  1. Jan 20, 2020 at 9:06 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    that is exactly what I was saying to @Kwikvette - might as well do the TB if he's going put that bumper and winch on. That way he can forget about it for 90k. haha
    Maybe it was the fact that the capture nuts (3 on each side, or was it 4) were worn out but it took 2Beers a couple of hours just hassling with those things. One comes loose and drops, you have to pull all the others to get the dropped one out. SUCKS.
    eon_blue[QUOTED] likes this.
  2. Jan 20, 2020 at 9:07 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You can leave the rad in for a TB job..., it doesnt make it any harder
  3. Jan 20, 2020 at 9:08 PM
    eon_blue
    Azusa, CA
    I'll pretend the bumper still needs to come off though so I'll have a more logical reason to get a winch sooner
    Seagull233 and Sperrunner like this.
  4. Jan 20, 2020 at 9:09 PM
    Area51Runner
    oh I fully agree - 1 person can definitely install the bumper. its just a PITA the way ARB designed those capture nuts. Tyler got mad and shook the hell out of the transmission jack - I'm afraid I'm going to grab the f-ing saw and start hacking away at the bumper. :annoyed:
  5. Jan 20, 2020 at 9:10 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  6. Jan 20, 2020 at 9:11 PM
    eon_blue
    Azusa, CA
    If you do, make sure someone's recording it
  7. Jan 20, 2020 at 9:11 PM
    eon_blue
    Azusa, CA
    Forgot the Rockstar
    Sperrunner[QUOTED] likes this.
  8. Jan 20, 2020 at 9:11 PM
    Area51Runner
    security cam in the garage, no worries. will upload. hahaha
    Sperrunner and eon_blue[QUOTED] like this.
  9. Jan 20, 2020 at 9:12 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    i did my timing belt without removing that bumper and pulled the radiator, but get a winch lol
  10. Jan 20, 2020 at 9:13 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 405K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Since I started replacing vacuum hoses with silicone I've somehow created an intermittent vacuum leak. It's not enough to cause a check engine light, but I can hear the VSV clicking while in idle. Also detecting a fast "whoosh" noise somewhere behind the plenum or near the vacuum booster. Every hose I've replaced feels tight. I'm about ready to crawl back to the dealership and get OEM hoses. It's driving me nuts!
    Any risk of damaging the VSV if I can't get this sorted out soon enough?
  11. Jan 20, 2020 at 9:13 PM
    eon_blue
    Azusa, CA
    Which winch did you run with this bumper again?
  12. Jan 20, 2020 at 9:14 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    The tow truck
  13. Jan 20, 2020 at 9:14 PM
    Prayn4surf
    Socal
    The warn 9.5xps
  14. Jan 20, 2020 at 9:14 PM
    Speedytech7
    It won't hurt it, but a good rule of thumb is never put silicone where there are fuel or oil vapors, that means no PCV or EVAP, because they both make the silicone gummy and it can break down and suck closed
  15. Jan 20, 2020 at 9:15 PM
    eon_blue
    Azusa, CA
    Ooof that's a spendy one haha
  16. Jan 20, 2020 at 9:15 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    I pulled my flatbed's R150F by removing the transfer case first. Then when reinstalling my "new" R150F I realized the dowel pin from the old trans had stuck in the block and I was smacking two dowels against each other. On my final install after heating the old dowel out the harbor freight jack exploded on me. What an experience.
    Sperrunner likes this.
  17. Jan 20, 2020 at 9:15 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Sounds $$$
  18. Jan 20, 2020 at 9:16 PM
    Prayn4surf
    Socal
    Thats good to know. Ive got to address my vaccuum lines sooner than later. They are old. Still no leaks...yet
  19. Jan 20, 2020 at 9:16 PM
    eon_blue
    Azusa, CA
    *laughs in P0171*
  20. Jan 20, 2020 at 9:17 PM
    Prayn4surf
    Socal
    It was...it works pretty dam good though. You can get a less expensive winch and it will most likely do its job. I just always wanted a warn
    Sperrunner[QUOTED] and eon_blue like this.
