  1. Jan 3, 2020 at 6:31 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    wiring without the pushbutton appears to be easier. and the truck may even be prewired in the interior. it would just be engine harness side that likely isnt
    Area51Runner likes this.
  2. Jan 3, 2020 at 6:33 PM
    Empty_Lord
    Dan
    if you wanted to do a quick check for prewiring in the dash harness, pull the passenger kick panel, find the transmission control relay and see if the wires in that diagram are present in your connector... i have a good feeling they will be... i mean hell my tundra was prewired for power locks, windows, keyless entry for fucks sake
    Area51Runner and Kwikvette like this.
  3. Jan 3, 2020 at 6:36 PM
    Empty_Lord
    Dan
    Area51Runner and Speedytech7[OP] like this.
  4. Jan 3, 2020 at 6:36 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Weird observation.... Tomato juice makes coffee taste like warm water...
    Also I saved $200+ dollars on a set of 5 new tires and got a raise
    Good day
    cruiserguy likes this.
  5. Jan 3, 2020 at 6:37 PM
    eon_blue
    Azusa, CA
    Weren't the older ADD 1st gens engaged via a vacuum system vs the newer push button ones electronically with the actuator? I thought that was how the j shift worked but I could be off
  6. Jan 3, 2020 at 6:37 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Where is this actuator located on the vehicle?
    So I guess really you're not positive if you're going ADD or Manual hubs?
  7. Jan 3, 2020 at 6:38 PM
    Speedytech7
    Yes and no. I have the vac and jshift, you could have electric add and jshift too. The case engages first so it don't matter what the add is
    eon_blue[QUOTED] likes this.
  8. Jan 3, 2020 at 6:38 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That is true?
    But wondering what extra components are involved since something has to tell the ADD system "hey..the dude moved the J shift to 4H"
  9. Jan 3, 2020 at 6:40 PM
    Empty_Lord
    Dan
    01-04 j shift have the electric actuator
  10. Jan 3, 2020 at 6:40 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    I have a few pics that show how it all plugs in - on the phone though so can't access desktop at the moment. @Empty_Lord or anyone can answer though. (And he just did :thumbsup:)
  11. Jan 3, 2020 at 6:40 PM
    Empty_Lord
    Dan
    its all in the wiring digrams i sent
  12. Jan 3, 2020 at 6:40 PM
    eon_blue
    Azusa, CA
    Gotcha ok so the J shift isn't exclusive to the vacuum operated system, that's where I got mixed up
    Empty_Lord[QUOTED] likes this.
  13. Jan 3, 2020 at 6:40 PM
    Empty_Lord
    Dan
    the case has a sensor that sends a signal to the 4x4 ecu or w/e to tell the ADD to activate.
  14. Jan 3, 2020 at 6:41 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That solves my mystery.
    Thanks :thumbsup:
  15. Jan 3, 2020 at 6:41 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    @Empty_Lord silicone spray and those exhaust hanger pliers worked unbelievably well
    Not a tool I will be needing a lot but when I need it it will be so handy to have
  16. Jan 3, 2020 at 6:41 PM
    Empty_Lord
    Dan
    isnt it crazy? i was actually smart about something!!
    yea you wont use it alot. but when you need it you'll be happy to have it for sure.
  17. Jan 3, 2020 at 6:41 PM
    eon_blue
    Azusa, CA
    I need to replace mine again, the AutoZone rubber exhaust hangers don't last for crap
  18. Jan 3, 2020 at 6:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    So with all that being said, I still don't know why Mike is dilly dallying in this thread and not buying those 4x4 components I tagged him on earlier :boink:
  19. Jan 3, 2020 at 6:42 PM
    Empty_Lord
    Dan
    poly exhaust hangers exist..
  20. Jan 3, 2020 at 6:42 PM
    Empty_Lord
    Dan
    i kinda wana buy the damn axles.
    Kwikvette[QUOTED] likes this.
