2.25" lift kit from "Fat Bob's Garage" for $129 ???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bmkshort, Mar 21, 2009.
  1. Mar 22, 2009 at 7:58 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Any top plate spacer is going to lengthen the stock shock/spring combo. When you lengthen the assembly, it stresses the ball joints, and can cause breakage od the shocks as they try and extend further than they can. Look at what happened to 06Bluez truck. Also, search around on TTORA and you will see damage caused by this type of lift. why they say it is fine (if its a top plate lift), I dont know. The 5100's preload the OEM spring to achieve lift, but they are valved for the preloaded spring rate, thus giveing a better ride.
  2. Mar 22, 2009 at 8:04 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  3. Mar 22, 2009 at 8:08 AM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    That's what I plan on doing. I'm only looking for a couple inches up front after I get the TSB done.
  4. Mar 22, 2009 at 8:41 AM
    bmkshort
    bmkshort [OP] Active Member
    southeast virginia
    09 d-cab 4x4 offroad
    I could be wrong, but judging from the pics on that link, the extra angle on the ball joints in the upper control arm are whats causing the problem. Do they make aftermarket ball joints that are longer to compensate for the lift???
  5. Mar 22, 2009 at 8:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not that I know of. The only alternative is a UCA with a Uniball joint.
  6. Mar 22, 2009 at 12:19 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    I did not know this! Thanks for your info in these spacers. I was looking at ToyTec 2.5" lift with the aal's. I think I will go w/the 5100's. What would you recommend if I have not had the rear tsb done? What would you set the 5100"s @ ? I'm thinking of adding 1 aal and going w/the 5100's.
  7. Mar 22, 2009 at 1:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Check out some of the folks on here that may have them installed, and see what they are running. AAL is the best rear lift option for the money.
  8. Mar 22, 2009 at 4:34 PM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I keep hearing it over and over and just need to dive in and do it.
    Easy enough...5100's all around and the Toytec AAL for trucks WITH the TSB = about $350 plus the cost of an alignment. Set the front at 2.5 and it should be leveled out or a slight rake forward.
    I'm not replacing the stock Sport rubbers but it should still look fine.
  9. Mar 23, 2009 at 1:01 PM
    BaseballFan
    BaseballFan Active Member
    I'm happy with my spacer lift. It does not lengthen the shock. It bolts above it without having to compress the springs. http://www.extremetrucktoys.com/5-6_tac_lift.htm
    I just added Spidertrax and 285/75r16's also.
    P.S. I don't see alot about this lift on TW, but I like it.
  10. Mar 23, 2009 at 5:19 PM
    bmkshort
    southeast virginia
    How long have you had it? Have you noticed any thing unusual as far as wear or anything with the upper arm control ball joints thats been discussed.
    I'm still thinking about those kits if I can get a better understanding of how the spacer lifts put more wear on the ball jonts vs. the Bilstein 5100 or the longer coils.
  11. Mar 23, 2009 at 7:01 PM
    Hydrabyte
    Hydrabyte Well-Known Member
    Florida
    1987 4Runner
    My 09 is done for now, I think.....
    Billi's @ 2.5, TSB & 1.5" AAL from Toytec on stock wheels/tires. Ride is a lil stiffer but then again its a truck
    I did order the Toytec adjustable CO's but have now changed my mind and will not install them. As soon as the missing parts arrive (SBR-129 - Front swaybar relocate kit:) chances are I will post them here for sale[​IMG]
  12. Mar 23, 2009 at 7:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes, It effectively lengthened your shock/spring assembly. How do you think yuou got the lift? By makeing the assembly longer, thus lifting the front.
  13. Mar 23, 2009 at 8:18 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    i think what he's saying is that since the spacer goes on top of the whole assembly instead of compressing the spring itsself, while the whole assemply is now longer, the shock absorber itsself is not extended further than normal while sitting still.
  14. Mar 23, 2009 at 8:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That could be, but a top plate lift, at the least, wears out ball joints.
  15. Mar 24, 2009 at 3:45 AM
    #35
    lasllc
    lasllc Wait. . what’s wrong here
    Southwest RedRocks
    13 SuperWhite DCSB Sport TRD
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    several old addages come into play here:
    You get what you pay for.
    Buy cheap , buy twice; and, more than likely, buy agaon to fix what the cheap crap caused to break.
  16. Mar 24, 2009 at 5:13 AM
    #36
    TacticalBacon13
    TacticalBacon13 Sorry for party rockin'
    Dunk
    Beech Creek
    2014 tundra platinum
    baby seat and a muffler
    have you every bought anything from a person who puts fat in front of there name? i know i haven't but it cant be good.
  17. Jul 28, 2009 at 1:36 PM
    #37
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    2021 TRD Off-Road 2wd Cement Grey
    Bilstein 6112/5160 set at notch 2/3, OEM TRD Pro Wheels, 275/70/17 Falken Wildpeaks, OEM TRD Pro Grill, Debadged, Ceramic Tinted Windows
    Well I did put 40,000 on an 06' 4x4 4runner with mild offroading with not problems using a daystar kit that uses top plate and coil spacer. I would not think you would have a thing to worry about if you drive a street truck that seldoms goes offroad.
  18. Jul 28, 2009 at 1:50 PM
    #38
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    now i have a question. since im running a top plate spacer/block lift now, im going to have to upgrade. ive originally thought about going with the complete ome 885/aal lift for the 3". but after seeing what bilstein's set at 2.5" and a 1.5" aal, i think that lift is pretty nice too.
    so my question, aside from the fact that the bilsteins won't provide as much lift, which lift (complete ome or bilstein) is better for ride quality, durability, and which will last the longest before needing to be replaced or what not.
    its kind of a nueb question but ive never asked
  19. Jul 28, 2009 at 2:52 PM
    #39
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think the OME will ride better than the 5100.
  20. Jul 28, 2009 at 3:14 PM
    #40
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    I am 06Bluez and this is what happens when you go offroad with a spacer lift.
