1st Gen Spacer Kit on 2nd Gen
Discussion in 'Suspension' started by cormudgen, Jan 1, 2012.
  1. Jan 1, 2012 at 1:10 PM
    cormudgen
    cormudgen [OP] Well-Known Member
    Hi,
    I'm looking at purchasing a 2.5" spacer kit that was previously used on a 96 Tacoma to put on my 2008 Pre-Runner Access cab. I am buying this used (obviously) and the owner does not know any branding. I have looked at the available spacer kits on Toytec’s site and the spacer's seem to be the exact same part for the first gen and 2nd gens.
    **I am aware of the recommendations that typically are against spacer lifts. I will openly admit that I am doing this fully for aesthetics so have no concerns with poor off road performance.
    -Do you see any issues with using this setup on a 2nd gen?
    -Do you know the size of the rear U-Bolts (toytecs site recommends 8.5" for length but does not list width/diameter/thread length etc). I'm hoping to pick up from the local parts store BEFORE I remove the stock ones for comparison
    -For the front, will I be able to use the existing bolts on the top of the struts (are they long enough: from pictures it seems that the spacers already have bolts in them and i'm guessing these just sit on top of existing strut bolts and then have the nuts screw into the new bolts coming from the spacers) and can you confirm I will NOT need a spring compressor to perform this install?
    pics attached of what I'm considering purchasing/installing
  2. Jan 1, 2012 at 1:47 PM
    cormudgen
    Well I asked a few questions, but are you saying. I to he idea at all?
  3. Jan 1, 2012 at 1:50 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    1st gen kit will not fit 2nd gen from what I've read on here.
  4. Jan 1, 2012 at 1:52 PM
    NelsonTacoma
    Tucson, AZ
    Wut?
    Edit. Nvm
  5. Jan 1, 2012 at 1:53 PM
    NelsonTacoma
    Tucson, AZ
    I could've sworn it said 1st gen stuff dorky bolt on 2nd gens.
  6. Jan 1, 2012 at 1:55 PM
    NelsonTacoma
    Tucson, AZ
    If I had a dollar for every time someone said that to me.
  7. Jan 1, 2012 at 1:58 PM
    NelsonTacoma
    Tucson, AZ
    Tomato?
  8. Jan 1, 2012 at 2:01 PM
    NelsonTacoma
    Tucson, AZ
    :sandwich:
    Here you go!
  9. Jan 1, 2012 at 5:09 PM
    cormudgen
    Thanks for the replys. What is the reasoning the 1st gen kit will not work on the 2nd gen?
    From toytec's site it appears that the 2.5" front spacer for a 2nd gen is the exact same part as the one for a 1st gen
    2nd gen here
    1st gen here
    This is the pic they show for that spacer. I'm not doubting you all, just trying to get a better understanding of the suspension differences.
  10. Jan 1, 2012 at 5:18 PM
    NelsonTacoma
    Tucson, AZ
    That spacer goes between the spring and the top plate. The one's you posted earlier go between the top plate and your truck. Two totally different parts.
  11. Jan 1, 2012 at 5:22 PM
    NelsonTacoma
    Tucson, AZ
    Mall crawlin!! Duh!! :homer:
  12. Jan 1, 2012 at 5:23 PM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    I can't attest for the 2nd Gen Tacomas, but I know the bolt circle for the three studs on the shock mounts is larger on my '04 4Runner than my '01 Tacoma.
  13. Jan 1, 2012 at 5:51 PM
    cormudgen
    Thanks for the clarification. This is what I missed! Top spacer vs coil spacer.
  14. Jan 1, 2012 at 5:58 PM
    cormudgen
    As I mentioned above, this is purely for aesthetics. I do not offroad. I use the truck on road quite frequently as a truck which is why I purchased the truck. I occasionaly (once a month) take the truck to some hunting land where I drive some dirt roads and mild trails.
    It was time to replace the stock tires and I decided to go with slightly larger all-terrains for
    1. looks
    2. better traction at the farm as there are some rutted/muddy spots I need to crosss.
    Now to suplement the look of the wheels/tires I am interested in a mild lift FOR LOOKS. I don't see this a much different then doing a BHLM or adding a satoshi grill etc. These things are for looks.
    I've attached some pictures of my truck after the new wheels/tires.
  15. Jan 1, 2012 at 6:00 PM
    NelsonTacoma
    Tucson, AZ
    Anytime. I have a coil spacer on my truck. It rides like crap, but I bought the truck with it installed. Currently saving up for some 5100's so I can ditch the spacers.
