1st oil change question...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcass77, Mar 30, 2008.
  1. Mar 30, 2008 at 5:32 PM
    bcass77
    bcass77 [OP] Member
    Ft. Collins, CO
    06 SR5 4x4 2.7
    Hi all. First post... recently got an '06 tacoma! I just did my first oil change. Truck is a 2.7L 4x4. The manual calls for 6.1 quarts of oil with a filter change. I put in just under 6 quarts and I'm at the high mark on the dipstick. Is this okay? Is it likely that all of the oil didn't drain out? Are you guys able to get the full 6.1 quarts in? Thanks for the help!
    Brian
  2. Mar 30, 2008 at 6:39 PM
    Zebra
    Zebra Well-Known Member
    Millington, TN
    2008 Tacoma 2.7L 4x2 Reg. Cab 5-speed
    Volant ram air and CAI setup, Fumoto oil drain valve, Pioneer DEH-3900MP
    i put in 6 quarts of amsoil 0-20w and mine is still on the high side 3k miles later
  3. Mar 30, 2008 at 7:27 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    You're probably right in thinking you didn't get every drop of the old oil out. +/- .1 quarts (3.2 ounces) won't bother your truck.
  4. Oct 7, 2008 at 10:34 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
  5. Oct 7, 2008 at 6:53 PM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    did u run it before u checked? start it let it run then shut it down and let it sit. the oil filter holds some oil if u just changed it added oil and checked it without running it your level will be a little high.
  6. Oct 7, 2008 at 8:00 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    I use 6 quarts and call it good. My dealer told me 5.5 was the amount I was supposed to use, but I didn't like having the 1/2 quart leftover, and the manual calls for 6.1, so I just use 6 and it works fine.
    Those manuals are (obviously) not accurate on many things. My OM calls for 2.3 quarts of ATF when doing a drain and refill, but 4 quarts came out when I drained it :eek: Go figure....
