  1. Aug 17, 2018 at 2:45 PM
    eon_blue
    Azusa, CA
    yeah that was my nightmare when doing mine. I could turn 3 of the adjustment holes but not the 4th without moving the shock
  2. Aug 17, 2018 at 2:45 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Do it and if they dont work im someone who will buy then
    Area51Runner[QUOTED] likes this.
  3. Aug 17, 2018 at 2:45 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    thought you had wheels - those methods
  4. Aug 17, 2018 at 2:47 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    So what’s the consensus? Should I leave the Icon coil over alone without adjusting the sleeve off the truck? Or should I adjust it?
  5. Aug 17, 2018 at 2:48 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Okay, take a breath, we're gunna get through this together...
    If you have the press, kinda like this:
    https://www.eastwood.com/fairmount-...MIjb_CzIf13AIVw0CGCh0d6gvMEAQYASABEgKaSfD_BwE
    You should be good in the hood.
    I remember when I did my 5100's I did all new BJs too, and was trying this stupid method of using a 3-arm puller, a big socket and cutting the UBJ post off. THAT SUCKED, and took me an entire weekend as well.
    When I did my Kings etc... I sucked it up and rented the proper tool. To install those plugs, def stick them in the freezer overnight. They almost fell in the spindle with barely any resistance on the BJ tool. I think I still used the 3-arm puller to get the old BJs out, which was still a PITA (I used bailing wire to keep the arms in place), but installing the TC plugs, I did the proper press tool.
  6. Aug 17, 2018 at 2:48 PM
    eon_blue
    Azusa, CA
    I just think no matter what you won't know for sure until they're on. You can adjust them now and make it so you only have to make minor adjustments when they're on the truck.
  7. Aug 17, 2018 at 2:50 PM
    eon_blue
    Azusa, CA
    I like your current stock ones better TBH, the other's aren't bad I just like the stock 1st gen wheels more
  8. Aug 17, 2018 at 2:50 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Thoae are for the 5lug
    I need 6lug wheels lol
    E30325 likes this.
  9. Aug 17, 2018 at 2:52 PM
    jbrandt
    Justin
    This.
    When I put mine on, I just left them at whatever factory setting. Then drove it around a little. To settle them out. Still too high so I had to adjust them. Once I get my rear setup going, I'll have to adjust them again.
  10. Aug 17, 2018 at 2:55 PM
    jbrandt
    Justin
    It's starting to come back to me. I must have blocked that from memory, lol...
    At least for me though, I think taking the upper control arm off the spindle is better than taking the shock off entirely. I made a tool that holds the shock in place while I turned the collar, but it was clunky and I scratched up the shock body doing it.
    If I can take the UCA out and get the spanner in there, I'll be good to go (I think).
    eon_blue[QUOTED] likes this.
  11. Aug 17, 2018 at 3:01 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Change of plans. My air compressor hose doesn’t reach all the way to where my truck is parked, so I’m going drill out the bedsides on the 5-lug bed first and then get the suspension on. Gotta get that bed out of my driveway.
    Crodell6 and Sperrunner like this.
  12. Aug 17, 2018 at 3:03 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Excuses
    Area51Runner and Crodell6 like this.
  13. Aug 17, 2018 at 3:09 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I’m definitely not trying to take those u-bolts and shackle nuts off without that air impact.
  14. Aug 17, 2018 at 3:10 PM
    eon_blue
    Azusa, CA
    breaker bar makes it easy as long as they aren't seized on.
  15. Aug 17, 2018 at 3:11 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Probably. I just have to get this bed out of my driveway.
  16. Aug 17, 2018 at 3:11 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Not even hard reall But i have a breaker bar and 6’ tube if needed
    Or idk get a longer hose lol
    Seagull233 likes this.
  17. Aug 17, 2018 at 3:12 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Smart, make it easy, keep a grinder handy as well
  18. Aug 17, 2018 at 3:13 PM
    jbrandt
    Justin
    And that's when you break out the sawsall.
    Might be good to do that anyway. I hear lot of people recommending to NOT re-use U-bolts. They are so cheap you might as well put new ones on. That way you don't have to worry if they are seized or not. Just cut.
    Prayn4surf likes this.
  19. Aug 17, 2018 at 3:14 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Tell that to @eon_blue lol
  20. Aug 17, 2018 at 3:14 PM
    Prayn4surf
    Socal
    They should not be reused. The threads will be overstretched
