1st oil change and oil filter?
Discussion in 'Technical Chat' started by clayj, Jul 14, 2007.
  1. Jul 14, 2007 at 8:04 AM
    clayj
    clayj [OP] Member
    finally hit 5000 in my 07 tacoma. took to dealership for oil change and tire rotation and they give me some crap about tires for life program but what they charged me for oil change and tire rotation$75.00 i could buy tires myself and save money i think. and they put synthetic in without letting me know. so ill start changing myself, so should i atleast buy toyota oil filters? thanks
  2. Jul 14, 2007 at 8:18 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    What makes you so sure they put synth in? Because they told you they did? I never believe anything the $tealer says.
    As for your filters, yeah, OEM filters are a very sound decision since your truck is still under warranty.
  3. Jul 14, 2007 at 8:25 AM
    clayj
    clayj [OP] Member
    yes they told me they did, but a dealership never lies. haha
    what weight should i use i read where they changed it to 5w20 from 5w30 and my cap says 5w20 and 0w20. i probably just go with mobil synthetic next time.
  4. Jul 14, 2007 at 8:29 AM
    humanoid
    humanoid bite me
    Sunny SoCal
    Either one weight oil will suffice, but read your owners manual to be certain. 5w and 0w aren't really that different. Mobil 1 would be an excellent choice.
  5. Jul 14, 2007 at 8:33 AM
    clayj
    clayj [OP] Member
    thanks for your help
  6. Jul 14, 2007 at 11:45 AM
    SLOTaco
    SLOTaco Ultimate Member
    Central Coast, California
    06 TRD Sport
    '06 TRD Sport 4x4 AC, K&N drop in air filter, Magnaflow cat back, Bilstein 5100's with Toytec adjustable front coil over 3" lift, rear TSB, AllPro UCA's.
    Mobil 1 is a great choice. You don't have to use an oem filter while maintaining warranty, but the oem will be a quality filter.
  7. Jul 24, 2007 at 11:22 AM
    JACKJMP
    JACKJMP New Member
    I am comming up on my first oil change and what do you think about SYNTHETIC PENNZOIL 5 W 30 ?
  8. Jul 24, 2007 at 1:50 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i run mobil1, but ive heard good stuff about the new pennzoil platinum. if i can find a deal on it, i may switch to it at my next oil change.
    as far as you go, either way, a synthetic will be really good for your truck! also, the k&n and mobil1 filters are also good, as is the oem filter. just dont use a fram filter.......junk! jmo!
  9. Jul 24, 2007 at 4:18 PM
    sataco
    sataco Well-Known Member
    san antonio tx
    06 SR5 PRERUNNER, ARMOR LID, UWS SIDE STEPS,
    just had my first oil change and now my maint reqd light flashes a little while after start up (about 20 seconds) is that normal? i checked the oil level, what kind was put in and the filter and nothing appears wrong. anyone else have this happen?
  10. Jul 24, 2007 at 4:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  11. Jul 24, 2007 at 7:17 PM
    sataco
    san antonio tx
    a million thank yous for the quick help it worked out great.
  12. Jul 24, 2007 at 7:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    glad i could help ya!!
  13. Jul 24, 2007 at 7:31 PM
    sataco
    san antonio tx
    after about ten minutes of cleaning and numerous paper towels i discovered
    that there is a drain plug under the oil filter housing to empty any oil from the old filter!! i felt like an idiot, good thing no one was around.
  14. Jul 24, 2007 at 8:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, there are alot of people who didnt realize that there was a plug underneath:D and got oil all over the place. dont feel too bad, at least you didnt do like a buddy of mine and leave the drain plug out and get oil all over your driveway!!
    what alot of folks have done is to install a length of clear hose or a quarter inch fuel line from the plug to the bottom of the truck where if any oil comes out, it will be easy for it to go into the drain pan. i havent done it yet, but i may. just a thought.
  15. Aug 21, 2007 at 8:49 PM
    mugu07taco
    mugu07taco Member
    what is this drain plug under the filter everyone speaks of??? Just did my first oil change today and made a mess with the filter. Pics would be nice, I have an 07'.
    Thanks, Dave
  16. Aug 21, 2007 at 9:00 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Have the V6? If so remove the engine cover (2 10mm nuts) and reach under where the oil filter screws on and feel for a little rubber cap. Remove that and put a little cup underneath to catch the oil. Or wait about 24 hours and all the oil will drain out of the filter.
  17. Aug 22, 2007 at 2:16 PM
    sataco
    san antonio tx
    if it's like mine it will be under the filter housing like this
    i have the V6 jus pull off the black cap and drain the oil from the splash guard.
  18. Aug 29, 2007 at 8:59 AM
    mugu07taco
    mugu07taco Member
    I have the 4 banger. Don't have 24 hours to wait, I change the oil on base at the auto hobby shop. This plug must be a V6 thing.
    Me like pictures.
    Thanks, Dave
  19. Aug 29, 2007 at 9:07 PM
    boxcar
    boxcar New Member
    Central Indiana
    '01 SR5 4x4 TRD Silver v6 auto
    tinted windows,bed cover,& vent shades
    Are these plugs common on '01 V6s?
  20. Aug 29, 2007 at 11:02 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    No plugs on the 1st gen Tacos.
