2.4L turns over fine, then dies
Discussion in '1st Gen. Tacomas (1995-2004)' started by seligman, Jun 4, 2010.
  1. Jun 4, 2010 at 6:19 PM
    98tacoma27
    Ben
    Not Beech Creek
    The OEM Denso is $125 at rockauto.com and $200 at advanceauto.
  2. Jun 4, 2010 at 6:24 PM
    seligman
    seligman [OP] Well-Known Member
    Thanks...
    Any idea how difficult it is to replace?
  3. Jun 4, 2010 at 6:26 PM
    98tacoma27
    Ben
    Not Beech Creek
    Removal Install Some people opt to remove the bed vs dropping the tank.
  4. Jun 4, 2010 at 6:43 PM
    seligman
    Should I check anything else before getting too far ahead of myself?
    For instance, could the Fuel Pressure Regulator be bad?
  5. Jun 4, 2010 at 6:48 PM
    98tacoma27
    Ben
    Not Beech Creek
    You tested that with the vice grips.
    This is how you test the pump. It's not readily easy to do, but if you had a pressure gauge you could do it.
  6. Jun 5, 2010 at 10:05 AM
    seligman
    What would you recommend, remove the tank or remove the bed?
    For one, I have at least 9 gallons in the tank right now. I also have the OEM plastic bedliner...not a big deal to remove, I suppose.
  7. Jun 5, 2010 at 10:20 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    i would check for voltage at the pump first,could be a main relay
  8. Jun 5, 2010 at 10:41 AM
    seligman
    You're talking about EFI correct?
  9. Jun 5, 2010 at 12:33 PM
    seligman
    I showed my dad what was happening by pinching the return hose to get it started. I gave it some RPM's and it stayed running for about 5 minutes. Under power it sounded and felt pretty normal, but after I took my foot off the gas, the idle was rough and irregular, even though it stayed running.
    In the side mirror, I got a glimpse (and my dad verified) that when I rev the RPM's, there is blueish-white smoke coming from the tailpipe. Not a lot, but it's there. The check engine light is still lit too. All of this is with the fuel return hose pinched.
    Should I be worried?
  10. Jun 5, 2010 at 2:12 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Head gasket? White smoke is burning coolant and blue is burning oil. Are you sure it wasn't condensation?
  11. Jun 5, 2010 at 4:18 PM
    seligman
    Removed the bed, hooked a meter to the fuel pump -- while still installed to the tank -- and got these results:
    My father has a fuel pressure gauge from his old Chevy truck. He doesn't have the adapters to connect it as the service manual describes. However, he hand held the gauge to the fuel line return on the regulator. With power to the fuel pump, the gauge was showing approx 70 PSI. Today there was lots more fuel spillage than I remember from yesterday. We tried this test a second time...70 PSI.
    If I understood the post from yesterday, this should be 38-44 PSI.
    Our reasoning is that the gauge, being handheld, is reading less pressure because it's not securely fastened. Therefore, the PSI might be significantly higher when everything is connected.
    Do you think this is sufficient evidence to show that the Fuel Pressure Regulator is bad?
  12. Jun 6, 2010 at 8:21 AM
    98tacoma27
    Ben
    Not Beech Creek
    When you check the fuel pressure per the FSM, it is actually done before the regulator which means you will see a lesser pressure (38-44). Since you measured the pressure at the regulator, I would expect to see the pressure that high. The OE style regulator is about $100.
    If you have access to a compression tester I would check each cylinder to verify the HG is ok. A quick test (but isn't always accurate) is to start the truck with the radiator cap off. If you see fluid shoot out, the then head gasket is bad. The compression tester is the best way to test this though.
    Seeing how you were able to get it running by pinching the return hose, I think you may have found the problem. FWIW, the white/blue smoke could be a result of the over-pressurization of the fuel line. That would explain why it ran normal under load and rough and irregular at idle.
    I would still check the compression to rule out the head gasket. It will at least give you a baseline for future reference.
  13. Jun 8, 2010 at 12:47 PM
    seligman
    OK, with the pressure gauge in the proper position:
    -Turning the key to the "ON" position without starting the truck: 0 PSI
    -After pinching the return line to get the truck to start, at idle: 46 PSI
    -Reving engine up after idling for a little bit: 46-48 PSI
    -After shutting engine off: fairly rapid decrease to 0 PSI
    What do you think, still a bad fuel pump?
  14. Jun 8, 2010 at 1:04 PM
    98tacoma27
    Ben
    Not Beech Creek
    Did you have the pump connected to the battery when you did the IGN on (non-start test)?
  15. Jun 8, 2010 at 1:19 PM
    #35
    seligman
    For this pressure test, the fuel pump was installed, connected, and powered the usual way.
    Over the weekend, when we put a meter across it, we used a battery.
    For the record, I've yet to pull the fuel pump out of the tank. All testing has been done from the outside.
    Hope this helps.
  16. Jun 8, 2010 at 2:31 PM
    #36
    98tacoma27
    Ben
    Not Beech Creek
    Ok, try this. Wire the pump directly to the battery per the FSM test. Turn the IGN to ON but do not start. Record the pressure reading. Then pinch the return line on the regulator and do the same test (DO NOT START, JUST IGN TO ON POSITION). Record the reading and post back.
  17. Jun 8, 2010 at 6:36 PM
    #37
    humtaco
    humtaco Well-Known Member
    You can have good pressure but have a low volume of gas flowing. Disconnect the fuel line at some point and stick it in a large jar or glass bottle and see what kind of continuous flow you get. If it starts out strong and begins to peter out there may be a restriction in the line of filter. Did you happen to run very low or out of gas lately?
  18. Jun 25, 2010 at 3:06 PM
    #38
    seligman
    OK guys, I've been dragging my feet getting the truck fixed.
    I did the test you suggested powering the fuel pump with a 12V battery and turning the ignition to ON. Result = 46 PSI.
    Then I pinched the return hose and repeated the test. Result = 72 PSI.
  19. Jun 25, 2010 at 3:09 PM
    #39
    seligman
    I put a jar underneath the return line and watched the flow. To the eye at least, it looks good. Nothing out of the ordinary.
    No, I haven't run low on gas recently. The failure took place with more than 3/4 of a tank.
  20. Jun 28, 2010 at 1:41 PM
    #40
    seligman
    < bump >
