  1. Jan 6, 2020 at 3:07 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    And sniffs gas
  2. Jan 6, 2020 at 3:08 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    The bearing as a whole spins inside of the spindle after its pressed in? Should only be able to spin the inner race of bearing which seats onto the shaft of the hub. The whole actual bearing should not spin. If the whole bearing assembly spins inside the spindle, then the bearing could be incorrect or the spindle had been wallowed out? I think I may be understanding you wrong, I've never seen the whole bearing after being pressed in, spin inside the spindle. It's pressed in because it's tight af. In your pic, you see that circular seal around the edge on top of the seated bearing? If that seal was removed you would see just the bearing assembly and where it's pressed into that big whole in the spindle. That bearing race should not spin. Don't know how it would spin but I don't know everything man:D
    Area51Runner[QUOTED] likes this.
  3. Jan 6, 2020 at 3:09 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    going to try and get a video uploaded... give me few
    cruiserguy[QUOTED] likes this.
  4. Jan 6, 2020 at 3:10 PM
    cruiserguy
    Elijah
    SEKS
    Sounds good broseph
  5. Jan 6, 2020 at 3:20 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  6. Jan 6, 2020 at 3:21 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Polishing Compound
  7. Jan 6, 2020 at 3:23 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    The Japanese never fail to amuse me.
    The ungodly abomination that are the Z31 seats.
    9C6253D7-9BC8-4F91-85A4-C3675CD725EF.jpg E3937261-CEE4-4054-9135-2D9893FFC324.jpg
    FLBAdrian likes this.
  8. Jan 6, 2020 at 3:23 PM
    Area51Runner
  9. Jan 6, 2020 at 3:24 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    If it hasnt been too long. Wait a few days or even a week and iron will wreak havoc on paint.
  10. Jan 6, 2020 at 3:24 PM
    SpikerEng
    SpikerEng Well-Known Member
    Leon
    Portland, OR
    I meant even with Priority Mail (which is how I ship the strut kits) it can still take longer to go one state away than across the country. I think they fly it if it's across the country, but truck it if it's closer.
    Looking forward to seeing your install!
    01x4[QUOTED] likes this.
  11. Jan 6, 2020 at 3:24 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Yeah goat feed makes a real comfy seat.
  12. Jan 6, 2020 at 3:25 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Back when I did that concrete slab, I got a bunch of dust on my bodywork. I washed it as soon as I got home, that shit is corrosive.
    Blue92[QUOTED] likes this.
  13. Jan 6, 2020 at 3:25 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I was told it was hay and horse hair mixed together.
  14. Jan 6, 2020 at 3:39 PM
    cruiserguy
    Elijah
    SEKS
    You have the other one to compare it to? I haven't been in the Tacoma front end really, only for brakes. That said knuckles, spindles, hubs, etc from front end 4wd IFS systems are all fairly similar. I believe what you're spinning there should be firm and in place and not move. That's the outer beating race, at least what it's called in traditional standard bearings that get serviced, the inner bearing race should be seated firmly against the shaft of the hub after pressed together.
  15. Jan 6, 2020 at 3:40 PM
    Area51Runner
    Yep, checked the other one and its solid. No movement. So this is a probable bearing issue or an issue with mounting?
    worth noting, the entire hub doesn't turn as easily on this one - unlike the other. there is resistance with this one.
  16. Jan 6, 2020 at 3:43 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    So you deliberately put grease in a MT housing where the pressure plate, flywheel and clutch disk combine to create friction which transfers torque to the gearbox? Did Jay play a part in this? Not in my FSM but it'll be fine. Maybe?
    Das it mang[QUOTED] likes this.
  17. Jan 6, 2020 at 3:45 PM
    Black DOG Lila
    Virginia
    Cleaner Wax
  18. Jan 6, 2020 at 3:47 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    I put it on the PIVOT POINT OF THE SHIFT FORK. I didn't just throw shit in there. Took high temp general grease on my finger and put it on that point as in this post
    https://www.tacomaworld.com/threads/clutch-creak-removing-transmission.225813/
  19. Jan 6, 2020 at 3:47 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Don't kid yourself, that's human hair...
  20. Jan 6, 2020 at 3:50 PM
    Das it mang
    Az
    1996 T100 SR5 MT
    Per that post it seems fine and fairly common for people to do it. Just didn't know if anyone in here had done anything similar
    Black DOG Lila likes this.
