What would you rather listen to instead of Cold Play
This poll will close on Jul 20, 2025 at 7:20 AM.
  1. Nails on a chalboard
    5.9%
  2. Bass boosted memes
    52.9%
  3. Rod knock
    52.9%
  4. Political discourse
    11.8%
  5. That one annoying drunk gal at a comedy club
    11.8%
  6. No i really do like Cold Play and I'm not writing this under duress (help Cold Play is in the room)
    11.8%
Multiple votes are allowed.
  1. Jan 26, 2020 at 9:28 PM
    InAComa2004
    InAComa2004 Well-Known Member
    2004 Toyota Tacoma(Base)
    I'd say that anything that is good with heat is fine
  2. Jan 26, 2020 at 9:28 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I enjoy it, it actually comes apart if it's the spendy stuff. I got ARP stainless studs and hardware for the Z
  3. Jan 26, 2020 at 9:30 PM
    Running Board Man
    Running Board Man Well-Known Member
    Sounds like ill get some for the 4 runner than, the more i take it to the beach the crustier the exhaust gets... its still clean as fuck but not brand new like it was
  4. Jan 26, 2020 at 9:35 PM
    Running Board Man
    20191216_164258.jpg thats the only tube bumper id get
  5. Jan 26, 2020 at 9:36 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    if that full of air i feel bad for whoever readends it
  6. Jan 26, 2020 at 9:38 PM
    Running Board Man
    Why? You see how thick it is and that its got other support/bracing its not gonna burst
  7. Jan 26, 2020 at 9:41 PM
    Empty_Lord
    Dan
    all it takes is the pointy end of something and 50 mph to puncture it.
  8. Jan 26, 2020 at 9:49 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    And god forbid there's fuel that gets ignited... WITH A PRESSURIZED OXYGEN SOURCE!
  9. Jan 26, 2020 at 9:58 PM
    Empty_Lord
    Dan
    i can see a bumper to hold water. compressed air id like to keep under the vehicle.
    away from danger mostly.
  10. Jan 26, 2020 at 10:22 PM
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    So that’s just how manual hub CVs are setup. They have a small c clip that prevents the tripod from falling off. So you tap the tripod downwards after removing the lower snap ring. Then remove the hidden c clip so you can tap the tripod off. Took a while to find pictures of someone rebooting manual hub axles. While I had the CV apart I compared every part to one of my broken CVs. Nothing looked off. So the CVJ axles went back in with Toyota grease, boots, and the boot slide mod.
    Yrfc2Vb6MFNLvSeYNkEVzN2f1dnbOx8jl9V6mB95_78324a3746ef6b49f4e2e547e1d19f46cff1fbce.jpg
    cruiserguy[QUOTED] likes this.
  11. Jan 26, 2020 at 10:31 PM
    Empty_Lord
    Dan
    So. question.
    255/80r17 or 285/70r17 for the tundra... Tires will be happening once the assend is on the taco and the wheels go back on the taco
  12. Jan 26, 2020 at 10:37 PM
    Speedytech7
    255s are too skinny, theyre non-committal big boy tires haha. 285s are decent, still skinny but adequate
  13. Jan 26, 2020 at 10:40 PM
    Empty_Lord
    Dan
    hmm 285 is pushing it with 7" wide wheels though isnt it?
  14. Jan 26, 2020 at 10:54 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    I ran 295/70/17 and now 315/70/17 on 7" 4runner wheels
    Tire chains might not mount them because the chart says you need 7.5" wide wheel :notsure:
  15. Jan 26, 2020 at 10:54 PM
    04Pre_Runner
    Andrew
    Doubt Wal Mart or most major tire places would mount them. At least they won't mount 12.50 wides on 7" wide. Not sure if 285/70R17 is wide enough at 11.2 inches to where you'd need to run lower tire pressure to keep tire wear even.
  16. Jan 26, 2020 at 11:11 PM
    Empty_Lord
    Dan
    I mount them myself. I’d rather not push it though
    04Pre_Runner[QUOTED] likes this.
  17. Jan 27, 2020 at 6:18 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    If you purge from the side will it allow effortless 360's and drifts?
  18. Jan 27, 2020 at 6:19 AM
    Das it mang
    Das it mang Well-Known Member
    Az
    1996 T100 SR5 MT
    Stock again- rip slug
    Real clean! Definitely will serve you well, looks great with the mechanisms showing through the faceplate!
    Just be careful not to bash ur wrists on countertops. I was infamous for doing that and chipped the faceplates on most of my watches as a result lol
    CS_AR and Wulf[QUOTED] like this.
  19. Jan 27, 2020 at 9:00 AM
    Wulf
    rock raisin
    Yeah I do the same. I have been trying hard to remember to take it off when I'm working on things to keep it from getting banged up
    I actually left my cheapy digital watch in her garage because it took it off for changing her truck's oil and forgot to put it back on after :homer:
    Das it mang[QUOTED] likes this.
  20. Jan 27, 2020 at 9:00 AM
    Wulf
    rock raisin
    Running Board Man likes this.
