1st Gen Stock Bumper Winch Mount
Discussion in '1st Gen. Tacomas (1995-2004)' started by iwagner, Jan 17, 2017.
Would you buy one?
  1. Yes
    91.8%
  2. No
    8.2%
  1. Jan 17, 2017 at 6:47 PM
    iwagner
    iwagner [OP] Well-Known Member
    Washington
    2002 Tacoma 2.7l 5spd
    I just installed a custom stock bumper winch mount and wanted to share with the community. The winch mount was designed by Evan Hasse (TacoRex) of L.R.FAB and you can view his original post here.
    If you're interested in purchasing a mount, contact Evan at hasse.evan@gmail.com. Great company and a great product.
    The mount came unpainted, here is a picture of it as shipped. It has two heavy duty shackle mounts underneath.
    It was then primed and painted...
    A substantial amount of plastic was removed from the bottom of the front bumper
    The winch was installed into the mount and connected
    The bumper was reattached and skid plate remounted. In all, it took about 5 hours to complete and I'm very satisfied with the results. It's a clean looking alternative if you're looking to keep a stock look. The winch used was a Smittybilt 98495 XRC Synthetic Rope Aviary Photo_131291794830568154.jpg Aviary Photo_131291785794276739.jpg
  2. Jan 17, 2017 at 7:00 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SLC
    2000 ext cab, 2.7L, auto, 4x4
    Looks awesome, brother. Looks very good.
    cruxofthebisquit and Dalandser like this.
  3. Jan 17, 2017 at 7:23 PM
    TacoREX
    TacoREX -TacoREX
    Evan
    NORCAL
    01 Taco 2.7 5spd
    2.5" lift, 285's, CB, DIY HiLift Bed Mount, AllPro Sliders,Warn
    Thanks for working with me on this! Glad to see it mounted and tucked in there so nicely!
    Dalandser likes this.
  4. Jan 17, 2017 at 10:25 PM
    lonelywanderer
    lonelywanderer Well-Known Member
    Oahu, Hawaii
    04 double cab 4wd
    Suppose to be stock
    Looks awesome! Idk why but i always thought the fairlead part came out of the opening on the valence not below it. Gonna have to put one of these on my wish list for when i finish up my suspension
  5. Jan 17, 2017 at 10:45 PM
    Mikeybuck
    Mikeybuck Well-Known Member
    SW WA
    2018, 2010, Tacoma
    If I didn't have a plate bumper, this would be perfect. I've always liked the hidden winch mounts.
  6. Jan 18, 2017 at 4:36 AM
    BossFan
    BossFan Well-Known Member
    Frank
    NJ
    03 TRD 4x4 X-Cab MT swap
    Tundra brakes Bilstein 5100s OME springs
    Looks great! I've been on the fence about a front plate bumper and really like the look of this hidden winch! Nice job!
  7. Jan 18, 2017 at 12:04 PM
    TurtleTruckTraveler
    TurtleTruckTraveler Well-Known Member
    2002 White Extra Cab V6 4x4 TRD w/ Custom aluminum cabover shell
    Super clean. Well done tacorex. But the real question is how much does it bench? (First photo in thread)
    TacoREX, WildLand and iwagner[OP] like this.
  8. Jan 18, 2017 at 12:34 PM
    Ktaco
    Ktaco Well-Known Member
    New Brunswick, Canada
    03 Black 4x4 TRD SR5 Xtra cab.
    Grey wire mod, Deck plate mod, diff breather mod. K&N air filter. Toytec coilovers. AAL. Custom rear lift shackles. diff drop. Centerforce clutch. Superwinch LP8500 with custom "behind bumper" mount. Winch solenoid relocation with in cab winch control. 33x12x15 Duratracs. Aisin manual hub swap.
    Pretty much like what I built but more fancy. Except it looks like your sits under the frame. Clearance and approach angle was very important to me so I installed mine in line with the frame. Nice work.
