2.5 in. Spacer on top of 6 inch suspension?
Discussion in 'Suspension' started by caleb337, Jul 21, 2008.
  1. Jul 21, 2008 at 2:59 PM
    caleb337
    caleb337 [OP] Lifted Tacoma
    Carencro, Louisiana
    6 inch lift on a 05 SR5 TSS
    6 inch Procomp Lift, 35 inch Mud Terrains.
    I have a 6 inch Procomp Stage I lift, and I was wondering if I have to settle for a body lift or if I can add my 2.5 inch spacer on top of my lift.
  2. Jul 21, 2008 at 3:12 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    I'm gonna take a wild guess and say that "don't stack lifts" is gonna be the answer, but go ahead and wait for another opinion.
  3. Jul 21, 2008 at 3:14 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Stack two Fabtech lifts on top of each other for 12" of lift.
    Socal562 likes this.
  4. Jul 21, 2008 at 3:21 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    The sky's the limit!:D
  5. Jul 21, 2008 at 4:40 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    No. I'm not an engineer, but you probably shouldn't do that. Get the body lift if you want it higher.
  6. Jul 21, 2008 at 6:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2! Im getting 2 6"ers and 3 pairs of OME springs. :D
  7. Jul 21, 2008 at 6:54 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Reach for the stars!:D
  8. Jul 21, 2008 at 7:04 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    Chris will be hitting the stars with his face!
  9. Jul 21, 2008 at 7:24 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Or seeing stars when I hit a bump! :D
  10. Jul 21, 2008 at 7:29 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    Nah. You'll have what, 15"+ of travel? You'd be driving on a cloud!
  11. Jul 21, 2008 at 7:55 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Do they make brushgaurds that handle space junk?
  12. Jul 21, 2008 at 10:07 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    y'all gonna scare the OP away...
    :D
    get some King coilovers in extended length and you can crank em up another inch and a half or more...
  13. Feb 18, 2009 at 5:04 PM
    KoolWipTacoma
    KoolWipTacoma Member
    Lynchburg Va
    05 Taco DB Cab 4x4
    lots with update soon!
    i thought this site was about asking ?s an showing off ur ride an helping others. if somome1 has a ? just answer it. u dont have to be a smart-ass!....... But any way yes you can sack the spacer on top of ur 6" BUT it will have ur cv's at a bad angle that will cause ur boots to bust in a short time. UNLESS u have a prerunner (2wd) it will be fine to do this. revteck spacer is a two peice spacer 2" peice& 1/2" peice. u can try useing the 1/2" peice for a little extra lift or vice-versa but a dont think i would do the whole thing although it looks bad ass and u can run 37"s!
  14. Feb 19, 2009 at 8:33 PM
    KoolWipTacoma
    Lynchburg Va
    05 Taco DB Cab 4x4
    i correct myself... the revteck is 1"1/2 [not 2" like i said above] peice and a 1/2" peice total of 2"... but still give u 3"
  15. Feb 19, 2009 at 11:49 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Hello 2008, welcome to 2009. :bananadance:
  16. Feb 22, 2009 at 11:37 AM
    KoolWipTacoma
    Lynchburg Va
    05 Taco DB Cab 4x4
    i didnt say it was a good idea. i agree its better off with just the 6" but i was just answering the ?. it is posible yes, good idea no! some people have done it with no problems but most of them have had problems.
  17. Feb 22, 2009 at 11:53 AM
    tc2008
    tc2008 Well-Known Member
    Garden Grove, CA
    06 Speedway Blue
    8000K HID light, LED map and dome light, cluster + AC blue, Camburg 2.5 front and rear, Deaver 10 Packs. Satoshi Grille, Eyelids, Carbon fiber hood w/ scoop, BHLM, 285/75/16 km2s, KMC enduros
    NEWB ALERT!!! :smack:
  18. Feb 22, 2009 at 12:02 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok. Yes you can do it. Your ride will suffer, and you will loose some down travel. You may need some UCA's to get the alignment back into spec.
  19. Feb 22, 2009 at 6:55 PM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    Putting the spacers on with the pro comp lift kit is essentially the same as putting spacers ontop of the stock suspension. Yes it will increase the angles but it would be the same angle that all of us 3" guys have.
  20. Feb 24, 2009 at 3:21 PM
    KoolWipTacoma
    Lynchburg Va
    05 Taco DB Cab 4x4
    correct me if im wrong, but but the procomp & fabtech only drop the diff bout 4" for a 6" lift. the 6" kit does not set the cv angles bak to the way it was stock. so it would be more like adding a 4" spacer(ballpark fingure) rather than the 2" spacer. it would be worse than adding the 3" kit to a stock truck. Again i may be slighty off but you can get wat im saying.
