  1. Jan 18, 2020 at 5:28 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Yea, if I got pulled over I’d be in a bad situation
    Empty_Lord[QUOTED] likes this.
  2. Jan 18, 2020 at 5:30 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    I'm jelly of all the cool folks I'm sure you're meeting:cool::D
    Off road folks in events and stuff like that have always been great people man. Makes me miss the Cruise Moab days
    CS_AR[QUOTED] likes this.
  3. Jan 18, 2020 at 5:36 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    cruiserguy likes this.
  4. Jan 18, 2020 at 5:39 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    It's people from all over the country. Most have driven 4 hours or more. Texas, Louisiana, Alabama, Kansas, and St. Louis that I've talked to tonight.
    01x4 and cruiserguy[QUOTED] like this.
  5. Jan 18, 2020 at 5:42 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Cum shot o_O
    what road likes this.
  6. Jan 18, 2020 at 5:42 PM
    cruiserguy
    Elijah
    SEKS
    :laughing::rofl:
    CS_AR and what road like this.
  7. Jan 18, 2020 at 5:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    FIFY
  8. Jan 18, 2020 at 5:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Painful?
    Sucks looking like that; I had pinkeye and that shit lasted for almost a week.
    Even went wheeling with pinkeye :rofl:
  9. Jan 18, 2020 at 5:47 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    His eye would be stuck shut not just red
  10. Jan 18, 2020 at 5:50 PM
    JKO1998
    Utah
    Nah, no pain
    Kwikvette[QUOTED] likes this.
  11. Jan 18, 2020 at 5:52 PM
    eon_blue
    Azusa, CA
    Hate it when I sleep in my contacts, usually means I can't wear them the rest of the day
  12. Jan 18, 2020 at 5:55 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Injector fuel hose OK to use for the power steering return hose? I can't find just the rubber return hose, Toyota only sells the whole assembly, cheapest I've found is $132. PITA. The metal line is all good, just the rubber from the metal return line to the reservoir needs replaced.
  13. Jan 18, 2020 at 6:04 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
  14. Jan 18, 2020 at 6:05 PM
    cruiserguy
    Elijah
    SEKS
    We're talking the low pressure side right? That sucks it's only available that way. I'd imagine it's fine to use, but never had to nor looked into it, so no direct experience
  15. Jan 18, 2020 at 6:05 PM
    cruiserguy
    Elijah
    SEKS
    :rofl:
    Kwikvette likes this.
  16. Jan 18, 2020 at 6:09 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yeah, low pressure return line.
    I'm assuming the lines on the 4R now are OEM. They are rock hard and very brittle. That's what was causing the power steering leak. Had to order a new OEM hose for the reservoir to pump side and I can get the return line from rock auto for $25 but if FI hose is good then I'll keep that on there. Replaced that one line today with 3/8" ID FI hose but I wasn't able to get the hose on far enough to be comfortable. It'll hold but I'm gunna have to do it all again when I get the other factory hose.
    cruiserguy[QUOTED] likes this.
  17. Jan 18, 2020 at 6:10 PM
    cruiserguy
    Elijah
    SEKS
    Gotcha. I think your plan sounds okay as you state it
  18. Jan 18, 2020 at 6:12 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I was just worried that maybe the ATF caused the old lines to get hard and brittle over time like that. Maybe it's just the location they are in too, might collect a lot of heat there.
  19. Jan 18, 2020 at 6:15 PM
    cruiserguy
    Elijah
    SEKS
    That sounds like normal hardness to aging and use and stuff. Unlucky about the leak, might've been bumped or something. Seems most are old and hard but not most leak
  20. Jan 18, 2020 at 6:19 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    The Taco never had hard, brittle return lines and that had the original rack, pump and hoses on it with 314k miles and was filled with actual power steering fluid. But who knows. :annoyed:
    The 4R had been leaking for a while from that return line. Huge mess in front of the air box there. I've cleaned up a bunch but still need to spray some engine cleaner in there and then hose it down.
