1st gen tundra trd coilovers in 2002 tacoma pre-runner
Discussion in '1st Gen. Tacomas (1995-2004)' started by tpoore, Feb 17, 2011.
  1. Feb 17, 2011 at 8:27 PM
    tpoore
    tpoore [OP] Active Member
    T
    Santa Cruz C.A.
    2002 tacoma pre-runner + 2006 tundra 4x4 dcab
    Tacoma is stock currently but will change, Tundra lifted, exhaust, ect....
    hello,
    I was wondering if any one has put the stock trd tundra coil overs in a 1st gen tacoma. My bro has the set off his truck and they are just sitting around. I would imagine that it would stiffen up the ride but not sure how it would affect ride hight. Any ideas would be great thanks - thoams
  2. Feb 17, 2011 at 8:55 PM
    tpoore
    T
    Santa Cruz C.A.
    I am going to give it a shot this weekend, but before i try i thought i would see if others have had any luck with it.
  3. Feb 17, 2011 at 8:57 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    are they the same diameter?
    are they the same length?
    they might be the same length, but stiffer, therefore they won't compress or sag under weight, and will give you some lift.
    someone's gotta try it!
  4. Feb 17, 2011 at 9:04 PM
    tpoore
    T
    Santa Cruz C.A.
    I will look into more closely this weekend and let you know what i find. Thanks for the ideas.
  5. Feb 18, 2011 at 12:09 AM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    a couple guys on CT tried that set up about 7 years ago...
    they were all street queens as the ride was horrible according to a couple of them...
    they bolt in just fine, but the spring rate and the length of the shock and spring assembly itself is longer than a tacoma, so it put a lot of stress on the lower arms...
    supposedly, it rides ok for the first 10,000 miles, then you start to kick yourself for not investing in tacoma adjustable coilovers...
  6. Feb 18, 2011 at 12:11 AM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    and to your original question, ride height is increased by about 3 inches...
  7. Feb 18, 2011 at 8:14 AM
    tpoore
    T
    Santa Cruz C.A.
    Hey thanks a ton for the info. I was kinda thinking that was case but not sure and they are free but i think i will hold off and buy the real thing. thanks.
  8. Feb 18, 2011 at 12:55 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I don't know how the 1st gen tundra trd stockers are but I run 5100's for 1st gen tundras on my 2000 with excellent results....;)
  9. Feb 18, 2011 at 3:03 PM
    tpoore
    T
    Santa Cruz C.A.
    When you say that it puts a lot of stress on the lower arms is this a result of the lift or because of the stiff ride. I mostly drive on the street and when off roading it is mostly forest roads not true "pre runner" type driving. If i did the mod would i have to worry about the lower arms giving out. I have a three inch on my tundra "fab tech" and is that puting the same stress as the this would be on the tacoma. Hope this makes sence and thanks for the help.
  10. Feb 18, 2011 at 4:56 PM
    mikesdoublecab
    Mohawk Mike
    Glendale, CA
    yah, its more a result of the lift... as the shock assembly on a tundra is longer, the space between the upper shock mount and the lower arm on the tacoma, is shorter than the tundra shock assembly's length...
    even on streets, every speed bump and pothole will be jarring... the tundra, being heavier, may also have a different spring rate..
