  1. Jan 7, 2020 at 7:51 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Its only money
  2. Jan 7, 2020 at 7:51 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I thought you were gunna sell the taco before you got banned
  3. Jan 7, 2020 at 7:52 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I can see the benefit if going from 4x4 manual hub to 4x4 ADD, and that's because of the Tundra axles used when going long travel.
    Oh and tell anyone else that's deterring you from your swap to fuck off extra, on my behalf.
    If you are doubting yourself and feel like you need to go manual hub, I'd be more than happy to pick up your ADD setup from you.
    Really though, I don't see much of a difference in converting a 4x2 to 4x4 j-shift with ADD vs a 4x2 to 4x4 j-shift with manual hubs; it's like Dan explained, and he's willing to help in that area.
    Area51Runner[QUOTED] likes this.
  4. Jan 7, 2020 at 7:52 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Arnt you a responsible dad/husband
  5. Jan 7, 2020 at 7:53 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    only ECU involved other than the ECU and 3 pins is the 4x4 computer that only controls the diff lock.. nothing else. the main communication is between the transmission Relay for the j shift transfer cases. the motors in the actuator know when theyre engaged and not
  6. Jan 7, 2020 at 7:54 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
  7. Jan 7, 2020 at 7:55 PM
    Empty_Lord
    Dan
    but weren't you involved in a murder?
  8. Jan 7, 2020 at 7:55 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Ftfy
    Crow_of_judgement likes this.
  9. Jan 7, 2020 at 7:56 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    might just take you up on that if its needed, thank you. :hattip:
    Perhaps I need to change my terminology - when I said cable, I meant harness as in plug.
    Well, I checked and that transmission relay plug we were talking about is there but there is nothing plugged in. It's just sitting there.
    Now that is where I'm confused. So when I pulled the HVAC panel and the accessory plug part of the console, according to the docs that 4WD ECM should be right above the airbag sensor module. There is nothing there and no plug for it if it were to be there. I've also come across a few posts which talk about it not being needed at all. I need to pull up that link.
  10. Jan 7, 2020 at 7:57 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Just skip all this and sas
  11. Jan 7, 2020 at 7:58 PM
    Empty_Lord
    Dan
    [​IMG] its not really a complex system the j shift setup
    cruiserguy and Kwikvette like this.
  12. Jan 7, 2020 at 7:59 PM
    Empty_Lord
    Dan
    you didnt get the joke...
    whats a flock of crows?
  13. Jan 7, 2020 at 8:00 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    cruiserguy and Crow_of_judgement like this.
  14. Jan 7, 2020 at 8:00 PM
    Empty_Lord
    Dan
    good chance the harness is all there interior wise. espeically since you have a fuse box with a 4wd fuse in. so it'll likely be running wires outside the truck to control the actuator and the sensors on the t case
    and finding a used transmission control relay
  15. Jan 7, 2020 at 8:00 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    How did you get un perma banned
  16. Jan 7, 2020 at 8:01 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I have a fuse box with a 4wd fuse in on my 5lug
  17. Jan 7, 2020 at 8:02 PM
    Empty_Lord
    Dan
    once again.. wouldnt surprise me. they'll use the same interior harness and fuse box for Alot of models. i wouldnt be surprised if you have a unused connector in you passenger side kick panel
    i have a tundra that was never offered with half the shit i put in it... but it was wired for it in the harness
    Sperrunner[QUOTED] likes this.
  18. Jan 7, 2020 at 8:03 PM
    Empty_Lord
    Dan
    there was some pp touching involved wasnt there
  19. Jan 7, 2020 at 8:05 PM
    Empty_Lord
    Dan
    we missed you bb
  20. Jan 7, 2020 at 8:07 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    X2
