  1. Jan 7, 2020 at 10:16 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    Lol
  2. Jan 7, 2020 at 10:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    And I'd rather go manual hubs which is why I own 2 sets of hubs (had a 3rd), and a manual diff tube.
    I only offered as a means of 1. Buying a nice ADD setup and 2. Help steer a friend back to the other direction of manual hubs
  3. Jan 7, 2020 at 10:22 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Ain't nobody said you can't do it! :D:cool:
  4. Jan 7, 2020 at 10:25 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Honestly I wouldn’t touch ADD with a 10 1/2 foot pole. It isn’t difficult to get it to work, but I don’t think getting out of the truck and turning a dial is all that difficult.
    04Pre_Runner likes this.
  5. Jan 7, 2020 at 10:26 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    hahaha didn't say it was difficult and cool bro, respect you not wanting to touch ADD...
  6. Jan 7, 2020 at 10:28 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I mean if you really wanted it, it’s obviously easier to find ADD parts plus ADD axles are stronger. Simplest way is to use the newer 2001-2004 electronic ADD actuator and some wiring. I can’t help you much there though, because I don’t know how to do it. You’ll need a relay and I believe a DPDT switch. Ask @mechanicjon he's better at this stuff than me.
  7. Jan 7, 2020 at 10:29 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    Got shipping notifications for both my Camelback Toyota orders today. It's a combined order now but the first order was put in well over a month ago. Just happy things are finally making their way here...
    Running Board Man and Kwikvette like this.
  8. Jan 7, 2020 at 10:29 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Whatcha order?
  9. Jan 7, 2020 at 10:35 PM
    04Pre_Runner
    Andrew
    It has the odds and ends my flatbed needs to return to service. Mostly seals and the front diff tube bearing. Parts for valve covers seals on both trucks. As well as two new wheel bearings, a manual hub assembly, and the outer spindle seals for my double cab.
    :spending:
  10. Jan 7, 2020 at 10:44 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Damn that sounds expensive.
    04Pre_Runner[QUOTED] likes this.
  11. Jan 7, 2020 at 10:45 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    04Pre_Runner and Kwikvette like this.
  12. Jan 7, 2020 at 10:47 PM
    Area51Runner
    Yep, staying away from the electronic ADD Actuator though. Expensive part when it fails. Why the plan is to do ADD with the jshift setup. The 2-4 push button I didn't want to go that route, would need a ton more work vs this route. I know the easy path would be the one you (and many others) chose to take - manual hubs but I'd rather do something different.
  13. Jan 7, 2020 at 10:48 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    If you do the j shift add swap you do t need the computer. For push button you would need the computer.
    Area51Runner[QUOTED] likes this.
  14. Jan 7, 2020 at 10:51 PM
    Area51Runner
    thanks for the confirmation. what i was thinking based on that doc I attached. In fact, one of the same you sent me earlier I believe. Might be the preceeding page for the T4 plug. So glad I grabbed that FSM hardcopy pack (included the Electrical Wiring Diagrams booklet) from ebay when I did.
  15. Jan 7, 2020 at 10:51 PM
    04Pre_Runner
    Andrew
  16. Jan 7, 2020 at 10:52 PM
    Area51Runner
  17. Jan 7, 2020 at 10:53 PM
    Empty_Lord
    Dan
    What you’ll have to do is see exactly what your trucks wired for and what it isnt. If I get the shit I’ve got going on done this week I’ll see what my dads truck is like since they seem to be the same truck.
    But chances are you’re going to need the transmission relay, and to run a few wires and the Connectors for said wires
  18. Jan 7, 2020 at 10:57 PM
    Area51Runner
    The transmission relay I've seen floating about.
    New its 120 bones
    https://parts.camelbacktoyota.com/oem-parts/toyota-relay-transmission-8953135050
    Used on fleabay like 50.
    https://www.ebay.com/itm/2000-2004-...ission-Control-Relay-89531-35050/153769712385
  19. Jan 7, 2020 at 10:59 PM
    Empty_Lord
    Dan
    Not too Bad. Now, I would pull the kick panel trim down and pull the fuse box down to check the wires going to the fuse box and make sure they’re all there. Also, check if the wires are at the ecu. You MAY need an ecu, I don’t know if these trucks got 4x4 ecu or not as prerunners
  20. Jan 7, 2020 at 11:00 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I realized I don’t need a locker to begin with. I use my truck for truck things like hauling trash and other stuff that doesn’t fit in a car.
