  1. Aug 17, 2018 at 2:14 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I MUST KNOW
  2. Aug 17, 2018 at 2:14 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Front should take the longest so i say front
  3. Aug 17, 2018 at 2:14 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    That truck probably not put you can put those on a bed
  4. Aug 17, 2018 at 2:15 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Ive seen it when they chop up beds to use parts of it to hold the glass on. But I doubt thats what they did
  5. Aug 17, 2018 at 2:16 PM
    jbrandt
    Justin
    Just do the left side. Then take it out for a spin. decide if you still want to do the right side. :anonymous:
    I did my front first. Ext travel Kings, TC UCAs, the back is still sporting my stock leafs and 5100s.
  6. Aug 17, 2018 at 2:17 PM
    eon_blue
    Azusa, CA
    Let's hope I'm done with having anything to do with my leaf springs for several more years, then we'll revisit this lol
    Crodell6 and Sperrunner[QUOTED] like this.
  7. Aug 17, 2018 at 2:20 PM
    eon_blue
    Azusa, CA
    wait I thought you were already into doing the leafs?
    I would do the rear first that way if you have to wait awhile until you do the front, you aren't left with bro lean.
  8. Aug 17, 2018 at 2:21 PM
    jbrandt
    Justin
    The people who have a LT SUA setup with a caged rear end, but still try and keep their bed = lolz
    Just take off the 3 square feet of bed sheet metal you still have, and stop pretending you're going to use the truck to haul gravel anymore.
    :D
    Sperrunner[QUOTED] likes this.
  9. Aug 17, 2018 at 2:21 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    But he has icons so he can jsut goto 0” lift
    eon_blue[QUOTED] likes this.
  10. Aug 17, 2018 at 2:22 PM
    eon_blue
    Azusa, CA
    true, didn't he buy them used though? They might already be adjusted for certain ride height
  11. Aug 17, 2018 at 2:22 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I was just changing the bushings outside the truck. How long do you think the rear will take me?
    Oh, and how exactly should I jack the truck up to do the leafs? By the frame? I usually jack by the axle gear pumpkin.
  12. Aug 17, 2018 at 2:22 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Got then rebuilt so idk
  13. Aug 17, 2018 at 2:22 PM
    jbrandt
    Justin
    you can adjust that...
    :anonymous:
  14. Aug 17, 2018 at 2:23 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I had them rebuilt. I have no idea what height the shop put the sleeve at, however.
  15. Aug 17, 2018 at 2:23 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    :violent:
    mechanicjon likes this.
  16. Aug 17, 2018 at 2:24 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I did front first, but I didnt do ucas so it was easy breezy. Rear took 2 days since everything was rusty and needed to be cut. When I did my extra leafs it took 4 hours start to finish with a 30 min lunch break. Ill probably do them a third time to install greaseable bushings and axle shims though. Not looking forward to that day. But these squeaks are getting on my nerves.
    BartMaster1234 likes this.
  17. Aug 17, 2018 at 2:24 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Jack up like normal then support with stand on the frame.
    The undo the u bolts and support the axel with stands, after that you can remove the leafs
  18. Aug 17, 2018 at 2:24 PM
    jbrandt
    Justin
    Didn't it take you like 3 weeks for the bushings? At this rate, you might be collecting social security by the time you're done...
    Jack the truck up on the pumpkin, then take the wheels off, and hopefully you have big enough jack stands to reach the frame. Harbor Freight has 6 and 12 tons one for pretty cheap. My 6 tons were like $50 for the pair.
    Sperrunner likes this.
  19. Aug 17, 2018 at 2:24 PM
    eon_blue
    Azusa, CA
    I put jack stands on the frame toward the rear and used the floor jack under the pumpkin to move the rear axle up/down (with small 3 ton floor jacks under the axle but not touching it just in case the jack gave out or something).
    yeah but that would suck to have to adjust them just to get level then do it again lol
  20. Aug 17, 2018 at 2:25 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    My truck has spent its life 30 minutes from the factory it was built at in Fremont, California - so I don't really have to worry about rust. Think I'll do the front first, the concrete is too hot don't want to get under the truck till it cools down.
