2.5 Bilstein lift shock or ToyTech 2.5 spacer both do the same right?
Discussion in 'Suspension' started by yfz450ak, Oct 11, 2009.
  1. Oct 11, 2009 at 10:03 PM
    yfz450ak
    yfz450ak [OP] Active Member
    Chino, California
    06 PreRunner
    NEED THEM ASAP
    K so here is the question i cant find anywhere,,, If the Bilstein compress the shock from the bottom up....... and the spacer compresses the coil from the top down,,, dont they do the same thing,,, just differnet placement right??? wouldent you get the same ride...
    If you think about it they are both spacing the coil in two different location, or am i just wong...
    It seems to me you would get the exact same lift and ride...
    Please explaine if i am wrong,,,, Also i just want to raise the front just 1 inch higher in the front front and leave the rear stock,,,,what is good way to go,,, will both above get the same result.... thanks guys
  2. Oct 11, 2009 at 10:55 PM
    Deathprone
    Deathprone Member
    Dallas
    08 Acc Cab 4WD
    Stock
    Yes they both compress the spring to get lift, however the 5100 shock is designed to be used with a preloaded spring the stock shock is not so ride quality will be better with 5100s they also let you adjust between 4 lifts heights so you can just level your truck like your talking about.
  3. Oct 12, 2009 at 12:12 AM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    3 lift heights. The first setting is stock height.
  4. Oct 12, 2009 at 9:34 AM
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    You are correct.
    This is the case with all coil-overs. They compress the coil to achieve lift. The higher the lift the stiffer the ride.
  5. Oct 12, 2009 at 9:43 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    You will get a much better ride with the 5100's. It is a little more work to get them installed than a spacer, but in the long run after you put in a spacer lift you will wish you did a 5100 lift instead. Go on the 1.75 setting, it will level your truck out almost perfect.
  6. Oct 12, 2009 at 9:45 AM
    98tacoma27
    Ben
    Not Beech Creek
  7. Oct 12, 2009 at 8:17 PM
    yfz450ak
    Chino, California
    06 PreRunner
    NEED THEM ASAP
    So im going to go with the Bilstein Shock, that seems like the better way to go,,, 1 question is if I go with the shocks and set them at 2.5 in the front and stay stock in the rear,,, will the truck be level, or will the truck sit nose high... I want it to sit nose high just a tad...
  8. Oct 12, 2009 at 8:20 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Spacer lifts move the shock body lower which means that the shock will bottom out early when the suspension compresses. Since the bumpstop remains in the same place, you run the risk of your shock becoming your bumpstop and you'll snap the shock in 2.
  9. Oct 12, 2009 at 8:26 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    go with the 5100's. you will have a much better ride quality. take it from a guy who has a spacer lift
