What would you rather listen to instead of Cold Play
This poll will close on Jul 20, 2025 at 7:20 AM.
  1. Nails on a chalboard
    6.3%
  2. Bass boosted memes
    56.3%
  3. Rod knock
    50.0%
  4. Political discourse
    12.5%
  5. That one annoying drunk gal at a comedy club
    12.5%
  6. No i really do like Cold Play and I'm not writing this under duress (help Cold Play is in the room)
    12.5%
Multiple votes are allowed.
  1. Jan 22, 2020 at 12:16 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    With that radiator, I need to get that clamp and lower hose squared away ASAP. I drove across the bay today (about a 40 min drive with traffic), getting to the destination - damn I could smell coolant when I climbed out of the truck. No leaks mind you but I could smell it.
  2. Jan 22, 2020 at 12:17 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    when you do it make sure the aluminum on the inlet and outlet of the engine is clean. i use scotchbrite pads to make sure theres no corosion or anything.. if they look pitted. replace them. (doubt thats an issue for you though)
  3. Jan 22, 2020 at 12:20 AM
    Area51Runner
    good deal. will watch for it. was planning on cleaning the pink crusties off the pipe but the scotchbrite pad sounds better than a wire brush (inlet - thermostat housing).
    What is your take on that Lucas Oil Stabilizer additive?
    https://www.amazon.com/Lucas-LUC10130-Synthetic-Stabilizer-Quart/dp/B000ARPVNY
  4. Jan 22, 2020 at 12:22 AM
    Empty_Lord
    Dan
    im sure its fine. i love lucas products. but honestly its a toyota with bucket and shim valvetrain. the damn thing can run on next to no oil. why waste your money.
  5. Jan 22, 2020 at 12:22 AM
    Area51Runner
    good point. thx.
  6. Jan 22, 2020 at 12:23 AM
    Empty_Lord
    Dan
    tundras idle oil pressure is like 10 psi min. the gauge is damn near at the bottom. tacomas are the same.
  7. Jan 22, 2020 at 12:24 AM
    Empty_Lord
    Dan
    CS_AR, cruiserguy and Area51Runner like this.
  8. Jan 22, 2020 at 12:26 AM
    Area51Runner
    very tempted to run one of those oil reports I keep seeing people talk about. Be interesting to see the results of this engine.
    that shelby should be your white noise for sleep. lol.
    out, time for sleep. thx for the input. have a good one!
  9. Jan 22, 2020 at 12:26 AM
    Empty_Lord
    Dan
    l8r!
  10. Jan 22, 2020 at 12:27 AM
    Area51Runner
  11. Jan 22, 2020 at 12:43 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
  12. Jan 22, 2020 at 4:04 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    His stuff from the 90s and 00s and even some of the 10s was sooooo funny:rofl:
  13. Jan 22, 2020 at 4:12 AM
    cruiserguy
    Elijah
    SEKS
    What amazing skill.
    Dude and you have access to this stuff?! On days off, yeah sucks to be home cause everyone is there, but don't stay home. In your. Days off Let's go to your shop and master those old school machines you have!
    Sperrunner[QUOTED] likes this.
  14. Jan 22, 2020 at 4:40 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Do you like Relleno de papa? My mother-in-law could make some of the best that I have ever eaten.
    Kwikvette[QUOTED] likes this.
  15. Jan 22, 2020 at 5:05 AM
    CS_AR
    I've used the one in this picture to bleed some SOB clutch fluid system. Extended a clean plastic line over the hard plastic stock line to fit the bleeder nipple.
    Comes in handy for just about any type of engine liquid. Be sure to get one that you can replace the vacuum diaphragm part of the pump and the line plugs. Those will go out long before the plastic container or plunger gives up. I wish I had bought the better model. This is just the basic Mityvac model.
    It just takes some creativity to figure out how to use it. It is a shame the ATF fill tube has a bend in it that prevents it from sliding down the tube to extract fluid.
    I have actually used it to extract engine oil from an oil pan on an engine that likes to spray oil all over everything underneath. Once I get 95% of the oil out using the extractor, then I finish it off by releasing the drain plug. By then there is so little pressure that it slowly leaks out without soaking everything.
    I actually used it "very carefully" years ago to evacuate a fuel tank before removal.
    Its great for lawnmowers and lawn equipment that can be a pain.
    I need to buy a new one or get the pump diaphragm fixed on mine.
    Side note. Stainless steel clutch lines are a nice enhancement to any MT setup.
  16. Jan 22, 2020 at 5:41 AM
    CS_AR
    Near disaster for the Land Rover yesterday. A runaway truck plowed into the Range Rover and slammed it the Land Rover.
    Many years ago, his grandfather had a new MG destroyed by a run away semi-truck.
  17. Jan 22, 2020 at 5:55 AM
    cruiserguy
    Elijah
    SEKS
    Wtf? What horrible luck???
    CS_AR[QUOTED] likes this.
  18. Jan 22, 2020 at 6:01 AM
    CS_AR
    For sure. Reminds me of the time I had a parked car that got hit by a runaway boat. Some people were pulling a boat down the road and the ball broke off of the trailer hitch and the safety chains broke. The boat and trailer shot across a parking lot and crashed into my car. When I came out, I'm like WTF happened? They were nice and left a note. I didn't see the note until after I got into the car to drive away.
    cruiserguy[QUOTED] likes this.
  19. Jan 22, 2020 at 6:25 AM
    cruiserguy
    Elijah
    SEKS
    Wow, that's bizarre luck too. I could imagine being all worked up with that spineless lowlife that wrecked your car and then get in the car and seeing the note and oh.....they're sorry.... Okay fine I can't be upset with you if you're sorry :anonymous::rofl:
    Kwikvette and CS_AR[QUOTED] like this.
  20. Jan 22, 2020 at 6:25 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    I'm not enamored with the upward sweep of the hoops. I jockeyed mine around (cut some off the upright portion) to get them level across.
    Running Board Man and cruiserguy like this.
