  1. Jan 11, 2020 at 12:53 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    gentlemen, I'm very interested in hearing both of your input on this... :popcorn: (and thanks!)
  2. Jan 11, 2020 at 12:55 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    im a man that goes through the little extra effort to make it function like factory. theres simpler ways to make the system work.. i mean you want to go real simple get a vacuum actuated diff and run a switch to a VSV to turn it on and off. thats the simplist way i can think of making an ADD diff work, thats literally just a switch and no relays
  3. Jan 11, 2020 at 12:56 AM
    Empty_Lord
    Dan
    to determine if its worth it for you to run the wires ultimately comes up to if the dash harness is wired. if it is, thats the hardest part already done. exterior is not a whole lot to wire up. almost everything 4x4 control is interior side except the actual actuator and the transfer case sensors
  4. Jan 11, 2020 at 12:59 AM
    Area51Runner
    so essentially, its going back to the 2-4 pushbutton selector or perhaps a better way to describe it is the same type of operation just without that pricey electronic actuator.
    Computer though. Unless we can rule that out. Speaking of that, I wonder if when I pulled the computer, that messed with all of the settings which caused that rough idle I encountered this morning.
  5. Jan 11, 2020 at 1:01 AM
    Empty_Lord
    Dan
    im a
    did you pull it completely out? its possible. the computer would need to relearn idle. cleaning the IAC helps
    the wiring for the tube with a j shift is simple. the relay is saying hey, the t case is in 4x4 which then sends signal to the actuator to lock. no buttons. no fuss
  6. Jan 11, 2020 at 1:02 AM
    Empty_Lord
    Dan
    theres also the one route i know a few people have gone and it does add a little more interesting abilities to the list. You can run an ADD tube with manual hubs.
    and the ADD can technically be ran like factory, or you can set it up as a dumb system with a switch.. no computers involved..
  7. Jan 11, 2020 at 1:06 AM
    Area51Runner
    Yep, pulled it completely out to get that picture. Could not see the label at all from the top. its a tight fit in there.
    See, now that I like the idea of but ultimately we'll need to determine exactly how much wiring.
    Now you just lost me there. :goingcrazy: I need to find docs on that to better visualize it I guess. Guessing more can break as well?
  8. Jan 11, 2020 at 1:08 AM
    Empty_Lord
    Dan
    the ADD manual hub mess would be pointless unless your unable to find a full manual hub setup. all you'd gain is the ability to unlock the hubs when you want 2lo or are just highway driving. with them locked it would work like a completely normal ADD setup.
  9. Jan 11, 2020 at 1:10 AM
    Empty_Lord
    Dan
    and technically the ADD tube is stronger in the bearing department. you can also permanently lock the ADD and it'll work like a manual hub tube... theres many options
    you just need to get the truck down to me and after a few drinks and a few days we'll have you all set! lol
    Area51Runner likes this.
  10. Jan 11, 2020 at 1:11 AM
    Area51Runner
  11. Jan 11, 2020 at 1:12 AM
    Area51Runner
  12. Jan 11, 2020 at 1:14 AM
    Empty_Lord
    Dan
    id just ignore the last option. lol thats if hobbled together things or if you wanted the gas mileage gain from unlocking the hubs but wanted on the fly shifting 4x4...
    either go full ADD or full manual hub. (but an ADD diff is strong with the presence of the extra bearing- albeit minimally).. And you cannot put an ADD tube on a manual hub diff. but a manual tube can be put on a ADD diff.. its weird
  13. Jan 11, 2020 at 1:19 AM
    Empty_Lord
    Dan
    Continue this tomorrow. I’ve gotta get some sleep :anonymous:
  14. Jan 11, 2020 at 1:20 AM
    Area51Runner
  15. Jan 11, 2020 at 1:23 AM
    Empty_Lord
    Dan
    I know about that post. That’s how you can lock them permently to get a 100% manual setup. But you can also leave it fully functional add if you really wanted.
    Area51Runner[QUOTED] likes this.
  16. Jan 11, 2020 at 1:26 AM
    Area51Runner
    good deal. go to bed. lol. im out as well. @BartMaster1234 thanks for your earlier feedback on this whole endeavor as well - appreciate it. until i get this going, going to be lots of questions come up.
  17. Jan 11, 2020 at 1:29 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    You’d be the first person on TW or any other Tacoma forum I’ve seen wire up the ADD as it were from the factory using stock wiring. Everyone who does this conversion uses Manual Hubs, the electronic ADD actuator with a relay and switch, or the vacuum ADD actuator with the vacuum accumulator/VSV and relay/switch.
    The only reason I would bother with all the wiring was to go for the pushbutton case. Which I have seen people do, but it’s too much hassle.
    I still don’t see the huge deal of the manual hubs. People even keep them locked the entire winter season, and all you have to do is pull the shifter in the cab.
    Kwikvette likes this.
  18. Jan 11, 2020 at 7:51 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Wakey Wakey, hands off snakey :D
    Time to get up and get ready for the Niners playoff game tail gate party! I'll see you Bay area snowflakes over there at Levi's for the pregame tailgate:cool: game is at 1:30 local PST
    Kwikvette and Black DOG Lila like this.
  19. Jan 11, 2020 at 7:58 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Now I'm confused. Is that 4:30pm EST here or 10:30am bc of time warping gov. approved time zones. Thank galctic gods for the Tartis.
    cruiserguy[QUOTED] likes this.
  20. Jan 11, 2020 at 8:06 AM
    cruiserguy
    Elijah
    SEKS
    Lol, I believe that is 4:30pm your time. And you're rooting for the good guys, the ones in the red and gold uniforms not the purple uniformed Vikings.
    It's the first playoff game ever for most of the team. So we're really anxious to see how they play and respond to the environment/scenario/pressure and crap being their first time. Coach has been to a Superbowl before though. So should keep the boys well grounded. I'm excited.
    I should go work, I'm almost done with those floors. But i'mma be lazy, it's cold out and all I need to be happy is one of those big breakfast burritos:D... and then I want both teams to play to the best of their ability so we can beat them fair and square and they won't have excuses:D:cool:
