yes. pump is external hence the coolant pipes in the valley
  20. Dec 30, 2019 at 10:04 PM
    Speedytech7
    It truly is amazing, even better than flatfoot shifting a faceplated H-pattern manual.
