2.5" sway aways saw race runners??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtaco, Aug 9, 2008.
  1. Aug 9, 2008 at 8:07 AM
    jtaco
    jtaco [OP] Well-Known Member
    07,trdOR,DC,4x4,v6,saw2.5s,OMEdakars,LRarms
    saw2.5s,AEMshortair,skyjackershocks,LRa-arms,OME dakars,Alpine,JL audio 6x9 3 way in front doors
    i just got the 2.5" saws installed , i unscrewed the set screw, but i cannot budge the spanner wrench when tryin to raise them about 1/2 inch . What am i missing here?
  2. Aug 9, 2008 at 8:14 AM
    RoadKill
    RoadKill Northern Alliance: padawan
    North of the border
    First gen 4x4
    285x70x17 offset rims+ 1.5 spacers, rear Timbrens + 3 inch lift add a leaf, Sway-a-way coilovers + camburg control arms, Fender flares (2.5 inch), clear lights, headers, sliders, roll bar
    there is a small locking allen screw you need to loose before you ajust height
  3. Aug 9, 2008 at 10:09 AM
    jtaco
    yea , that is the set screw i refer to in first post, i took it all the way out even but i cannot turn them at all with spanner wrench and they are brand new direct from sway away. i mean i can barely get up in there to get enough leverage. but i get enough i think that it should at least move.
  4. Aug 9, 2008 at 2:41 PM
    RoadKill
    North of the border
    First gen 4x4
    try taking the truck weight off the wheel with a jack before binding the ajustment or you might strip the treads, maybe loosen and check it?
  5. Aug 9, 2008 at 3:00 PM
    jtaco
    u mean try loosening first after lift with jack?
  6. Aug 9, 2008 at 3:40 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Put the front of the truck on jack stands to get the weight off the front tires and suspension. Back the adjusting collar off about 1/2 turn, then try to adjust it to the desired height. :)
  7. Aug 9, 2008 at 4:07 PM
    jtaco
    the only way i could move it either way was hit the spanner with a hammer. this is after i have lifted, and taken out set screw all the way. should it be this hard?? all i had to lift it was toyota jack and put a brick under that so i could only lift one side, but the left side is the only side i need to raise.
  8. Aug 9, 2008 at 5:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You need both tires off the ground, otherwise you will be fighting the tension from the sway bar. You could try and disconnect the sway bar and see if that helps.
  9. Aug 9, 2008 at 9:19 PM
    jtaco
    oh lord , this is more then i bargained for
  10. Aug 9, 2008 at 9:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Naw! You'll be fine, and your truck is gonna be sweet! Just have a bit of patience. :)
  11. Aug 9, 2008 at 9:42 PM
    jtaco
    well i just have spent so much money cause when i get one thing, i find i need another to make it work rt, then payin for installs cause my health is not all that good and i dont have tools.and it then it just keeps getting worse. lol
    see now i have to go buy another jack. cant i just lift the middle front to lift both tires? i got the patience, i just dont have the money.
  12. Aug 9, 2008 at 9:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Where do you live? Maybe there is a Member in your area that can lend a hand/tools?
  13. Aug 9, 2008 at 9:52 PM
    jtaco
    jackson,ms. . hopefully cause there isnt shit here, i mean no one here, (shops) that know what the hell they are doing. i mean they all claim they do but shit i know more then they do, i just cant physically do it, so when they mess it up , i have to take it back and pull teeth and bribe them into getting it corrected like 5 or 6 times plus tell them how to do it. and u dont even know how hard it is when the break something. its always the tire shops fault, or the susp shops fault or ricks pro trucks fault, everyones but theirs.
  14. Aug 9, 2008 at 9:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Start a thread to see if anyone can lend a hand. :)
  15. Aug 10, 2008 at 7:51 AM
    jtaco
    yea ill just get another jack, but thanks so much for tellin me i have to lift both ends. i dont understand why allpro , sway away and all these supposedly profressional places dont tell u the details, they just advertise like bling blang wow, LOOK , easy bolt on , bla bla bla. They dont say u have to be a near bout certified mechanic and have prior extensive knowledge of 4x4s and everything there is to know about them in and out or u will spend weeks on research and then if u are loaded with money and your health is perfect and u can run 10 miles without panting then u will be able to install our products. oh and have a spring compressor and all sorts of 150 dollar jacks and what not.
  16. Aug 10, 2008 at 8:53 AM
    jtaco
    well i borrowed a neighbors jack, got both front tires off the ground, and still had to use a hammer on the spanner wrench to move it.it was just as hard to move it as it was when i just lifted the one side i was adjusting.
    yea man im just tired of being ripped off, seems like there are no honest people left in the world.shit bro im just telling it how it is. oh beleive me , i am tryin to chill out, u have no idea what i have been through with all these shops and allpro and these mechanics. if i werent chilled out , i wouldnt killed them or myself by now.
