2.5-3" AAL + billies up front @ 1.75? level?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hamNswiss on rye, Jan 30, 2011.
  1. Jan 30, 2011 at 3:21 PM
    hamNswiss on rye
    hamNswiss on rye [OP] ¡Yo Quiero Taco World!
    Nick
    Scottsdale, AZ/Portland, ME
    '07 4x4 Access Cab
    OME 885's and billies all around, allpro apex front bumper, Nfab tire carrier, black magic rallye 1000 driving lights, custom back to the future light rack, KC LED Daylighters, PIAA 510 fogs, bed lights, satoshi, 285/70/17 Duratracs
    in the semi near future (aka when i come into some cash), im looking to lift my daily driver (2007 4x4 access) a bit for a beefier look. i will be doing some off roading, but nothing crazy. i think ive decided on going with the rear AAL and billies up front. i just had a few questions.
    1) i do not have the leaf spring TSB done, will these (below) AAL's fit/bolt right on? do i have to do any other modifications (other than get the truck re-aligned)?
    (first one)
    http://www.thepartsbin.com/catalog/?N=1725+11782+4294962484&Ntt=Add-A-Leaf
    2) if i do go with those leafs, will the billies at 1.75 lift the front enough to level the truck (a little rake is okay)? i dont want to go to 2.5 because ive read further modification is required, and it could be too stressful on the stock suspension.
    3) im thinking billies just in the front and leaving the stock shocks in the back. with this lead to any problems? is it highly recommended that i go with billies all the way around?
    thanks,
    Nick
  2. Jan 30, 2011 at 3:29 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    1. They will work just fine.
    2. I'm level with 1.75 up front and 1" in the rear. 3" rear will give you lots of rake. Most go with only a 1.5-2" AAL with 2.5" up front.
    3. For only $100 more, the rear billys will greatly improve the ride.
  3. Jan 30, 2011 at 3:35 PM
    hamNswiss on rye
    Nick
    '07 4x4 Access Cab
    what about billies at 2.5 and 3" AAL? for the light off roading i will be doing and daily driving, will the billies at 2.5 be alright? will i have to change anything else like the UCA's if they are set at 2.5?
    also, will there be much rake here? im new to this, sorry
  4. Jan 30, 2011 at 3:58 PM
    KPT
    09 Prerunner
    Why are you wanting to go with the Skyjacker AAL? There are less expensive, higher quality options out there like Toytec. That way you could get a 1.5" AAL, set the billy's at 1.75" and have a slight rake.
  5. Jan 30, 2011 at 4:16 PM
    hamNswiss on rye
    Nick
    '07 4x4 Access Cab
  6. Jan 30, 2011 at 4:19 PM
    KPT
    09 Prerunner
    All depends on how much rake you want. If you went 1.5" rear, 1.75" front, you would still have a small amount of rake. Like I said I'm level with 1" rear and 1.75" front.
  7. Jan 30, 2011 at 4:36 PM
    hamNswiss on rye
    Nick
    '07 4x4 Access Cab
    alright...i cant find the 1.5'' toytec AAL's for the non TSB pack. do they make them? or would i have to go with the 2''?
  8. Jan 30, 2011 at 4:36 PM
    Beerrun
    Beerrun Well-Known Member
    Jon
    Spokane WA
    10 Sedan Sport LB
    Fog light rewire- debadge- front window tint- 5100's @ 1.75- Toytec 1.5 AAL- Avid sliders- 4x4 lighted switch- Sockmonkey decals- Truxedo low pro QT cover- Weather Techs- Back up light Mod. Diff. breather mod. OEM roof rack-Yakima bars. HomerTaco grill. Hella Black Magic Lts. WT vent visors.
    I have Billies set at 1.75 with stock springs. The rear (No TSB) was just a bit low, depending on load, fuel. So I installed a 1.5 Toytech AAL last night. I measured before and after, and the rear came up 2.25. To much rake, for me anyway. But from what I've read they should settle a bit over time. Who sells a 1.0 AAL? I couldn't find one.
  9. Jan 30, 2011 at 4:41 PM
    Beerrun
    Jon
    Spokane WA
    10 Sedan Sport LB
  10. Jan 30, 2011 at 4:42 PM
    lynyrd3
    lynyrd3 Strength ,Determination ,Merciless,Forever
    Bill
    Upstate New York ,Columbia County
    2008 SR5 AC SUPER WHITE V6 4x4
    Bilstein 6112s at top setting ,1/4" top plate spacer driver side,Total Chaos UCAs ,SS extended brake lines ,Rear 4 leaf Suspension TSB,Wheelers 2" AAL, Bilstein 5125s , SS extended brake lines rear , Toytec dif drop , Hayden high performance transmission fluid cooler,aFe pro dry filter , ,Powerstop drilled and slotted rotors.N-Fab light bar with 4 Hella OR lights , Devil horns by Andres ,Weathertecs floor protector, American Racing wheels Baja 17x8,4.5 BS , 285/70 Falken Wildpeaks AT/3W .Body Armor rear bumper . Extra D rings in bed ,Blue sea fuse block and 100amp breaker ,G-Tek Fab door sill protectors ,blacked out grille , painted pinch weld.Shorty antenna ,HVAC knob mod ,LED dome and map lights , Tri Fold bed cover ,UltraGauge ,Morimoto XB LED fog lights ,
    This is the way to go !:burnrubber:
  11. Jan 30, 2011 at 5:07 PM
    KPT
    09 Prerunner
    I don't think anyone makes one. The tsb pack gives 1" lift over the 3 leaf pack.
  12. Jan 30, 2011 at 5:16 PM
    hamNswiss on rye
    Nick
    '07 4x4 Access Cab
