  1. Jan 20, 2020 at 2:27 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    If I could live in a place that had 3” of freshish snow on the ground year round, I totally would.
  2. Jan 20, 2020 at 2:30 PM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    lols window tint, good ac, and tank tops. Run up north to camp as much as possible. Long as u aren't in construction it's not too bad imo, but I've lived here my whole life and prolly have adjusted. It's prolly hell for people who are out of state in for the summer
    I just see it as a giant sauna, good to clear the pores, if u need work on the truck just do in the morning or at night
    eon_blue[QUOTED] likes this.
  3. Jan 20, 2020 at 2:31 PM
    eon_blue
    Azusa, CA
    Yeah the elevation there is what saves it and makes it a nice place. Even the high desert out here in CA wouldn't be so bad if only it didn't get quite so hot in the summer. In winter though the high desert here gets plenty of snow. But also most high desert towns in CA are meth villages so there's also that
    01x4[QUOTED] likes this.
  4. Jan 20, 2020 at 2:35 PM
    eon_blue
    Azusa, CA
    Area51Runner and 01x4 like this.
  5. Jan 20, 2020 at 2:37 PM
    eon_blue
    Azusa, CA
    Bishop is a really nice high desert city right in the foothills of the lower eastern Sierra...about an hour south of Mammoth. That's a really cool place, @theesotericone lives there and raves about it. Beautiful backdrop and tons of local wheeling
    theesotericone and 01x4[QUOTED] like this.
  6. Jan 20, 2020 at 2:39 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    I too finally scratched one off the list... :rofl:
    1. Change Engine Oil
    2. Rotate Tires
    3. Wheel Alignment - Caster back to 3.5 from 3.9
    4. Remove ARB, Valve Cover Gaskets, Timing Belt, Trans Cooler install, Radiator hoses/clamps
    5. Swap out Grille and put the ARB back on
    Figure the truck will be sitting for at least a few days while I tackle #2. :help:
  7. Jan 20, 2020 at 2:40 PM
    eon_blue
    Azusa, CA
    Yeah I felt really good about myself right after I did it but then realized how long it took me to finally get around to it...and all the other crap I still need to do...and now I feel stressed again lol
    Area51Runner[QUOTED] likes this.
  8. Jan 20, 2020 at 2:40 PM
    Area51Runner
    01x4 and eon_blue[QUOTED] like this.
  9. Jan 20, 2020 at 2:50 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I owe Vicente a birthday gift, and that’s his dream car so I pulled the valve cover and the center gauges for him along with the VIN plate. Think I’m going to stick the clock in the oil fill hole.
    I did unspeakable things to that car to get the center gauges out.
  10. Jan 20, 2020 at 2:51 PM
    eon_blue
    Azusa, CA
    Damn you've got some high caster...I didn't think we could go that high without doing it via the adjustable UCAs. Your SPCs are in the normal setting right?
  11. Jan 20, 2020 at 2:52 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    That’s a super rare center gauge cluster too. The analog clock is very uncommon, they were usually digital.
    CS_AR and Area51Runner like this.
  12. Jan 20, 2020 at 2:58 PM
    Area51Runner
    yep. default setting. I like the extra clearance but I have been seeing very light feathering on the outside shoulder - doesn't make sense since my toe is good. Going to try bringing it back to 3.5 | 3.5, 0.0 | 0.0 Camber and 0.0 | 0.0 Toe.
    Pressure is fine also - currently running 35psi
    last report
  13. Jan 20, 2020 at 3:00 PM
    eon_blue
    Azusa, CA
    Yeah I need to take mine in for an alignment too in the next few days. Place isn't cheap ($130) but they do a great job and work primarily on 4x4 Toyotas
  14. Jan 20, 2020 at 3:02 PM
    Area51Runner
    lol brain fade... not 4.9... meant 3.9. lol
  15. Jan 20, 2020 at 3:11 PM
    Area51Runner
    $130 isn't bad at all. Last place I went to (Tyler and many others have used them), charged $150. I thought they did a decent job but this wear is bugging me. I need to call them and ask about the wear I've been seeing. Probably just going to say bring it back in and charge me another $150. :notsure:
    As long as it gets sorted. Don't want to be buying another set of these tires any time soon
  16. Jan 20, 2020 at 3:19 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Outside edge sounds like a camber issue. May need a touch of negative camber.
  17. Jan 20, 2020 at 3:25 PM
    Area51Runner
    Yeah, they have me @ -0.3 L & R now. I always thought that outside uneven wear/feathering was a toe in issue. @ 0.0 toe now both sides.
  18. Jan 20, 2020 at 3:27 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Toe is steering related, could be the problem. But I think camber is more likely.
  19. Jan 20, 2020 at 3:41 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    It's really not as bad as you might think it is. Low humidity makes it much more tolerable and you are in A/C more often than not.
    cruiserguy and eon_blue[QUOTED] like this.
  20. Jan 20, 2020 at 3:41 PM
    Area51Runner
    On another note, picking up one of those old 1st gen rubber bed mats from another member. It was listed on the local craigslist, so contacted the seller right away. Someone had snatched it up but the seller said it was someone on TW and to check there since they were only planning on using it for a week. Posted in the NorCal CL thread and sure enough, dude was using it to transport his new bumpers from the powedercoating shop. So worked out.
    Might just throw it into the truck as is or might pull the drop in liner. Not sure yet. Last time I removed the liner, the rails and the bed itself had only small paint wear spots in a few places.
    Still looking for a new/old stock DC bedrug. :pccoffee:
    01x4 likes this.
