  1. Jan 15, 2020 at 10:20 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    I know the feeling and it sucks. Best to start it and let it idle and do a visual, then you should be good to go.
    Might have to use the wrench to take it off if you got it on there monkey tight
    Das it mang[QUOTED] likes this.
  2. Jan 15, 2020 at 10:22 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    On the 2RZ and 3rz its easy if you drop the skid plate. Just go straight up at it from underneath, tight as possible by hand.
    My first time I used a wrench. Never again. Had to take it someplace the next time after I struggled to get the filter off and crushed it in the process.
  3. Jan 15, 2020 at 10:27 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    What was weird is on the ram I started it and gave it gas in park a couple of times and no leak. once I put it into R and gear is when it leaked. I made sure to take the 5 lug round my apartment parking lot after the change and no leak so I knew it was gtg. Thank you for the info! I hate being ignorant lol
  4. Jan 15, 2020 at 10:28 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    I have 5 lug so no skid plate. Maybe it's actually easy and I'm just a baby lol.
    Hoping mine isn't too tight, but I ALWAYS put old oil around the seal to make sure it doesn't seal up and be unable to be removed. Fingers crossed I'm gtg but well see
  5. Jan 15, 2020 at 10:34 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Yeah go from underneath, drive up on ramps first if you need to. Easy peasy since you don't have a front diff in the way. I find the best type of filter wrench to get it off is the 3 jaw claw looking one that you use with a long extension and ratchet. No good way to use a strap wrench on that filter.
  6. Jan 15, 2020 at 10:37 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I’ve struggled to get Toyota filters off after hand tightening. I don’t know if the seal swells up and puts weird pressure on the thread or what.
    It’s actually probably due to the fact that ima bitch
  7. Jan 15, 2020 at 10:47 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    and THAT's why I struggled. I used the strap-style wrench lmao. FML
  8. Jan 15, 2020 at 10:48 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    Fingers crossed I'm GTG. might try to check it this weekend if it'll budge then, but after driving 300 miles up and down a mountain I'm sure whatever swelling could have happened; did happen at this point
  9. Jan 15, 2020 at 10:52 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Mpg is the issue.
    11 mpg is bad enough already. Now if someone made some manual hub ends that fit the tundra cv axles, that’d be the ticket. The spindles can use the Tacoma manual hubs.
    Wulf[QUOTED] likes this.
  10. Jan 15, 2020 at 10:53 AM
    eon_blue
    Azusa, CA
    Every now and then, two harmless words are brought together in such a visually inspiring way that when you read them you think - I really wish I hadn't
  11. Jan 15, 2020 at 10:53 AM
    Wulf
    rock raisin
    I see your point there. I wonder if one of the companies like Moser who makes custom shafts could take a tundra CV and turn it down and respline it for the manual hub. Ain't be cheap I bet but I believe it could be done
  12. Jan 15, 2020 at 10:58 AM
    Wulf
    rock raisin
    Diplo - Express Yourself (Lyrics)
  13. Jan 15, 2020 at 11:01 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Ditto. More of a pain to rummage through the garage looking for an acceptable drain apparatus then it is to be prepared with a roll of paper towels. :notsure:
  14. Jan 15, 2020 at 11:05 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    not to get it on, but snug it, yes.
    It'll be me who gets to break it loose. If I broke my rear diff loose after fighting it a couple weekends by hand when others have had to use more "invasive" methods; I'm fairly confident I have the "umph" to get this bastard loose. BUT, we shall see
  15. Jan 15, 2020 at 11:09 AM
    JKO1998
    Utah
    Twists top half of filter off*
  16. Jan 15, 2020 at 11:11 AM
    eon_blue
    Azusa, CA
    I always just hand tighten my oil filter and hand loosen it. One of those rubber jar lid openers helps loosen it if your hands or the filter are oily
    Das it mang likes this.
  17. Jan 15, 2020 at 11:18 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    well see, not trynna come off arrogant. But shit does nothing to worry atm
    JKO1998[QUOTED] and Wulf like this.
  18. Jan 15, 2020 at 11:20 AM
    Das it mang
    Az
    1996 T100 SR5 MT
    thanks! will update when I get around to it. just know worrying does nothing cause I've already put on ~400 miles since I did it last weekend
  19. Jan 15, 2020 at 11:34 AM
    eon_blue
    Azusa, CA
    Damn...company I work for bought my wife and I a really nice crib and mattress + sheets for the baby, just delivered it this AM
    Now let's see how complicated this DIY crib assembly is
  20. Jan 15, 2020 at 11:48 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    If you live in an older house, put it together in the babys room. I did my buddies, had it all together and the stupid thing wouldn't fit in the doorway. Took the door off and it just barely cleared.