  9. Jan 18, 2017 at 4:54 PM
    ekul310
    ekul310 Well-Known Member
    Luke
    Pennsylvania
    2002 Lunar Mist Regular Cab 4x4
    Stock stock stock
    How many bolts holds this mount to the frame? It looks like 3 per side from the pics.
  10. Jan 19, 2017 at 8:22 AM
    iwagner
    Washington
    3 per side, two from the bottom and one from the front. Fits exactly where Toyota subframe was bolted in.
  11. Jan 19, 2017 at 8:25 AM
    iwagner
    Washington
    My clearances didn't change at all. The mount is slightly higher than the bottom of the front bumper and the skid plate mounts to it.
  12. Jan 19, 2017 at 8:09 PM
    gmr102
    gmr102 Well-Known Member
    Utah County
    Formerly: 2002 Silver Stepside TRD OR Ext Cab V6 Current: 2008 Lexus GX470
    This is awesome. I love the idea of not having the winch add another 10 feet (exaggeration I know but that is what it feels like) to the front of my truck. adding to the list of mods I want.
  13. Jan 22, 2017 at 7:40 AM
    02Taco4x4Trd
    02Taco4x4Trd Well-Known Member
    J
    2015 Tacoma Trd 4x4
    How much? How much of the plastic valance did you have to cut out, all of the middle? I wonder if my Warn would fit, it looks a little bit taller but it might just be me. Will you take some more pictures when you get a chance and post them please?
  14. Jan 22, 2017 at 12:48 PM
    iwagner
    Washington
    I had to cut a 33" long and 2" high section out of the bottom and then slightly more to have the fair lead fully exposed in the middle, about anoth 1.5" x 7".
  15. Jan 23, 2017 at 5:31 AM
    02Taco4x4Trd
    J
    2015 Tacoma Trd 4x4
    I am a little new to the forum but have been driving and working on trucks for 20 years. I really like the way yours turned out, Painting it black, etc... Made a lot of difference. If you don't mind just so I can see what it looks like up-close & Personal, would you take some more pictures for me like from the front, side, underneath, different angles and you can post them or email me at jwg212121@gmail.com I would really appreciate it. I have a winch right now but I don't was to mount it in front of the bumper on a big bracket that will get hung up on stuff and probably forget it's there when I go to park and bam, besides those weigh so much and I don't want to add much more weight to the truck. I have the 3.4 V-6, 4.10's Trd but I am used to V-8s This is the first V6 I have owned, I have owned 6 Chevys in the 8 years and one of them I kept for 3 of those years. I can really tell a difference, but I try to baby her but it just seems like when I have gotten down on it the couple times I did, I was a little disappointed. Sorry for going on and on.
    Thanks,
    Joe
    jwg212121@gmail.com
  16. Jan 23, 2017 at 5:48 PM
    iwagner
    Washington
  17. Jan 23, 2017 at 5:48 PM
    iwagner
    Washington
    Here's one, I'll post more tomorrow
  18. Jan 23, 2017 at 8:50 PM
    arifleman
    arifleman Well-Known Member
    Pacific NW
    2002 TRD 3.4L Ext Cab
    Wow, slick, real nice!
  19. Jan 24, 2017 at 4:40 AM
    Flat four 56
    Flat four 56 New Member
    Justin
    2004 Tacoma TRD double cab
    I am very interested in this. As far as I've seen, no one else produces one.
  20. Feb 7, 2017 at 9:31 AM
    02Taco4x4Trd
    J
    2015 Tacoma Trd 4x4
    That looks really good. I have a Warn M6000 it looks to be about the same size as the Smitty so it shouldn't be a problem, I will just have to move the box/plug like you did. Mine sits on-top of the winch motor right now. If you get a chance to take some more pictures I would love to see it from a coupe different angles up close. Guess I'm going to have to start putting a little $$ away here and there so I can get one.
    Thanks,
    Joe
