1st oil change? how many miles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deadbolt, Jul 9, 2008.
  1. Jul 9, 2008 at 4:53 PM
    deadbolt
    deadbolt [OP] do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    I know this has probably been asked many of times.
    When did you guys do your first oil change? At how many miles?
  2. Jul 9, 2008 at 4:54 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
  3. Jul 9, 2008 at 5:13 PM
    deadbolt
    Socal
    yah most people do it around 5k.
    however i have seen people say they changed theirs at 500,1000,1500. basically at really low mileage.
    my cousin use to tell me that he woudl change his oil at after he reached 1k due to the imperfections and the shards of metal that are still lingering through the oil.
  4. Jul 9, 2008 at 6:07 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    1500. Any metal or contaminants from initial break in will be in that break in oil.
  5. Jul 9, 2008 at 6:27 PM
    Wolfpack
    Wolfpack Well-Known Member
    Las Vegas
    08 Prerunner
    I've always done the "Jiffy Lube" thing, I'm thinking dealer on this truck though. Do you guys do the 5k intervals at the dealer or quicky lube joints?
    PS, I'm not doing it myself.
  6. Jul 9, 2008 at 6:31 PM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    Jiffy lube sucks!!
    do it ur yourself or a garage!!!
    use sythnetic... long intervals... they last a long long time!
  7. Jul 9, 2008 at 6:37 PM
    Taco969
    Taco969 Well-Known Member
    6 months for me, i dont do a lot of driving!
  8. Jul 9, 2008 at 6:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2!:)
  9. Jul 9, 2008 at 6:48 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Why you shouldn't go to Jiffy Noob: http://www.knbc.com/investigations/8881193/detail.html
  10. Jul 9, 2008 at 6:59 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    I had about 1200 miles on the truck for the 1st change. Will change every 4-5K from now on depending on use and abuse. Plan on running Castrol GTX 5-30 for now with Toyota filters.
  11. Jul 9, 2008 at 7:16 PM
    CometKat
    CometKat Well-Known Member
    Carson City NV
    08 Tacoma 4X4 Regular Cab SR5
    Jiffy Lube sucks. I bought a car once with all the receipts including oil changes from Jiffy Lube. Once I got the car home and looked it over more carefully I determined Jiffy Lube had done nothing from their check list (checking the water in the battery, lube, etc.)
    On oil changes I used multiples of 833. So the first change was 833. Next will be 2500 (833 x 3). Then 5000 (833 x 6). After that I will change the oil every 2500 to keep in sync with the Tacoma maintenance schedule. I know some people will say 2500 is too often but I only drive my truck about 5000 miles per year.
  12. Jul 9, 2008 at 7:32 PM
    Wolfpack
    Las Vegas
    08 Prerunner
    That's why I'm asking if you guys go to the dealer, those of you who don't do it at home.
  13. Jul 9, 2008 at 7:39 PM
    CometKat
    Carson City NV
    I did mine at home. Changing the oil on my Tacoma is easy. I’ll probably do the lubes also since I have a grease gun setup for my air compressor.
  14. Jul 9, 2008 at 9:02 PM
    deadbolt
    Socal
    Yah. I have about 1200 miles on my car as of today. I think ill change the oil out at 1500.
  15. Jul 9, 2008 at 10:30 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Well you're certainly better off going to the dealer than you are Jiffy Noob.
  16. Jul 9, 2008 at 10:32 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    5 k ! :d
  17. Jul 10, 2008 at 12:33 AM
    1bad03snake
    1bad03snake Well-Known Member
    Baytown,TX
    4x4 TRD
    none but please give me your info.
    I called the stealership last week they said 5K
  18. Jul 10, 2008 at 1:21 AM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    1st oil change I did at 3,000. Every oil change after that, when the service light comes on at 5,000 miles. 88,000 miles & still kicking without a problem.
  19. Jul 10, 2008 at 2:58 AM
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    First oil change I did @ 500 and the next @ 5000 miles. I do them myself and I'm going to switch to the 3000 mile interval I've always used not the Toy recommended 5000.
  20. Jul 10, 2008 at 3:00 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I did my first oil change at 3K.... everything after that has been 5,000 (per the manual).
