1st gen Prerunner conversion using 4Runner parts?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gnarlyshredder, May 15, 2016.
  1. May 15, 2016 at 12:03 AM
    Gnarlyshredder
    Gnarlyshredder [OP] Well-Known Member
    Jacob
    SoCal
    1999 Prerunner
    Suspension: Bilstein front/rear 5100's (set at 3" lift) Eibach front coil springs 620lb Toytec 2" add-a-leafs Wheels/Tires: Pro Comp 7069 Series Alloy Wheels 285/75/15r General Grabber AT2s
    I'm pretty new here, and it looks like everyone gets butt hurt when a new thread is started about a topic which already has many threads about it, but I'm going to do it anyways as I haven't found a definite answer to my question.
    I'm in the process of converting my 99 Prerunner to 5 speed 4x4. Original idea right?
    Well I've stumbled across a 1996 4Runnerthat's relatively close that has all the parts I'd need to do said conversion for $850. I've read somewhere on one of the many forums that 3rd gen 4runner parts transfer over to 1st gen Tacomas such as my own.
    Can anyone confirm this before I buy the 4Runner. Are there any parts that won't transfer over? I'd really appreciate the input. Also if anyone has any tips or tricks for this conversion feel free to share your wisdom. Thanks!
    opteron likes this.
  2. May 15, 2016 at 11:27 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
  3. May 15, 2016 at 11:31 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Did any 4 runners come as stick shifts? As for parts in general, they are pretty universal.
  4. May 15, 2016 at 11:32 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    Most of the front end stuff should work fine...i think the differences were body panels and rear suspension but it's been a long time since I deal with that stuff
  5. May 16, 2016 at 8:38 AM
    Gnarlyshredder
    Jacob
    SoCal
    1999 Prerunner
    I believe after 2000, at least for 3rd gens, manual was discontinued.
  6. May 20, 2016 at 9:53 AM
    markmb45
    markmb45 Well-Known Member
    Mark
    Utah
    99 4x4 Reg Cab 3.4, auto, e-locker
    V6,Auto, e-locker 4runner dash, seats
    Yes most of the parts will transfer. I did a 99 regular cab with a 4runner doner vehicle. The hardest part is the wiring harness. I used the 4runner harness and removed what was not needed, ie rear door controls, etc. But gained rear locker, ABS, auto trans, ADD, bucket seats, and center console. The 4runner dash fit, engine and trans I had to move the motor mounts (installed the 3.4). Seats needed a minor modification to work. Didn't have to modify the rear drive shaft. Very happy with the truck.
  7. Jul 9, 2016 at 12:52 AM
    Gnarlyshredder
    Jacob
    SoCal
    1999 Prerunner
    So after more searching I bought a Tacoma frame with all the parts I need that was a lot closer, so I will be starting a new build thread.:thumbsup:
  8. Jul 9, 2016 at 12:57 AM
    Gnarlyshredder
    Jacob
    SoCal
    1999 Prerunner
