1st gen Tacoma clutch
Discussion in '1st Gen. Tacomas (1995-2004)' started by Itstaco, May 12, 2017.
  1. May 12, 2017 at 3:44 PM
    Itstaco
    Itstaco [OP] Small Build Tacoma
    Ken
    2001 Tacoma
    Cold air intake, dual exhaust, fog light mod, -44 offset on 33.12.50.20
    My clutch just went out and lost pressure on the pedal. I can hear the throw out bearing is worn out. Looking to upgrade to a stage 2 clutch. Any recommendations and advice I should do while the transmission will be down? It's going on a 2001 Tacoma 2.7L extended cab 4x4
  2. May 12, 2017 at 5:10 PM
    Matermax
    Matermax Well-Known Member
    Nathan
    NE Arizona
    1999 Tacoma TRD
    White Line LCA bushings.
    How many miles? I changed the rear seal on the motor when I did mine.
    boostedka and Dalandser like this.
  3. May 13, 2017 at 7:06 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  4. May 14, 2017 at 7:07 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Get a replacement stock clutch. Most "upgraded" clutches aren't an upgrade at all because they are heavier and grab hard. I've used both Exedy and Aisin with good results.
    Marlin is the exception to the rule because his mixes and matches parts to build the best combo.
  5. May 14, 2017 at 10:16 AM
    Matermax
    Nathan
    NE Arizona
    1999 Tacoma TRD
    I replaced mine with an Aisin at 300k, feels just like the stock one when it was newer.
  6. May 14, 2017 at 10:21 AM
    Wulf
    rock raisin
    I put an Exedy clutch in my truck and have been very content with it in traffic and off-road.
  7. May 14, 2017 at 1:21 PM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    Mine had an exedy in it when I got it. I changed trying to get rid of a notchy 1-2 shift (think I need to go in and replace damaged syncro parts). Used oem (from Toyota) and really REALLY like it better. Softer clutch pedal (not sure if the pressure plate is softer or what but it's very fluid and has almost no resistance). I even got a compliment from a lot porter at Toyota. Still grabs nicely and I've towed probably past my limit with it - no issues.
  8. May 14, 2017 at 1:32 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    The stock clutch is fine for 98% of the people out there. When I say stock I mean OEM Toyota and not the garbage you find at Cockauto or Oh'Reallys
    FirstTimeFirstGen likes this.
  9. May 14, 2017 at 1:41 PM
    FirstTimeFirstGen
    David
    Pacifica
    What 2% would you say the stock wouldn't work for? I'm thinking about doing 1 ton axles but with the right gearing I'm hoping my clutch should still be fine. that's the most extreme example I can think of and I think the stock clutch should still work great
  10. May 14, 2017 at 1:44 PM
    Itchyfeet
    With one tons I'm assuming you're going to be blowing over rocks n stuff. In that case I would go aftermarket.
  11. May 14, 2017 at 1:53 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I used the following and I love it. Higher holding capacity with the V6 PP and smooth stock like engagement.
    Aisin 3rz disk
    Aisin 5vz pressure plate
    Timken Throw out bearing
    Timken pilot bearing
    Luk flywheel
    I replaced the rear main seal while it was opened up. I also replaced the shifter bushing with a marlin crawler bushing and installed a URD short shifter as well. Truck shifts awesome now. Altogether everything cost about $350
    FirstTimeFirstGen and Dalandser like this.
  12. May 14, 2017 at 2:27 PM
    Wulf
    rock raisin
    hmmm the clutch that I took out was an Aisin one and I haven't noticed a huge difference ¯\_(ツ)_/¯
  13. May 14, 2017 at 2:29 PM
    FirstTimeFirstGen
    David
    Pacifica
    Your pedal doesn't feel stiffer with the exedy? There's was a very noticeable difference when I swapped mine
  14. May 14, 2017 at 4:43 PM
    Itstaco
    Ken
    2001 Tacoma
    My truck has 224k. I was looking at the OEM clutches and wasn't sure if I should get that or get SPEC clutch. I think I'm going to do the rear main seal to then. I've been told I shouldn't drain the gear oil out of the transmission and get new gear oil. What do you think?
  15. May 14, 2017 at 4:47 PM
    Itstaco
    Ken
    2001 Tacoma
    I've heard a lot of people use EXEDY clutches. Is it good for a lot of road driving?
  16. May 14, 2017 at 4:50 PM
    Itstaco
    Ken
    2001 Tacoma
    How much did the short shifter run you?
  17. May 14, 2017 at 4:55 PM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Stick with stock or a mash up like @boostedka has. You want the longest, softest engagement you can get in the rocks. That way you can take slack out of the drivetrain easily and not have a left calf twice the size of your right after a day of wheeling.
    Long sad story, but I had both clutches new in my truck back to back in one night and I didn't feel any difference at all between then.
    Go Aisin or Exedy, you can't go wrong with either. Aisin one has a nicer throw out bearing and the Exedy has a nicer pressure plate that has metal retainers for the springs instead of plastic.
    Don't mess with the rear main if it isn't leaking, greater chance of you causing a leak putting it back together than if you just leave it alone IMO.
    Yes, drain your old oil out and replace with a GL4 oil like Redline MT90 that is friendly to the brass synchros.
  18. May 14, 2017 at 5:22 PM
    Itstaco
    Ken
    2001 Tacoma
    How many qt's did you have to use for the transmission?
  19. May 14, 2017 at 5:25 PM
    Itstaco
    Ken
    2001 Tacoma
    Did you tilt the from of the transmission and pulled it down, or took the bed off and pulled it from the back of it, or could you just slide it back just enough to work on the clutch? Where do you measure to get the right clutch size, I've seen there's a 9 1/4" or a 10".
  20. May 14, 2017 at 5:50 PM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    3 or 4, it's in the manual.
    What? Use a trans jack and pull it straight out. You need a universal joint and a lot of extensions to get the bolts out.
