  1. Jan 7, 2020 at 8:46 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Off topic, well kinda, more like off quote, but I had a brain fart earlier in that post regarding the converting ADD to manual system, some have done it after having an issue in the ADD system somewhere and they just thought it'd be easier to convert. Also another pro, not that big a deal, is that you get your cv axle to stop spinning full time and only when hub is locked. Save wear and tear. Not a big deal but it is there.:D and if you already factored that into the equation, grassyass por leer igual:D
    Area51Runner[QUOTED] likes this.
  2. Jan 7, 2020 at 8:47 PM
    cruiserguy
    Elijah
    SEKS
    Oh yeah, close on the age and close on the promo:cool: damn straight, get all training you can get out of em
  3. Jan 7, 2020 at 8:48 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Packed some wheel bearings for the taco but I need the wheel seals to be able to put the spindles back on
    Sperrunner likes this.
  4. Jan 7, 2020 at 8:50 PM
    Wulf
    rock raisin
    Good job
    Sperrunner[QUOTED] likes this.
  5. Jan 7, 2020 at 8:53 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    The so cal trainning is all i want. It applies to my job.
    union training doesn’t apply to me. Because im in a steamers ans pipe fitters Union. So not much i need to know to be learned.
    only reason I would swap to union later is to get a jurneyman title for the better benefits
    cruiserguy[QUOTED] likes this.
  6. Jan 7, 2020 at 8:53 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's about how I'd do it. Simple enough with relays
  7. Jan 7, 2020 at 8:54 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    and that right there is one of the biggest points I see mentioned. immediately followed by someone who asks how many people actually can say their axles crapped out as a result of spinning full time... ahhhh another one of those timeless debates
  8. Jan 7, 2020 at 8:56 PM
    Area51Runner
    but I wonder if this is on the older tacos pre-push button selector - that is what I'm trying to figure out. Do I actually need to worry about this. I think Dan has said no but wanted to verify by putting the TTORA info out there.
  9. Jan 7, 2020 at 8:57 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Convenience Of ADD>>Style points of Manuel hub
  10. Jan 7, 2020 at 8:58 PM
    Speedytech7
    Hi, guy that works with metal parts all day here. CVs in ADD setups are always spinning. Without load behind them there's almost no wear taking place bathed in all that molybdenum disulphide grease. Those parts are all case hardened and would need some actual force on them for either surface to even slightly gall the other. Only part that wears is the cheap part, the rubber boot.
    cruiserguy likes this.
  11. Jan 7, 2020 at 8:58 PM
    Speedytech7
    I can make it work with a j shift, with electric... Without either if you really wanted something stupid haha
  12. Jan 7, 2020 at 9:12 PM
    Wulf
    rock raisin
  13. Jan 7, 2020 at 9:13 PM
    Area51Runner
    not doubting your input on the boots or axles at all just was mentioning how someone always chimes in about the axles being fine with them spinning full time. or wait, is it just the boot that spins full time ;)
    just trying to understand it all. a bit of ramp up time.
  14. Jan 7, 2020 at 9:18 PM
    Speedytech7
    My point is that the vacuum add can operate independent of the case you chose. I can adapt it to either so long as you have a vac add front diff tube.
  15. Jan 7, 2020 at 9:19 PM
    cruiserguy
    Elijah
    SEKS
    True. Just spins. Good point
  16. Jan 7, 2020 at 9:24 PM
    Area51Runner
    appreciate that. this is on its way. should be here in a day or two.
    Front Differential ADD Tube w/ Actuator and gear
    Kwikvette likes this.
  17. Jan 7, 2020 at 9:29 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Home from work, showered and relaxed finally.
    Movie time -
    04Pre_Runner, what road, Wulf and 3 others like this.
  18. Jan 7, 2020 at 9:30 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I remember seeing that and saying "that's too cheap to not buy"
    Good job!
  19. Jan 7, 2020 at 9:31 PM
    cruiserguy
    Elijah
    SEKS
    Man what a movie :Dgreat choice
  20. Jan 7, 2020 at 9:31 PM
    Area51Runner
    BluRays/DVDs on the case?! Bottom are games but Whoa. :anonymous:
    Kwikvette[QUOTED] likes this.
